Copy&Paste with RDP to XRDP doesn't work
Posted: Tue Oct 13, 2015 9:15 am
by Robertus
i have a little problem because copy and paste doesn't work for me.
I use RDP in windows 7 64bit ( default remote ) for my raspbian ( sudo apt-get install xrdp)
but copy and paste from windows to raspbian and viceversa doesn't work
Please someone can help me about that?
I read a lot of stuff without success.
Re: Copy&Paste with RDP to XRDP doesn't work
Posted: Tue Oct 13, 2015 1:17 pm
by klricks
Robertus wrote:Hi,
You are correct C&P does not work with RDP.
As an alternative I found that C&P does work from a SSH connection using PuTTy.
From RPi to Windows: Select text with mouse left button hold and drag (press no other keys). Then on the Windows side use Paste menu or CTRL-V
From Windows to RPi: Copy text then on the RPi put cursor at insertion point. Be sure to place cursor with arrow keys and NOT mouse! Then right click the mouse.
Posted: Tue Oct 13, 2015 7:50 pm
by Robertus
klricks wrote:
Robertus wrote:Hi,
i tried without success from and to windows :/
Posted: Tue Oct 13, 2015 9:51 pm
by klricks
Did you do this using SSH connection instead of RDP?
Posted: Thu Oct 15, 2015 8:44 am
by Robertus
no, how can i do it?
Posted: Thu Oct 15, 2015 1:10 pm
by klricks
Install PuTTY on your Windows computer. http://www.chiark.greenend.org.uk/~sgtatham/putty/
A tutorial from my web site: http://www.blackeagle12.net/Comp/RPi/SSH.html
Posted: Fri Oct 16, 2015 7:35 pm
by Robertus
thanks klricks, i will try and i hope to have success :)
Posted: Sun Nov 01, 2015 8:29 am
by coding
Excuse me, but how can PuTTY be the answer to this question? It is a very tedious workaround. After all, we use RDP to see a graphical user interface, not a text console, right? So please, is anyone else interested in a real solution? PuTTY is a great tool but has nothing to do with RDP.
Can anyone explain why Copy&Paste does not work? How can you be satisfied with the PuTTY workaround?
Posted: Sun Nov 01, 2015 9:05 am
by fruitoftheloom
coding wrote:Excuse me, but how can PuTTY be the answer to this question? It is a very tedious workaround. After all, we use RDP to see a graphical user interface, not a text console, right? So please, is anyone else interested in a real solution? PuTTY is a great tool but has nothing to do with RDP.
Another alternative:
https://bigdanzblog.wordpress.com/2015/ ... g-tightvnc
http://www.nongnu.org/autocutsel
Posted: Sat Feb 13, 2016 5:14 am
by godsendpie
klricks wrote:
Robertus wrote:Hi,
I don't understand. It looks like I can do C&P between my Windows and my LinuxMint via RDP. And it's xrdp on Mint too. Is that due to different versions of xrdp?
