mapomme1108
Auto mount NAS share at startup
Fri Sep 11, 2015 8:52 am
I want to automount a folder of a NAS on my local network at startup.
The folder adress is : \\192.168.0.13\Multimedia\Musique
The mount point would be : \mnt\Musique
I know the admin username and password of the NAS
I have tried to add it to the /etc/fstab without succes
Thanks per advance for your help
RaTTuS
Contact: Twitter YouTube
Re: Auto mount NAS share at startup
Fri Sep 11, 2015 9:09 am
if after you log in
does a
sudo mount -a
mount it OK ?
Covfefe
mapomme1108
Fri Sep 11, 2015 9:19 am
yes
sudo mount -a
does mount it OK
RaTTuS
Fri Sep 11, 2015 9:23 am
you'll need to add a delay to the boot, as the USB subsystem is not available when that mount gets done by the system there are posts here somewhere about it
Covfefe
mapomme1108
Sat Sep 12, 2015 8:42 am
I have added :
rootdelay=5
in /boot/cmdline.txt
and
sudo mount -a
in /etc/rc.local
and it works
rubikwizard
Sun Sep 13, 2015 9:29 am
You can also just add the line “mount -a” to the end of /etc/rc.local, before the line “exit 0″. That just forces network shares to be mounted at the end of the boot sequence.
This problem was introduced with the last Raspbian release (May 2015). Hopefully it will be fixed in the next release.
manleypv
Fri Oct 09, 2015 1:56 am
Rubikwizard, this isn't working for me. I added
sudo mount -a
and it hung up the boot process, as I found out immediately after in another post...
Anyway, added
mount -a
to /etc/rc.local and it's not working. Still have to manually mount after reboot.
Thoughts?
RaTTuS
Fri Oct 09, 2015 8:21 am
putting sudo in rc.local will have no effect as rc.local runs as root anyway
also this will not help in jessie as rc.local will be un out of sequence now
Covfefe
Return to “Raspbian”
