beje
Re: [GUIDE] Raspbian Lite with RPD/LXDE/XFCE/MATE/i3/Openbox/X11 GUI
Fri Apr 06, 2018 8:43 am
GhostRaider wrote:
Sat Jan 23, 2016 3:19 am
The top and bottom panels are Tint2 panels. I customized the Tint2 panels to my liking to achieve this look. The notifications displayed on the desktop are from xfce4-notifyd. I want to be notified of things such as disconnection from the Internet, or Raspberry Pi is getting hot, or other notifications thrown by Raspbian Lite. Let's see the memory usage of my custom desktop environment:
Dear GhostRaider a VERY BIG THANK YOU! I register here mainly to give you this. I know that there is a big amount of time invested into creating quality content and than (1) to share it (for free) and on the comunity board and (2) to also support the others!
I have also a selfish request: would you share the openbox / tint2 configuration? For the bottom dock/panel I pretty much know what to do, but I am dead curious of how you have set up the top panel. :ugeek:
p.s. to all of you that just requesting stuff, stop for one second and appreciate. And here I mean, take 1 minute and thank the man who worked before (directly) asking for something!
GhostRaider
Sun Apr 08, 2018 3:45 am
Tint2 gives you the ability to have multiple panels. So one panel can go on the left, then in the middle, and then the right. So while it looks like its a single panel, its just 3 panels on top. Hope that helps! ;)
Guides I have created on the Raspberry Pi Forums:
1) [GUIDE] Raspbian Lite with PIXEL/LXDE/XFCE/MATE/Openbox/i3
2) [GUIDE] Communicate between iOS and Raspberry Pi using MQTT
migasmike
Mon Apr 09, 2018 2:25 pm
I´m new in this.
Who can i revert my desktop environment to RPD. Now i´m using the LXDE.
I don´t know how LXDE appears on my Raspberry.
Appreciate your help
chrishurley
Tue Apr 10, 2018 12:39 pm
I used this guide last year to set up a Pi with a customised xfce desktop, and it was AMAZING, many many thanks. However I have recently come to set up another Pi, came back to this page only to find it's been edited and all the juicy customisation help has gone :( most disappointed...
TheTechKid
Thu Apr 26, 2018 11:54 pm
GhostRaider-
Could you post a guide for your custom Openbox setup? It would be useful for noobs like me :D
Thanks ,
TheTechKid
steigerlabs.io | My Website
HelmutR
Fri Apr 27, 2018 12:34 pm
Hello!
I hope i am right here with my Problem:
I have build a Script to start Chromium in Openbox with Tint2 - it should used for working at Home and build a connection to our Company via Citrix!
In Jessie, all went fine, worked like a charme, now i have upgraded to Stretch (building the Environment complete new) and now Chromium opens the .ica Files (Citrix start files) in Leafpad instead of Citrix Receiver...
I unterstand the difference between an desktop environment and Openbox - Chromium use here xdg-open to claim the mime-types...
What have i done?
xdg-mime default wfica.desktop application/x-ica
no change! then i have created HOME/.local/share/applications/defaults.list with the correct binding, tried the solutions from here: https://ubuntuforums.org/archive/index. ... 45173.html
but nothing, Chromium opens the File in Leafpad... and now its going to be strange: if i start pcmanfm in the same session in openbox the .ica files have the correct binding and wenn i double click them, the Citrix App opens :shock:
Maybe its a bug in Stretch? As i said - in Jessie there was no problem, the correct binding was already there out of the box!
Perhaps anyone have an Idea what to do, or have that done already ;)
Thanks!
Sorry for my English, i am from Austria and i write not often in English :oops:
starlight.tu
Mon Apr 30, 2018 5:01 am
Excuse me,
Could you share all the packages' name of this theme please?
I also would like to know whether it could use on RPD?
antiriad
Contact: Twitter
Wed Aug 22, 2018 7:16 am
This guide is awesome, but it would be nice if it could be expanded with instructions to activate OpenGL acceleration.
Installing
sudo apt-get install xcompmgr libgl1-mesa-dri
and activating the OpenGL driver in raspi-config still does NOT work... someting is missing.
Any hint?
JamesPi123
Tue Oct 02, 2018 7:36 am
Really nice tutorial, GhostRaider
Sunwind
Mon Oct 08, 2018 11:31 pm
Installed everything fine, first login of xfce using xstart it asked me to create default panels etc, I said yes, restarted, when I login (pi/raspberry) it says no running instance of xfce4-panel was found, start? I hit yes, the desktop loads fine, but it says modifying the panel is not allowed running in 'kiosk mode' ? Thanks
Aciel
Re: [GUIDE] Raspbian Lite with PIXEL/LXDE/XFCE/MATE/i3/X11 GUI
Sat Oct 27, 2018 11:19 am
GhostRaider wrote:
Wed Jan 10, 2018 9:06 pm
I mostly cover GUI related things in the original thread instead of hardware. But yes, I've had the exact same problem that you have when you use NetworkManager with XFCE. The way I fix this issue is to edit "/etc/NetworkManager/NetworkManager.conf" and set managed=true so that NetworkManager takes over WiFi and Ethernet. Then I just run the command "sudo iwlist wlan0 scan" so that WiFi goes into the UP state. Finally I edit "/etc/wpa_supplicant/wpa_supplicant.conf" and delete everything inside it. After a restart, NetworkManager now shows the WiFi networks in the system tray.
Will the above settings work on Raspbian Stretch Lite LXDE? I tried it and wifi works, but ethernet said "device not managed". Can you please shed some light here.
Frederk
Fri Dec 07, 2018 7:00 pm
I use Openbox and when i created a new user obconf and lxappearance didn't work. If i try it in terminal i get this answer:
frederik@raspberrypi:~ $ obconf
Segmentation fault
Kind84
Thu Dec 13, 2018 10:58 pm
Very nice guide! Immediately bookmarked. I have a small question related to the GUI: I’m running RPD desktop on standard Raspbian. I accidentally selected the Preferences setting to load defaults for large screens. Now the whole UI is messed up with ugly icons. Even selecting medium or small screens did not made the UI come back to its default nice theme. Any idea on what to do to bring back the original? It was very nice and now it looks very bad. Thanks for your help.
Frederk
Tue Dec 25, 2018 5:22 pm
obconf still doesn't work. Can you please help me?
drmullins
Sat Jan 12, 2019 9:34 am
obconf seems to be ok now after latest update/upgrade
however lxappearance does not work at the moment leading to difficulties in setting gtk theme and icon theme etc. A possible workround may be to edit the configuration files directly using any text editor. The relevant files are ~/.config/lxsession/LXDE/desktop.conf and~/.config/gtk-3.0/settings.ini. It seems that both must be modified identically
See also threads under troubleshooting
Frederk
Sat Jan 12, 2019 10:07 am
I fixed lxappearance by removing the package lxappearance-obconf
drmullins
Sun Jan 13, 2019 5:25 pm
Thanks Frederk - that worked. I hope the foundation arrange for lxappearance-obconf plug-in to be fixed (like obconf) so that the integrity of LXDE metapackage is restored !
PjotrekSE
Sun Jan 20, 2019 10:13 pm
Advanced - X11 Forwarding (Remote Applications)
I don't seem to be able to connect to the pi with Mobaxterm. I followed all instructions, including installing the XFCE GUI. But Mobaxterm gives the error 'X11-forwarding : ✘ (disabled or not supported by server)'. I googled the problem and tried all remedies found, but to no avail. Checked that xinit is run on the pi, X11forwarding enabled in the ssh & sshd configs in the pi and that .Xauthority is present in the used home. What to do?
GhostRaider
Mon Jan 21, 2019 4:53 pm
Strange. A possibility would be that the service is disabled. Try
sudo systemctl enable sshd.socket
in Terminal and restart and try to connect again.
Return to “Raspbian”
