drhoeh
constantly have to mount -a
Fri Jun 26, 2015 4:49 am
I have a pi2 running raspbian and I have mapped it to a wd mycloud NAS. I entered the following in /etc/fstab
//myIP/public /home/pi/mynas/myshare cifs guest,workgroup=WORKGROUP, users,auto,user_xattr 0 0
I save and exit.
Then I enter sudo mount -a. Everything works just fine and all of my drives are mounted, however when I reboot the system nothing. I have to enter sudo mount -a every time I reboot the system.
Why do I have to remount the NAS after every reboot?
Any help would be greatly appreciated.
Thanks,
sprinkmeier
Re: constantly have to mount -a
Fri Jun 26, 2015 3:08 pm
at a guess the network isn't up when the boot-process does its "mount -a"
try adding a mount script as a hook script in /etc/network/if-up.d/
it should run automagically when the ethernet interface comes up.
drhoeh
Fri Jun 26, 2015 4:55 pm
Thanks for the help but I am not entirely sure how to do that. Do I just put "mount -a" in "sudo nano /etc/network/if-up.d/" or is there more to it? You will have to forgive me I am still very new at all of this.
thanks,
Tom_A
Fri Jun 26, 2015 7:23 pm
drhoeh wrote:Thanks for the help but I am not entirely sure how to do that. Do I just put "mount -a" in "sudo nano /etc/network/if-up.d/" or is there more to it? You will have to forgive me I am still very new at all of this.
thanks,
Add _netdev to /etc/fstab like so...
//myIP/public /home/pi/mynas/myshare cifs guest,workgroup=WORKGROUP, users,auto,_netdev,user_xattr 0 0
The reason the drive is not mounting is that the network is not up in time. The "_netdev" option will make the mount occur as soon as the network is available so it doesn't fail.
drhoeh
Fri Jun 26, 2015 7:39 pm
Thanks for the suggestion but when I tried _netdev but it did not auto mount at boot up. I still have to go in and type "sudo mount -a" to get the NAS on the PI.
Tom_A
Fri Jun 26, 2015 9:36 pm
drhoeh wrote:Thanks for the suggestion but when I tried _netdev but it did not auto mount at boot up. I still have to go in and type "sudo mount -a" to get the NAS on the PI.
I think there's also a problem with some of the current network updates. I seem to remember having the same issue after a recent update. I switched to NetworkManager and that fixed the problem as well as some others for me.
default_user8
Fri Jun 26, 2015 9:44 pm
Look here and see if any of these solutions solve your problem.
https://discourse.osmc.tv/t/osmc-alpha- ... -fstab/134
Two heads are better than one, unless one's a goat head.
sprinkmeier
Fri Jun 26, 2015 11:10 pm
put the following in /etc/network/if-up.d/mount_all_hack:
#!/bin/bash
/bin/mount --all &
the sudo chmod +x /etc/network/if-up.d/mount_all_hack
The script could be a lot smarter (i.e. make sure eth0 came up instead of lo etc...) but the above should do as a start.
Don't add any extensions to the filename (i.e. "hack.sh") or it will be assumed to be a backup file and ignored.
drhoeh
Sat Jun 27, 2015 1:22 am
thanks, I am still learning this stuff but, if I understand you right I am going to write a script. I want to be certain before I get myself into trouble.
I am going to create a file called
1. sudo mkdir etc/network/if-up.d
2. create a shell script sudo nano "/etc/network/if-up.d/mount_all_hack"
and put in
"#!/bin/bash
/bin/mount --all &"
3. I am then going to execute the script with, "sudo chmod +x /etc/network/if-up.d/mount_all_hack"
4. Then sudo /etc/network/if-up.d/mount_all_hack
Did I get this right?
diederik
Sat Jun 27, 2015 3:20 pm
drhoeh wrote:3. I am then going to execute the script with, "sudo chmod +x /etc/network/if-up.d/mount_all_hack"
Almost.
With "chmod +x <file>" you make it executable (but you're not actually executing/running it)
You don't have to do step 4 yourself. That script will be run automatically when the network becomes available.
rubikwizard
Sat Jun 27, 2015 8:52 pm
drhoeh wrote:I have a pi2 running raspbian and I have mapped it to a wd mycloud NAS. I entered the following in /etc/fstab
I save and exit.
Thanks,
This is a known issue with the May 2015 release and another solution is given here.
Basically add "mount -a" to the end of the file /etc/rc.local (before the line "exit 0").
drhoeh
Sat Jun 27, 2015 11:24 pm
WOW!!!
That did it, thanks for all the help.
The solution was to add "mount -a" to /etc/rc.local before exit 0.
You guys are great!
I appreciate all of the help.
sprinkmeier
Sat Jun 27, 2015 11:49 pm
drhoeh wrote:thanks, I am still learning this stuff but, if I understand you right I am going to write a script. I want to be certain before I get myself into trouble.
(missing leading "/", but nevermind)
That directory should already exist, and probably have a few files in it. If it doesn't then your install might be borked.
If you ever do need to create a directory hierarchy (rather than just one level at a time) use "mkdir --parents"
Return to “Raspbian”
