jenfbe
How to put Raspian Jessie on a sd? (new user)
Wed Sep 28, 2016 2:33 pm
I have a RPi that is located in a remote data-centre.
I wanted to install PiVPN on it, and for that I needed to upgrade to the jessie release.
I tried the "dirty way" I found by googling, and that worked... until the reboot after the PiVPN installation. It doesn't come up again.
Now the data-centre will send me the SD-card, so that I can install the new OS on it and send it back.
So my question: Will the default installation be sufficient, or do I need to modify things?
For example: I need to access the RPi via ssh, do I need to do something for it?
Since the slow process of sending the SD-card back and forth, I should be do it right the first time.
Thank you in advance!
ssfdre38
Re: How to put Raspian Jessie on a sd? (new user)
Wed Sep 28, 2016 3:31 pm
You can follow this guide https://www.raspberrypi.org/documentati ... /README.md and will tell you how to do it for your following system
Rasbian Latest Builds on SourceForge at https://sourceforge.net/projects/raspbian/
Github at https://github.com/ssfdre38
3 2B & 1 3B
Return to “Raspbian”
