vinceducat
yes another Rpi 3 internal wifi problem
Sat Sep 03, 2016 11:44 am
Hello
i have fresh install lastest image ...on a new rpi3
but i cant use wifi with the last jessie raspbian version.
i try all i found in many forum , but no connexion.
i have a french isp box freebox v5 in wpa psk mode.
but the connexion never start....
pi@raspberrypi:~ $ iwconfig
wlan0 IEEE 802.11bgn ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
lo no wireless extensions.
eth0 no wireless extensions.
pi@raspberrypi:~ $ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:9e:8c:cf
inet adr:192.168.0.27 Bcast:192.168.0.255 Masque:255.255.255.0
adr inet6: 2a01:e34:ee8b:90:27d3:ce3e:f5b4:546/64 Scope:Global
adr inet6: fe80::1b52:869c:b47d:4e41/64 Scope:Lien
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:91238 errors:0 dropped:0 overruns:0 frame:0
TX packets:50304 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 lg file transmission:1000
RX bytes:124694812 (118.9 MiB) TX bytes:5194310 (4.9 MiB)
lo Link encap:Boucle locale
inet adr:127.0.0.1 Masque:255.0.0.0
adr inet6: ::1/128 Scope:Hôte
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr b8:27:eb:cb:d9:9a
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:224 errors:0 dropped:224 overruns:0 frame:0
RX bytes:36199 (35.3 KiB) TX bytes:0 (0.0 B)
pi@raspberrypi:~ $ dmesg | grep brcmfmac
[ 6.739722] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[ 6.740440] usbcore: registered new interface driver brcmfmac
[ 6.910822] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[ 6.933923] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 7.163407] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 22.727619] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 22.727633] brcmfmac: brcmf_add_if: ignore IF event
[ 22.731770] brcmfmac: power management disabled
[ 256.286616] WARNING: driver brcmfmac_sdio did not remove its interrupt handler!
[ 256.789010] brcmfmac: brcmf_fil_cmd_data: bus is down. we have nothing to do.
[ 256.789035] brcmfmac: brcmf_dev_pno_clean: failed code -5
[ 256.941622] usbcore: deregistering interface driver brcmfmac
[ 260.313153] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[ 260.313646] usbcore: registered new interface driver brcmfmac
[ 260.388413] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[ 260.404976] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 260.527972] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 260.527987] brcmfmac: brcmf_add_if: ignore IF event
[ 260.533723] brcmfmac: power management disabled
seem to have some error here dont find how to solve it
pi@raspberrypi:~ $ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
pi@raspberrypi:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
country=GB
update_config=1
network={
scan_ssid=1
ssid="BRAKAOUAC"
psk="**************"
psk change... but check many time containt special caracter &...
could you help me... i bought a rpi 3 to have a intern wifi connexion
can any body could help me to configure this wifi
i try update upgrade same problems.... with another wifi key it work....
thanks
vinceducat
Re: yes another Rpi 3 internal wifi problem
Sat Sep 03, 2016 4:23 pm
i dont have problem with anaother wifi usb key... wifi connection ok
Linux raspberrypi 4.4.13-v7+ #894 SMP Mon Jun 13 13:13:27 BST 2016 armv7l GNU/Linux
fergusondavid6
Sun Sep 04, 2016 12:09 am
I had this exact issue, where a USB wifi adapter worked, but the internal one didn't, and it turned out the problem was my power supply couldn't provide enough current to the Raspberry Pi. Initially I was using a 2A one, but when I tried a 3.5A one everything worked find.
How much current can your power supply provide? If it's less than 3A, I'd recommend trying a higher current one as a first step.
vinceducat
Sun Sep 04, 2016 2:57 pm
thanks, i m trouble because i bought a bundle with rpi3 power supply sd card.
my actual power supply is 2.5A... i will try to find an over current one ... seems a strange probleme ....
thanks....
can we monitor the current on the rpi3 ??? via a soft tools ??
vinceducat
Sun Sep 04, 2016 3:06 pm
did you have a brand/model for PSU ?
thanks
ssfdre38
Mon Sep 05, 2016 6:36 am
They fixed it if you can update it. if not i do make updated raspbian images and i have it at https://sourceforge.net/projects/raspbian/ so there it that.
This link will help to set your wifi if you want to try and manually set it up via the term
https://learn.adafruit.com/adafruits-ra ... cidentalis
Rasbian Latest Builds on SourceForge at https://sourceforge.net/projects/raspbian/
Github at https://github.com/ssfdre38
3 2B & 1 3B
vinceducat
Mon Sep 05, 2016 5:10 pm
thanks i m no in 4.4.19-v7+ #906 SMP Tue Aug 23 15:53:06 BST 2016 armv7l GNU/Linux
version du to sudo BRANCH=next rpi-update ....
i will try your link 1st is it newer version than 4.4.19 ?
i will try your second link but this seems not to respect the last jessie style ussing dhcpcd.conf .....
ssfdre38
Mon Sep 05, 2016 6:25 pm
i am building a new img but the second link works cause i had problems with wifi and i used adafruit's fix and it worked
3 2B & 1 3B
vinceducat
Wed Sep 07, 2016 8:50 pm
it seems to work with version date 08-16 after
sudo apt-get update
sudo apt-get dist-upgrade
sudo rpi-update
pi@raspberrypitest2:~ $ uname -a
Linux raspberrypitest2 4.4.20-v7+ #908 SMP Wed Sep 7 14:44:27 BST 2016 armv7l GNU/Linux
wath was the difference beetween raspberrypi org and your version ??
wath was the patch ??
thanks
vinceducat
Sun Sep 11, 2016 1:04 pm
what are the changes in the version 08 2016 ???
ssfdre38
Sun Sep 11, 2016 5:57 pm
it just has all the updates that is out to that date and it uses the official raspbian build tool
3 2B & 1 3B
Return to “Raspbian”
