gkreidl
Re: Video Converter HandBrake 0.10.5 for RPi2&3
Sun Jan 29, 2017 7:04 pm
micu wrote: thanks.
I've done it,
I've still the same problem. Can I try to install libavdevice55 manually ?
Yes, use apt-get.
BTW, are you trying to install with dpkg?
Minimal Kiosk Browser (kweb)
micu
Mon Jan 30, 2017 12:11 am
yes, like this
$ sudo apt-get install - libavdevice55
Reading package lists... Done
Building dependency tree
E: Unable to locate package libavdevice55
thank you for your help
gkreidl
Mon Jan 30, 2017 12:38 am
Are you on Raspbian Jessie?
It's in the Raspbian archive: http://archive.raspbian.net/raspbian/po ... iba/libav/
micu
Mon Jan 30, 2017 9:19 am
gkreidl wrote:Are you on Raspbian Jessie?
thanks. I installed that pack but now it says
Dependency is not satisfiable: intltool
Maybe there is a problem because I've installed a too new version of Raspbian Jessie?
I installed it by noobs 2.1.0 two day ago. I could try to install all packages manually?
gkreidl
Mon Jan 30, 2017 10:06 am
Did you install gdebi-core and use it to install ghb?
micu
Mon Jan 30, 2017 9:02 pm
yes, I did
sudo gdebi ghb_0.10.5-1_armhf.deb
Building data structures... Done
This package is uninstallable
thanks you so much, I'm giving up now..
gkreidl
Mon Jan 30, 2017 11:13 pm
There's something definitely broken with your Raspbian system.
micu
Sun Feb 05, 2017 12:30 pm
What a mystery. I've formatted and I've reinstalled Raspbian, always the same problem.
gkreidl wrote:There's something definitely broken with your Raspbian system.
gkreidl
Sun Feb 05, 2017 1:59 pm
micu wrote:What a mystery. I've formatted and I've reinstalled Raspbian, always the same problem.
Try installing some standard package like firefox.
bonkeman
Mon Apr 17, 2017 7:04 pm
Just wanna say thanks for this one! Installed it with no problems at all and it works just fine!
gkreidl
Thu Aug 17, 2017 7:19 am
Artionic wrote:
Thu Aug 17, 2017 6:16 am
Handbrake works great on my computer. And handbrake has updated the version to 1.0.7, so you can install the latest version of it. Otherwise, you can find the old version here: https://www.videohelp.com/software/Hand ... s#download
And there are many online video converters now, which does not need any installation: http://www.videoconverterfactory.com/ti ... erter.html
And these free online video converters can also be amazing for video conversion. So share with you.
You won't find any version for the Raspberry Pi on their download page.
I don't plan to create a newer RPi version just now, but perhaps after we have switched to Stretch.
Nachteule
Wed Sep 20, 2017 5:41 pm
@gkreidl
I built Debian Stretch package [1] today, but the result is very disappointing :(
On my Cubieboard2 (it is 1GHz dualcore ARMv7) running Debian Stretch, I'm getting average transcoding rates of 2 fps when transcoding an ISO DVD to a mkv. So being optimstic, RPi3 has 4 cores and one core is three times faster than my Allwinner A20 cpu, RPi3 would have 12 fps.
So, how do you get 28 fps when transcoding sd video :shock:
Btw, Im getting activity log
x264 [info]: using cpu capabilities: ARMv6 NEON
That's confusing me a bit, because shouldn't it be ARMv7 ???
[1] Grabbed Debian Stretch source package, modified debian/rules and debian/control and rebuilt package
gkreidl
Thu Sep 21, 2017 6:01 am
@gkreidl
Creating and testing a Stretch version is on my to-do-list but other things have a higher priority.
Nachteule
Mon Oct 02, 2017 3:15 pm
Yes, I know, you already talked about that
But, this was not my question ;)
My question was how did you get 28 fps when transcoding sd video
I'm now on RPi3, not overclocked and I'm getting 8.8 avg fps transcoding a DVD ISO image to mkv (High profile, cropping a bit, sound and subtitles passthrough). Core temperature is between 70 and 72 °C, so no CPU throttling will reduce transcoding speed
If anybody wants to test my Handbrake build, packages for Debian Stretch are available for download from here
Btw,
comes from libx264 and this lib does not distinguish between ARMv6 and ARMv7 processors
gkreidl
Mon Oct 02, 2017 8:19 pm
If anybody wants to test my Handbrake packages, Debian Stretch packages available for download here: http://apt1.xbian.org/pool/devel/rpi2-stretch/h/
Btw,
Have a look here: viewtopic.php?f=66&t=109584
Perhaps automatic neon detection is not enabled for some Stretch packages.
kazuko.nakamura
Sun Oct 08, 2017 10:45 pm
Would be great if Handbrake could handle OMX hardware.
Last edited by kazuko.nakamura on Mon Oct 09, 2017 9:31 am, edited 1 time in total.
Nachteule
Sun Oct 08, 2017 11:15 pm
Would be great if Handbrake coul handle OMX hardware.
Does not make sense, please read this post
Malowz
Fri Nov 24, 2017 1:38 pm
Hi, im trying to download the packages for stretch, but the site gives me 404 on that folder. it has moved somewhere else?
Nachteule
Fri Nov 24, 2017 1:49 pm
Yes, address has been changed, but the download link in my original post works
Khatharr
Sun Jan 21, 2018 2:25 am
I'm trying to transcode an mkv with embedded ass subs to mp4 hardsub, but your build does not detect the embedded subs. Windows HB sees them just fine.
darthtony2
Tue Jan 23, 2018 9:33 am
Hi i'm new ! on everything xD first timeusing linux! so after a week i've succeed to install your handbrake (thanks a lot really) but after a while , while it is enconding ir disappear !
i've no error no closing window ....
just it close with no reason ! some help ?
i've raspberry pi 3 ,raspbian jessie i've mounted heatsinks but no cooling fan !
thank you
gkreidl
Tue Jan 23, 2018 12:11 pm
thank you
I have seen a few crashes while converting to mp4 , but never when the output container format is set to mkv.
darthtony2
Tue Jan 23, 2018 1:15 pm
thank you
the container was mkv ! codec h264 level 5.2
gkreidl
Tue Jan 23, 2018 3:02 pm
No idea. I'm not one of the authors, I just compiled and packaged it for the RPi.
darthtony2
Tue Jan 23, 2018 3:27 pm
ok thanks ! i will try changing something
Thank you so much ! it works with the presets settings !
i love you ! :D
Return to “Raspbian”
