chewy74
Issues after upgrading to jessie
Sun Oct 11, 2015 3:57 am
Hey everyone, I'm having the following issues after upgrading to jessie from wheezy on my Raspberry Pi 2.
1. Edits to /etc/resolv.conf are not sticking after reboot. I set nameserver 8.8.8.8 & 8.8.4.4 but after reboot it reverts to default nameserver 192.168.1.1
2. Transmission rpc won't connect after upgrading. I followed the Raspberry Pi Torrentbox tutorial and got transmission daemon to run, and transmission rpc to connect, but after rebooting the Pi 2 I lose connection with transmission rpc and can’t remotely connect. I believe the daemon is active because sudo service transmission-daemon status shows:
pi@raspberrypi ~ $ sudo service transmission-daemon status
transmission-daemon.service - Transmission BitTorrent Daemon
Loaded: loaded (/lib/systemd/system/transmission-daemon.service; enabled)
Active: active (running) since Sat 2015-10-10 12:52:24 EDT; 1min 30s ago
Main PID: 441 (transmission-da)
Status: "Uploading 0.00 KBps, Downloading 0.02 KBps."
CGroup: /system.slice/transmission-daemon.service
└─441 /usr/bin/transmission-daemon -f --log-error
Oct 10 12:52:24 raspberrypi systemd[1]: Started Transmission BitTorrent Daemon.
Oct 10 12:52:26 raspberrypi transmission-daemon[441]: [2015-10-10 12:52:26.439 EDT] UDP Failed to set receive buffer: requested 4194304, got 327680 (tr-udp.c:78)
Oct 10 12:52:26 raspberrypi transmission-daemon[441]: [2015-10-10 12:52:26.439 EDT] UDP Failed to set send buffer: requested 1048576, got 327680 (tr-udp.c:89)
Oct 10 12:52:46 raspberrypi transmission-daemon[441]: [2015-10-10 12:52:46.461 EDT] Continuum.S04E06.720p.HDTV.x264-KILLERS Tracker error: "Connection limit exceeded! You may only s...rrent.c:580)Oct 10 12:52:46 raspberrypi transmission-daemon[441]: [2015-10-10 12:52:46.461 EDT] Z.Nation.S02E05.HDTV.x264-KILLERS.mp4 Tracker error: "Connection limit exceeded! You may only see...rrent.c:580)Oct 10 12:52:46 raspberrypi transmission-daemon[441]: [2015-10-10 12:52:46.461 EDT] Haven.S05E14.720p.HDTV.x264-KILLERS Tracker error: "Connection limit exceeded! You may only seed ...rrent.c:580)Hint: Some lines were ellipsized, use -l to show in full.
If I execute the command:
sudo service transmission-daemon stop
then
sudo service transmission-daemon start
Transmission rpc will be able to connect remotely again. I’ve tried a fresh install thinking it was a update issue coming from wheezy, but problem still persist.
3. Kodi performance has degraded dramatically on jessie. Playing video of all resolution now stutters and audio will cut in and out throughout play. Audio will now also go out of sync while playing. I've also had to enable overscan twice already because settings got reset after a reboot, or start up. Kodi will also lockup when I turn up/down the volume through my TV remote through CEC... The other control functions like pause, play, rewind and fwd works fine, but volume adjustment will cause kodi to freeze and requires power cord pull.
My boot/config
arm_freq=1000
core_freq=500
sdram_freq=483
over_voltage=0
gpu_mem=320
force_turbo=1
avoid_pwm_pll=1
v3d_freq=300
4. I can't get a smb network share to auto mount at start up,but It will mount when I manually mount with
sudo mount - a
Any suggestions on these issues?
gkreidl
Re: Issues after upgrading to jessie
Sun Oct 11, 2015 9:57 am
I can only tell something about kodi on Jessie. For me it's working very snappy and I've got not problems whatsoever.
If video is lagging, select omxplayer in Video/Acceleration and disable MMAL.
BTW, gpu_mem=320 is a complete overkill and will only take away valuable RAM from the CPU side. 160 MB is good enough to run kodi (and everything else).
I've published my first Jessie version of kodi-15.2RC3 today. Perhaps you should try that.
Minimal Kiosk Browser (kweb)
chewy74
Sun Oct 11, 2015 1:08 pm
I will give your kodi version a try. I will also adjust the memory split,and give the omxplayer adjustment a try too... I plan on using the Pi 2 headless and won't be using omxplayer at all, so can I just remove it?
Thanks for the information
gkreidl wrote:I can only tell something about kodi on Jessie. For me it's working very snappy and I've got not problems whatsoever.
gkreidl
Sun Oct 11, 2015 3:36 pm
chewy74 wrote:I will give your kodi version a try. I will also adjust the memory split,and give the omxplayer adjustment a try too... I plan on using the Pi 2 headless and won't be using omxplayer at all, so can I just remove it?
Kodi on a headless RPi? That doesn't make sense to me.
chewy74
Sun Oct 11, 2015 3:39 pm
I meant I don't plan on using the desktop environment, or anything else except kodi, and as a always on torrent box. So I guess it's not really 'headless- since it's hooked up to the TV lol. Wrong usage... My bad
Sun Oct 11, 2015 3:53 pm
chewy74 wrote:I meant I don't plan on using the desktop environment, or anything else except kodi, and as a always on torrent box. So I guess it's not really 'headless- since it's hooked up to the TV lol. Wrong usage... My bad
Why not just use OpenElec or OSMC if you only need the KODI Media Centre Software :?:
Retired disgracefully.....
chewy74
Sun Oct 11, 2015 8:34 pm
I use flexget heavily with transmission and while you can compile openelec to be able to install flexget, there's not a lot of options for other things.
Might try Osmc... Have to look more into how well it runs with core programs I use
fruitoftheloom wrote: Why not just use OpenElec or OSMC if you only need the KODI Media Centre Software :?:
karma007
Fri Oct 23, 2015 9:31 pm
gkreidl wrote: I've published my first Jessie version of kodi-15.2RC3 today. Perhaps you should try that.
Hello, where can i find this version ?
thanks' a lot, i'm still on 15.0RC1 from michael.gorven
regards
Fri Oct 23, 2015 10:05 pm
regards
The Raspbian Jessie repository now has KODI 15.1
viewtopic.php?f=66&t=109088
Return to “Raspbian”
