Page 12 of 13
Re: Two XBMC (.deb) compiled/prepared for users + instructio
Posted: Sat Oct 05, 2013 3:20 pm
by juppiter89
Uhm... try to install the package udev
sudo apt-get install udev
Posted: Sat Oct 05, 2013 3:41 pm
by mcgyver83
No luck
Reading package lists... Done
Building dependency tree
udev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
/usr/lib/xbmc/xbmc.bin: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
Posted: Sat Oct 05, 2013 3:42 pm
by juppiter89
Ok, now try libudev1
sudo apt-get install libudev1
Well, I think I undestood:
in Raspbian Wheezy there is libudev0, not libudev1.
A possible workaround should be to create a symlink. Please try
sudo ln -s /lib/arm-linux-gnueabihf/libudev.so.0 /lib/arm-linux-gnueabihf/libudev.so.1
Posted: Sat Oct 05, 2013 3:55 pm
by mcgyver83
E: Unable to locate package libudev1
Only *udev
libudev0 libudev-dev
and both are installed
Posted: Sat Oct 05, 2013 4:01 pm
by juppiter89
Sorry for these troubles, and thank you for your feedback :)
Please try the workaround of my last post.
Posted: Sat Oct 05, 2013 4:08 pm
by mcgyver83
Sorry??? :ugeek:
You're helping me for free, I have to say thank you!!!!
I made the simlink and now:
xbmc
/usr/lib/xbmc/xbmc.bin: /lib/arm-linux-gnueabihf/libm.so.6: version `GLIBC_2.15' not found (required by /usr/lib/xbmc/xbmc.bin)
/usr/lib/xbmc/xbmc.bin: /lib/arm-linux-gnueabihf/libudev.so.1: no version information available (required by /usr/lib/xbmc/xbmc.bin)
/usr/lib/xbmc/xbmc.bin: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.17' not found (required by /usr/lib/xbmc/xbmc.bin)
Posted: Sat Oct 05, 2013 4:15 pm
by juppiter89
Hehe, I try to do my best :D
However, unfortunately, I think you have to upgrade to Raspbian Jessie, because I compiled XBMC using Jessie libraries. If you want to do this, run:
sudo nano /etc/apt/sources.list
and change wheezy with jessie in "deb http://mirrordirector.raspbian.org/raspbian" line, then
sudo apt-get update && sudo apt-get dist-upgrade
Posted: Sat Oct 05, 2013 4:21 pm
by mcgyver83
I Jessie the new version of Weezy?
I red that Jessie is the testing version.
How can I compile myself XBMC?
Posted: Sat Oct 05, 2013 4:23 pm
by juppiter89
Jessie is the new version of Raspbian, based on Debian Jessie.
Officially it is an "unstable" version, but it is almost perfectly usable.
Posted: Sat Oct 05, 2013 4:27 pm
by mcgyver83
I trust you. I'm upgrading.
But is too difficult to provide a guide to compile XBMC with only CEC support?
I tried many time following this guide http://www.raspbian.org/RaspbianXBMC but every time something went bad
Posted: Sat Oct 05, 2013 4:32 pm
by juppiter89
Well, I followed exactly that guide, plus other hints found on the net (expecially https://github.com/xbianonpi/xbian/wiki ... pendencies).
However, compiling is not a easy task, many little things can go wrong.
Posted: Sat Oct 05, 2013 4:40 pm
by mcgyver83
Ok, so I will update this topic as soon as upgrade ends.
Posted: Sat Oct 05, 2013 4:42 pm
by juppiter89
Ok, thank you for your testing :D
Posted: Sat Oct 05, 2013 4:44 pm
by mcgyver83
thank you for the help!!!!!
Posted: Sun Oct 06, 2013 6:07 pm
by mcgyver83
Before I had only one .xbmc folder under /root/.xbmc.
Now I have also a .xbmc folder under $HOME/.xbmc
I copied the /root/.xbmc folder over the $HOME/.xbmc folder but I still miss all my settings.
I'm on tail on both the xbmc.log files (/root/.xbmc/temp/xbmc.log and $HOME/.xbmc/temp/xbmc.log) but no log lines when I use xbmc
Posted: Sun Oct 06, 2013 6:50 pm
by juppiter89
Hi, first of all, does XBMC start correctly now?
About the settings, if you have /root/.xbmc folder, you sometime had certainly run XBMC as root, and not as normal user. This is a bad behavior. You should not start XBMC (and any user application) as root!
Having said that, I don't know if you can copy setting between different users (in this case root and pi I presume). However, although not advisable, you might start XBMC as root, so you may see if you can keep your settings.
sudo bash
then
xbmc
EDIT: If you copied from /root/.xbmc to $HOME/.xbmc, make sure to fix permissions of copied files
sudo chmod -R +wr $HOME/.xbmc
Posted: Mon Oct 07, 2013 5:56 am
by mcgyver83
Thanks again.
Yes, maybe once I run xbmc as root but I'm quite confident not each time.
But no problem, I fixed files permission. Xbmc starts fine now.
I'm at work now, so this evening I'm going to try to run xbmc with fixed permission on $HOME/.xbmc folder ad I'll update this post.
Posted: Tue Oct 08, 2013 7:15 am
by mcgyver83
None, my settings are lost but doesn't matter, starting from now I'll run xbmc not with sudo.
At the first start xbmc asked me for a password to check for update, what is it?
Posted: Wed Oct 16, 2013 9:24 pm
by mcgyver83
When I exit from XBMC menu, in the shell I started it, this message is raised:
Exception SystemExit in <function _remove at 0x1ac1b30> ignored
Posted: Sat Jan 04, 2014 1:00 am
by mcgyver83
no update?
Posted: Wed Feb 19, 2014 10:17 am
by milad69_1
I have a problem :( i installed xbmc using instruction on this page . I selected no for starting xbmc by default. and after reboot a login page shows and even though i didn't change default user pass (pi/raspberry) i cannot login! actually screen splashes and login page starts again and wont start the any of sessions.
what should i do? is there a way to start a terminal and remove xbmc?
Posted: Sat Mar 01, 2014 5:57 pm
by mcgyver83
Since a month ago CEC was working with the samsung tv remote control.
Now the "pheriperial" menĂ¹ in system settings is disable, grey.
How is it possible?
Posted: Mon Mar 03, 2014 9:21 pm
by mcgyver83
Hi man,
I used your compiled xmbc but now I have a problem with CEC.
So I though to try to compile it.
I followed the guide you suggested https://github.com/xbianonpi/xbian/wiki ... pendencies in this message http://www.raspberrypi.org/phpBB3/viewt ... 61#p432961
All is fine.
After a night and more all the pieces are compiled.
I'm a newbie so, now what I have to do to install xbmc ?
In the guide some "add on" like libcec and libshairport were compiled before xbmc, others (PVR Addons,..)after.
The first were automatically included in the xbmc and the last no?
Posted: Fri Jan 23, 2015 10:40 pm
by eloyucu
I followed the two first steps:
 wget https://github.com/downloads/RB-tomaz/xbmc-rdp-tomaz/xbmc-rdp-tomaz.armhf.deb
    sudo dpkg -i xbmc-rdp-tomaz.armhf.deb; sudo apt-get -y -f install
But what I got was the scratch IDE!!!!! WTF!!!!!????
Posted: Fri Jan 23, 2015 10:52 pm
by DirkS
eloyucu wrote:I followed the two first steps:
Have you checked the date that software was last changed at https://github.com/RB-tomaz/xbmc-rdp-tomaz :?:
Why would you want to download and install that :?: :?:
