MrM87
[INFO] PI to a Virtual machine
Sat Feb 20, 2016 10:57 am
i have a Raspberry B first version; i use it with raspbian jessie lite and a software for the weather.
The problem is that sometimes i need to modify the DB and the RP need to calculate all the new value and this need at least 10hrs.
I'd like to do this:
virtualize the raspberry on my PC then move the DB to the raspberry.
Is possibile clone the raspberry to a virtual machine?
Thanks in advance to all!
elatllat
Re: [INFO] PI to a Virtual machine
Sat Feb 20, 2016 3:34 pm
qemu.org
though likely you could just optimize your code instead.
also likely you could just use Ubuntu in virtualbox instead of using the raspberry pi OS
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Return to “Raspbian”
