Lob0426
Re: Raspbian Server Edition?
Fri Aug 24, 2012 9:40 am
nickstewartroc wrote:Running the RSE v2 atm. Running great so far! So far the only thing I've had to do is do a apt-get install sudo
Other than that, Awesome work! :D
-Nick
That's pretty funny. I ran it the other day and sudo did not work. I thought I had a bad download. Did not even think of just installing it! :lol: I still have it on the card so I guess I will install sudo. :D
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
SirLagz
Fri Aug 24, 2012 10:32 am
haha sorry guys. ill put it back in soon and release a new version. anyone tried raspi-config on v2 ? any opinions ?
thanks !
Jim JKla
Fri Aug 24, 2012 12:26 pm
sudo apt-get install sudo 8-)
nickstewartroc
Fri Aug 24, 2012 3:18 pm
No prob! The only reason I needed it is to run the visudo command
c_k
Sun Aug 26, 2012 9:24 am
Can you make this Raspbian Server Edition image as clean as an installation with only the "SSH server" task installed?
Here is a copy of the output from "dpkg --list" and "cd /; ls -alR" to show what is installed and what files exist:
Raspbian fresh installation with only SSH server task selected: dpkg --list
http://slexy.org/view/s20vhbtpNe
Raspbian fresh installation with only SSH server task selected: cd /; ls -alR
http://slexy.org/view/s2l2oSogE1
SirLagz
Sun Aug 26, 2012 11:24 am
I *could* do that...but if you have already got an install like that, why not just make an image of the SD card ?
SirLagz
Sun Aug 26, 2012 5:02 pm
RSE v2.1 released
Reinstalled Sudo into the image
also update raspi-config a bit more, it now has a network configurator of sorts.
Linky !
Feedback is always welcome
Thanks !
SirLagz
Tue Jan 01, 2013 2:16 pm
SirLagz
Wed Feb 13, 2013 4:16 pm
SirLagz
Mon Mar 04, 2013 6:59 pm
tonyhughes
Mon Mar 04, 2013 7:03 pm
Downloading now. Incredibly useful for a 1GB SD card I have lying around, for a non-performance critical server.
Thanks!
bluc
Fri Mar 08, 2013 9:21 am
Hey all total noob with anything not windows or gui based. Wondering if any overheads using this as opposed to stock raspbian with gui loaded? Also any benefit to use this compared to the full raspian without the gui loaded. Running sabnzbdplus and trying to free up resources the pi seems to max itself according to the cpu usage.
SirLagz
Sat Mar 09, 2013 8:39 am
This has less overheads as there is no gui installed, so less system resources is used up by not having a gui.
Space is also saved as I have removed a whole bunch of packages.
If you already have a working setup, then you would probably be better off having a look at the output of 'top' and see what is using all of your resources.
wpns
Sat Mar 09, 2013 2:43 pm
Any idea how much 'overhead' is saved by just not starting the GUI in Raspian (and leaving the memory split at 'minimum video' memory)?
I understand there are a lot of packages removed, which saves space on the SD card and allows you to run on a 1GB card, just curious how the actual performance is between this release and the stock Raspian...
Great project, BTW, thanks for making it available to the community!
SirLagz
Sat Mar 09, 2013 4:24 pm
Unfortunately I don't run a Pi with a GUI so I couldn't tell you.
Feel free to try them both out and report back though :)
I'll be getting a Pi with a GUI running sometime soon hopefully so I may have some stats later on.
Wiaf
Tue Mar 12, 2013 12:03 pm
I've just tested the RSE2.3 image and it works fine. Good work there SirLagz. Any other image (apart from wheezy) didnt work on my RPi B-Model with a Class10 Sdcard. As stated in this thread http://www.raspberrypi.org/phpBB3/viewt ... 66&t=36210
Yours seems to work perfect.
I got a question though, on the initial raspi-config I selected Turbo for overclocking and got "bug bad rss" counter, the system not starting up. From what intel Ive gathered all Rpis should be able to overclock to maximum without a breach in warranty. Why isnt this working on my model? Maybe you have an idea?
Also: Is there any other way to changing the overclock setting apart from "re-dd-ing" a fresh image onto the sd?
-Wiaf
SirLagz
Wed Mar 13, 2013 1:03 am
Not sure why it wouldn't work when overclocking...
If you want to disable overclocking, you should be able to modify the config.txt file and remove / modify the overclocking lines.
Wiaf
Wed Mar 13, 2013 6:30 am
SirLagz wrote:Not sure why it wouldn't work when overclocking...
i've changed it from 1gig to 700mhz and it booted up just fine. I was just wondering :)
so far RSE2.3 is running smoothly :P
SirLagz
Sun Mar 24, 2013 6:53 pm
Apparently this is so popular that all my website bandwidth has disappeared :lol:
I may get some downtime at the end of this month due to lack of bandwidth, but I'll be getting newer versions mirrored so this doesn't happen again
duberry
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
Sun Mar 24, 2013 7:55 pm
thenewguy wrote:I realize these things, my issue isn't a question of functionality so much a size. I could download and set up a full Raspbian image, but I think some people (such as myself) would appreciate starting with a smaller download. There is something nice about being able to start from the ground and build up from it, rather than starting with everything and trimming it down.
true that!
depending on your intended use you might want to take a look at picore
more info in this link
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
duberry
Sun Mar 24, 2013 7:59 pm
SirLagz wrote:1GB Image of RSEv2.3 - grab it at http://sirlagz.net/2013/03/04/raspbian- ... 1gb-image/
thanks!
downloading ..
SirLagz
Tue Mar 26, 2013 2:27 pm
Since my blog is now out of bandwidth, I'm self-hosting the images myself, though the speeds aren't great.
The files can be found here - http://sirlagz.ath.cx/Pi/
Hiradur
Thu Mar 28, 2013 2:23 pm
Much appreciated! Downloading...
But maybe you should think about hosting it at Dropbox? Not complaining about download speed, 130kb/s ist ok for me but to save bandwith for your own private needs :)
SirLagz
Thu Mar 28, 2013 4:15 pm
My Dropbox is full lol.
Not to worry, I have a few voluntary mirrors, and I'll use google drive to upload them for next time too :)
Hiradur
Thu Mar 28, 2013 9:26 pm
Do you have a script to remove the packages from an already installed Raspbian image? Would save me some trouble. :)
Return to “Raspbian”
