pippozzzz
disk full or not?
Sun Nov 13, 2016 9:13 am
I've a raspberry pi2 with raspbian installed. I keep raspbian updated and every 15 days i use apt-get update and upgrade (also dist-upgrade if needed).
I've mounted an external usb drive where i store some photos (raw files and jpeg). This hard drive is formatted with ext3.
Now something stringe is happening: i was trying to copy some more files but i've got an error (something like "impossible to copy, the drive is full").
So i checked with df -h and i got this:
/dev/sda1       2,7T  2,4T    192G  93% /media/usbhdd1
so i tried df -i and i got this:
/dev/sda1      183140352  14598 183125754    1% /media/usbhdd1
So i don't understand why this drive semms to be full when i copy a new big file but with df command i have still 300gigabyte free.
Can you help me understanding what is happening?
PeterO
Re: disk full or not?
Sun Nov 13, 2016 9:22 am
How are you trying to copy these new files ?
What command or application are you using ?
What is the exact error message ?
PeterO
aleifuu
Sun Nov 13, 2016 9:57 am
just out of curiosity, how big the files are you trying to copy over ?
pippozzzz
Sun Dec 11, 2016 9:43 am
sorry for my late answer, but i was abroad for work.
this is the exact message:
cp: errore scrivendo "pippo.mkv": Spazio esaurito sul device
cp: creazione dell'extent di "pippo.mkv" non riuscita: Spazio esaurito sul device
is in italian. In english should be like:
cp: error writing "pippo.mkv": No more empty space on device
cp: creating the extent of "pippo.mkv" failed: No more empty space on device
I'm trying to copy a file of 500Mbyte
this is the output of sudo df -h on that device:
/dev/sda1       2,7T  2,4T    163G  94% /media/usbhdd1
Do you have any idea?
pippozzzz
Sun Jan 01, 2017 8:29 pm
Any ideas?
I searched almost everywhere but i found nothing :(
Sun Jan 01, 2017 8:32 pm
Do you have lots of files on that disk? Sometimes you can hit the limit of the number of files (but that is normally very high).
What does df -i show on that partition?
patrikg
Sun Jan 01, 2017 8:49 pm
You can search for large files like this command.
sudo find / -size +100M
That will find files greater than 100 mega bytes.
pippozzzz
Sun Jan 01, 2017 9:38 pm
I have a lot of large files. They are raw files as result of a merge of some shoot (from 300 to 1000 megabyte per files), so i have a relatively low numbers of files stores (about 3000 files).
with df -i -h i have this result:
              INODE     IUSED  IFREE   IUSE
/dev/sdb1       175M    15K    175M    1% /media/usbhdd1
pippozzzz
Sat Feb 04, 2017 8:34 am
up, any idea? I've searched everywhere but i found no help :(
dasmanul
Sat Feb 04, 2017 10:33 am
What exact commands are you using to copy the files? How big are the files you're trying to copy? Can you post the output ot
sudo tune2fs -l /dev/sdb1
pippozzzz
Sat Feb 04, 2017 12:55 pm
This is the output:
tune2fs 1.42.12 (29-Aug-2014)
Filesystem volume name:   backup
Last mounted on:          /media/usbhdd1
Filesystem magic number:  0xEF53
Filesystem revision #:    1 (dynamic)
Filesystem features:      has_journal ext_attr resize_inode dir_index filetype needs_recovery sparse_super large_file
Filesystem flags:         unsigned_directory_hash
Default mount options:    user_xattr acl
Filesystem state:         clean with errors
Errors behavior:          Continue
Filesystem OS type:       Linux
Inode count:              183140352
Block count:              732558080
Reserved block count:     36627904
Free blocks:              79191196
Free inodes:              183125749
First block:              0
Block size:               4096
Fragment size:            4096
Reserved GDT blocks:      849
Blocks per group:         32768
Fragments per group:      32768
Inodes per group:         8192
Inode blocks per group:   512
Filesystem created:       Thu Jan 22 20:37:35 2015
Last mount time:          Sat Feb  4 09:42:07 2017
Last write time:          Sat Feb  4 09:44:45 2017
Mount count:              192
Maximum mount count:      -1
Last checked:             Thu Jan 22 20:37:35 2015
Check interval:           0 (<none>)
Lifetime writes:          2737 GB
Reserved blocks uid:      0 (user root)
Reserved blocks gid:      0 (group root)
First inode:              11
Inode size:               256
Required extra isize:     28
Desired extra isize:      28
Journal inode:            8
Default directory hash:   half_md4
Directory Hash Seed:      da5f22cd-4b9c-4e3d-ba6c-4004976258c1
Journal backup:           inode blocks
FS Error count:           188412
First error time:         Sun Feb 14 22:20:53 2016
First error function:     ext4_mb_generate_buddy
First error line #:       757
First error inode #:      0
First error block #:      0
Last error time:          Sat Feb  4 09:44:45 2017
Last error function:      ext4_mb_generate_buddy
Last error line #:        758
Last error inode #:       0
Last error block #:       0
dasmanul
Sat Feb 04, 2017 2:32 pm
PeterO wrote:How are you trying to copy these new files ?
dasmanul wrote:What exact commands are you using to copy the files?
pippozzzz
Sat Feb 04, 2017 2:45 pm
a simple cp
Example:
cp source.dat destination.dat
Also using scp i have the same problem, and also sharing a directory with sftp.
For sure i have rights to write in that directory
dasmanul
Sat Feb 04, 2017 2:59 pm
Are you also absolutely, positively sure the destination directory is actually on that disk? What does a "df <targetdir>" give you? What happens if you try a "dd if=/dev/zero of=<targetdir> bs=1M count=700"?
pippozzzz
Sat Feb 04, 2017 3:17 pm
Yes, i'm sure about it
This is the output of that command:
700+0 record dentro
700+0 record fuori
734003200 byte (734 MB) copiati, 29,1462 s, 25,2 MB/s
in english should be:
700+0 record in
700+0 record out
734003200 byte (734 MB) copied, 29,1462 s, 25,2 MB/s
dasmanul
Sat Feb 04, 2017 3:43 pm
Sorry, was too quick earlier. That should have been
dd if=/dev/zero of=<targetdir>/testfile bs=1 count=700
Can you still access the target directory? The output looks like dd could indeed write 700 MB, so the disk is not full. The last thing I can think of is to run
strace <your exact cp command>
and post the (probably very long) output and your exact command here.
Return to “Raspbian”
