cjan
Re: Kodi 15/16 Packages for Raspbian
Thu Mar 23, 2017 10:11 am
Rascas wrote:
cjan wrote:does 17.1 RC = 17.1 ?
and, dvb-t channels audio and video not sync, not too much its only SD format.
Almost, 17.1 RC2 is just 3 or 4 commits behind.
No problem here with dvb-t channels, h264. Just like the previous versions. If in your country/provider it is mpeg-2, and you are not using RPi 3, it maybe worth buying th mpeg-2 license.
thanks, so will update again to 17.1?
about A/V no sync in Jarvis no such issue.
Rascas
Thu Mar 23, 2017 12:02 pm
There is no reason to update for now only to include 3 or 4 commits, and it won't solve your problem.
How do you have your setup connected ? HDMI, DACs, external soundcard, etc ? Please give more information.
Did you made any changes to audio/video configuration ? Can you check if the problem still exists with a clean Kodi settings (moving/removing /home/pi/.kodi) ?
Please provide your Kodi log to check your problem.
cjan
Thu Mar 23, 2017 11:27 pm
Rascas wrote: How do you have your setup connected ? HDMI, DACs, external soundcard, etc ? Please give more information.
ok, will check.
all setting is inherit Jarvis.
cjan
Sun Apr 02, 2017 12:54 pm
17.1 RC ask for update to 17.1, its annoying.
where to disable that?
Rascas
Sun Apr 02, 2017 3:05 pm
cjan wrote:17.1 RC ask for update to 17.1, its annoying.
It only asks one time...
derders
Re: Kodi 15.1-rc1 Debian package for Raspbian on RPi 2
Sun Apr 02, 2017 5:33 pm
aik wrote:
gkreidl wrote:xfce desktop? Kodi? What are we talking about.
I boot Pi, it starts with XFCE. Then I start Kodi, which is full screen. TV is 1920*1080 (which is 16:9). In Kodi, I navigate to a folder with a movie and start it. Its resolution is 320*240 (whish is 4:3 aspect ratio).
The movie starts in full screen but since its aspect is less than TV's one, it only occupies the area 1440*1080 in the center of TV. So there should be nothing on the left (240x1080+0+0) and on the right (240x1080+1680+0) of the TV screen.
However I can see respective XFCE desktop parts through these (240x1080+0+0) and (240x1080+1680+0).
This is (I think) because Kodi hides itself and runs omxplayer in fullscreen but since omxplayer outputs to overlay and preserves the aspect ratio, it does not expand the overlay to the entire screen (otherwise the video would be stretched from 4:3 to 16:9 which is ugly) so here is this weird effect.
Need a picture?
Hi
what is the solution for this problem ? I have the same with latest Kodi on Jessie
Edit:
okay I have changed some settings and I think this was caused by a faulty setting of refreshrate.
I had 59.94 hz set and changed it back to 60 hz
ReEdit:
okay this is strange .. for some videos it works like it should but other resolutions has the problem like in picture that I made.
With Libreelec it works but here in Jessie Kodi not.
How to fix this ?
davboc
Fri Apr 28, 2017 3:51 pm
Now I have kodi 15.2 on Jessie, installed following the first post in this topic. How can I update to 16 (or 16.1)? Using PiPplware repository it install 17.1 version...
Rascas
Fri Apr 28, 2017 4:08 pm
davboc wrote:Now I have kodi 15.2 on Jessie, installed following the first post in this topic. How can I update to 16 (or 16.1)? Using PiPplware repository it install 17.1 version...
There is now Kodi 17.1 (latest stable) available on Raspbian (Raspberry Pi Foundation Repo), which is the same in PiPplware repo, and is confirmed to work just fine. It is always advisable to run the latest stable version. If for some reason you need an old version, they are still available on PiPplware repo. After adding the repo, you need to downgrade kodi packages (check versions with apt-cache policy packagename), and install them specifying the respective version you want. Then you need to hold kodi and kodi-bin packages, at least, so they aren't updated later with the rest of system packages.
davboc
Fri Apr 28, 2017 4:16 pm
first of all thanks for reply!
I tried to install kodi 17, but I can't execute it, I only see a black screen and if I try to launch from command line typing only "kodi" I see this message error:
/usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin: error while loading shared libraries: libbrcmGLESv2.so: cannot open shared object file: No such file or directory
Rascas
Fri Apr 28, 2017 4:29 pm
davboc wrote: first of all thanks for reply!
You have an old firmware version. Update your system first with:
sudo apt-get update
sudo apt-get dist-upgrade
davboc
Fri Apr 28, 2017 4:32 pm
sudo apt-get update
obviously I already done it.
Thanks again
Rascas
Fri Apr 28, 2017 5:12 pm
Are you running Raspbian ?
What's the output of:
vcgencmd version
apt-cache policy libraspberrypi0
davboc
Fri Apr 28, 2017 6:43 pm
Rascas wrote:Are you running Raspbian ?
vcgencmd version
Thanks again for your support
pi@raspberrypi ~ $ vcgencmd version
Mar 15 2016 14:47:28
Copyright (c) 2012 Broadcom
version 1bf9a9a77026af9128a339c82d72e331d3532ee4 (clean) (release)
pi@raspberrypi ~ $ apt-cache policy libraspberrypi0
libraspberrypi0:
  Installato: 1.20160315-1
  Candidato:  1.20160315-1
  Tabella versione:
 *** 1.20160315-1 0
        500 http://archive.raspberrypi.org/debian/ wheezy/main armhf Packages
        100 /var/lib/dpkg/status
Rascas
Fri Apr 28, 2017 7:15 pm
You are using Raspbian Wheezy, the old version, this pakages are only for Raspbian Jessie.
davboc
Fri Apr 28, 2017 7:37 pm
Rascas wrote:You are using Raspbian Wheezy, the old version, this pakages are only for Raspbian Jessie.
I see the output now... seems very strange, I use jessie repository and I made upgrade and dist-upgrade...
Rascas
Fri Apr 28, 2017 7:44 pm
You don't have the raspberrypi.org Jessie repo configured, as you can see by the output above. Here is mine:
pi@pipplware:~ $ apt-cache policy libraspberrypi0
libraspberrypi0:
  Installed: 1.20170427-1
  Candidate: 1.20170427-1
  Version table:
 *** 1.20170427-1 0
        500 http://archive.raspberrypi.org/debian/ jessie/main armhf Packages
davboc
Fri Apr 28, 2017 11:09 pm
libraspberrypi0:
  Version table:
 *** 1.20170427-1 0
how this can be possible?
pi@raspberrypi ~ $ sudo cat /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
ktb
Sat Apr 29, 2017 1:32 am
davboc wrote:
Rascas wrote: You don't have the raspberrypi.org Jessie repo configured, as you can see by the output above. Here is mine:
libraspberrypi0:
  Version table:
 *** 1.20170427-1 0
mirrordirector.raspbian.org and archive.raspbian.org (Raspbian repo) are different from archive.raspberrypi.org (RPF repo).
pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ jessie main ui
#deb-src http://archive.raspberrypi.org/debian/ jessie main ui
gkreidl
Re: Kodi 15/16/17 Packages for Raspbian
Sat Apr 29, 2017 6:05 am
I just installed the new 17.1 version from the Foundation repository on one of my systems (a Raspberry Pi 2 using an Air Mouse for control).
The mouse cursor is rather jerky and the auto-scrolling feature of the new default skin makes it almost unusable with an Air Mouse (it's impossible to select anything from a long list). But after installing the old confluence skin again it works really well.
Minimal Kiosk Browser (kweb)
davboc
Sat Apr 29, 2017 8:09 am
ktb wrote: mirrordirector.raspbian.org and archive.raspbian.org (Raspbian repo) are different from archive.raspberrypi.org (RPF repo).
I'm very sorry for this error, now the output of the command is right
libraspberrypi0:
  Installato: 1.20170427-1
  Candidato:  1.20170427-1
  Tabella versione:
 *** 1.20170427-1 0
I made update upgrade and dist-upgrade but when I launch kodi I only see the logo for a second and black screen after that...
Rascas
Sat Apr 29, 2017 11:17 am
libraspberrypi0:
  Tabella versione:
 *** 1.20170427-1 0
Probably some inconpatible addon. Move or remove your old settings, /home/pi/.kodi
cjan
Sat Apr 29, 2017 11:58 am
so, can we remove PiPplware repos from source.list?
davboc
Sat Apr 29, 2017 12:09 pm
Probably some inconpatible addon. Move or remove your old settings, /home/pi/.kodi[/quote]
same behavior, I see the kodi logo flashing and after that a black screen.
Rascas
Sat Apr 29, 2017 3:50 pm
cjan wrote:so, can we remove PiPplware repos from source.list?
Yes
same behavior, I see the kodi logo flashing and after that a black screen.[/quote]
Upload your full kodi log to pastebin or something similar and leave the link here.
davboc
Sat Apr 29, 2017 9:01 pm
thanks to your help I probably solve the problem, now kodi start correctly.
I still have a question: how to make a script in order to autorun kodi at startup?
Thanks again for your great support
Return to “Raspbian”
