Page 18 of 30
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Posted: Mon Feb 22, 2016 12:08 pm
by gkreidl
stastka wrote:Try this:
If you want Kodi to automatically start when the system boots, edit /etc/default/kodi and change ENABLED to 1:
# Set this to 1 to enable startup
ENABLED=1
# The user to run Kodi as
USER=kodi
# Adjust niceness of Kodi (decrease for higher priority)
NICE=-5
I have successful installed kodi 15.2 under raspberian jessy
dany
I suppose this will run kodi as user "kodi". It will store its file in a different place then when you run it as user "pi".
Starting kodi from the desktop or command line will run it as user "pi" and will use different settings etc.
So I do not recommend this.
Posted: Thu Feb 25, 2016 2:04 am
by Rascas
I made Kodi 16.0 "Jarvis" available in the PiPplware repo, if there is someone interested.
To install it on Raspbian Jessie you can follow the instructions in this post:
viewtopic.php?p=832735#p832735
There is also Kodi 17 Alpha1 in the unstable repo, but it is still in early development so I recommend to use Kodi 16.
Posted: Thu Feb 25, 2016 2:10 am
by gkreidl
Rascas wrote:I made Kodi 16.0 "Jarvis" available in the PiPplware repo, if there is someone interested.
view ... 35#p832735
Did you use popcornmix backports for this version?
Posted: Thu Feb 25, 2016 2:11 am
by Rascas
Yes. It also has joystick/gamepad support.
Posted: Sun Feb 28, 2016 3:10 am
by Micha1982
I am more interested in that the actual repository-version of Raspbian gets an update to v16.... :mrgreen:
Btw, is the Youtube addon defect? Search does not work here actually, only saying bad request...for a short moment I saw something like "marked as abandoned"....is it dead?
Posted: Sun Feb 28, 2016 11:30 am
by Rascas
Actually, this Kodi packages are based on the Raspbian's (foundation) repository version.
The Debian scripts are the same, so compile/configure options, packaging, dependencies, etc, are the same. You can check the *debian.tar.xz also in Pipplware repo.
The only things changed from the original Kodi source code is:
- The inclusion of popcormix optimizations/additions for the Raspberry Pi available here:
https://github.com/popcornmix/xbmc/tree ... _backports
- The addition of gamepads/joystick support. The configuration of joysticks is the same as other platforms. Check the Kodi wiki.
- Some changes to /usr/bin/kodi script to prevent some Raspbian/Kodi bugs like black screen on exit, framebuffer (fbi) and CEC.
Relatively to Youtube, other addons and repositories, there isn't any change.
The problem with Youtube is that, it is currently unmantained, since the last developer stopped working on it. And yes, search is not working as it is, but if you initiate session with your Youtube account, everything seems to be working fine. There is also some workarounds (not tested) for the Youtube addon if you don't want to login with your account. You can find all this information here:
http://forum.kodi.tv/showthread.php?tid=200735
Posted: Thu Mar 03, 2016 6:30 pm
by futant
Hi, I'll just drop this in here in case anyone else has the same problem. Upgrading libraspberry* and raspberrypi-bootloader packages from 1.20160209-1 to 1.20160225-1 broke DTS passthrough via HDMI for me in Kodi. I confirmed the issue by downgrading the packages to previous versions and everything was again working without any changes to configuration. The issue existed with vanilla Raspbian Kodi and Pipplware Kodi 16. I posted a comment about this in github also but I don't know if that's the correct place https://github.com/raspberrypi/firmware/issues/548
My setup: RP2b -> HDMI -> Sony KDL 46HX tv -> Sony STR DB-790 amp (dts and dd only, no hd support). MMAL on, OMX off.
Posted: Fri Mar 04, 2016 7:05 pm
by Rascas
Well, DTS passtrough is working fine here with the latest kernel (4.1.18-v7+ #846). From what I read in your bug report, if I understood correctly, it seems to be a problem in VDR Raspberry Pi HD Device. Best report to them.
Posted: Fri Mar 04, 2016 7:55 pm
by futant
Hmm... my case really isn't related to VDR since I'm not using it at all (and I'm assuming we are talking about the Video Disk Recorder software here). Just the standard up-to-date Raspbian + Kodi. Currently the last working kernel for me is 4.1.17-v7+ #838. When I upgrade the packages to the latest versions via aptitude the kernel goes to 4.1.18-v7+ #846 and the DTS passthrough stops working. Or at least there is no sound from my amp.
[UPGRADE] libraspberrypi-bin:armhf 1.20160209-1 -> 1.20160225-1
[UPGRADE] libraspberrypi-dev:armhf 1.20160209-1 -> 1.20160225-1
[UPGRADE] libraspberrypi-doc:armhf 1.20160209-1 -> 1.20160225-1
[UPGRADE] libraspberrypi0:armhf 1.20160209-1 -> 1.20160225-1
[UPGRADE] raspberrypi-bootloader:armhf 1.20160209-1 -> 1.20160225-1
Downgrading these packages to previous versions makes the DTS passthrough work again after reboot. Maybe we have different hardware and the problem just doesn't appear in your setup.
I'm really at lost how the Raspbian bug tracking works and where I should report to about this. But I'll be happy to provide more info if it helps someone to fix the issue. When browsing the github changes in the firmware, this commit seemed to be the only one that touched the passthrough stuff, at least based on the developer's comment https://github.com/raspberrypi/firmware ... 2a75697a26.
Posted: Fri Mar 04, 2016 9:21 pm
by Rascas
I have tested in this connection scheme:
Pi -> HDMI -> AV Receiver -> HDMI -> TV
Speakers connected to AV Receiver.
DTS Passthrough is working using Pipplware 5.1, running my Kodi 16.0 Jarvis packages. Pipplware 5.1 is based on latest Raspbian Jessie with same kernel and firmware, so it should be the same in Raspbian Jessie (2016-02-26):
Linux pipplware 4.1.18-v7+ #846 SMP Thu Feb 25 14:22:53 GMT 2016 armv7l GNU/Linux
Feb 25 2016 14:31:22
Copyright (c) 2012 Broadcom
version dea971b793dd6cf89133ede5a8362eb77e4f4ade (clean) (release)
Posted: Fri Mar 04, 2016 9:37 pm
by futant
My connection is Pi -> HDMI -> Sony TV -> Optical -> Sony Receiver -> Speakers.
I just re-tested this with your Kodi 16.0 Jarvis packages before posting my previous reply and it is still broken with the latest Raspbian kernel. In Kodi configuration I have enabled HDMI passthrough, AC3 and DTS, otherwise the settings are pretty much on defaults.
With Pipplware Kodi I was able to get sound from DTS tracks with the new kernel if I enabled both DTS-HD and the AC-3 transcoding. But then my DTS streams were transcoded to DD which is less than optimal. With the older kernel my receiver shows that is is receiving DTS 3/2.1, with new kernel there is just silence. I don't doubt that the new kernel works for you but it sure doesn't work for me.
Posted: Fri Mar 04, 2016 10:26 pm
by Rascas
Hmm, it could be a SPDIF only issue. A friend of mine has also tested DTS passthrough in a similar setup as yours, with the only difference in HDMI connection oposed to SPDIF. It works for him also.
And the problem may be with that kernel commit. Maybe the best for you is to post a comment in that commit, explaining your situation / problem.
Posted: Fri Mar 04, 2016 10:33 pm
by gkreidl
futant wrote:My connection is Pi -> HDMI -> Sony TV -> Optical -> Sony Receiver -> Speakers.
What does
tvservice -a
report?
Posted: Sat Mar 05, 2016 11:27 am
by futant
here are my tests. The outputs are identical for both kernels. Maybe the fact that vcgencmd shows hdmi_stream_channels=1 in both cases could be some kind of clue (I'll post this info in the github as well). So hdmi_stream_channels was 1 always when the file was playing and 0 when it was stopped.
Working kernel: 4.1.17-v7+ #838 SMP Tue Feb 9 13:15:09 GMT 2016 armv7l GNU/Linux
$ tvservice -a
     PCM supported: Max channels: 2, Max samplerate:  48kHz, Max samplesize 24 bits.
     AC3 supported: Max channels: 6, Max samplerate:  48kHz, Max rate  640 kb/s.
$ vcgencmd hdmi_stream_channels
Non-working kernel: 4.1.18-v7+ #846 SMP Thu Feb 25 14:22:53 GMT 2016 armv7l GNU/Linux
$ tvservice -a
Posted: Sat Mar 05, 2016 7:05 pm
by typxxi
Hey,
I've got a current Raspbian installation with a kodi-jessie 15-2-3 running on raspi 2 latest modell at 900mhz.
I've made the latest updates and upgrades but it is not working if I start it by menu or file explorer (double click on startkodi file).
Here is the crash log:
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
 Date: Sa 5. Mär 19:04:46 CET 2016
 Kodi Options:
 Arch: armv7l
 Kernel: Linux 4.1.18-v7+ #846 SMP Thu Feb 25 14:22:53 GMT 2016
 Release: Raspbian GNU/Linux 8 (jessie)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====>  Core file: /home/pi/core (2016-03-05 19:04:16.462147539 +0100)
[New LWP 2174]
[New LWP 2175]
[New LWP 2182]
[New LWP 2176]
[New LWP 2189]
[New LWP 2195]
[New LWP 2177]
[New LWP 2187]
[New LWP 2194]
[New LWP 2186]
[New LWP 2160]
[New LWP 2193]
[New LWP 2188]
[New LWP 2185]
[New LWP 2165]
[New LWP 2192]
[New LWP 2169]
[New LWP 2166]
[New LWP 2191]
[New LWP 2184]
[New LWP 2162]
[New LWP 2170]
[New LWP 2190]
[New LWP 2163]
[New LWP 2171]
[New LWP 2183]
[New LWP 2196]
[New LWP 2167]
[New LWP 2180]
[New LWP 2197]
[New LWP 2181]
[New LWP 2172]
[New LWP 2179]
[New LWP 2168]
[New LWP 2173]
[New LWP 2164]
[New LWP 2159]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0  0x016bce84 in PERIPHERALS::CPeripheralCecAdapter::ProcessActivateSource() ()
Thread 37 (Thread 0x7400d000 (LWP 2159)):
#0  0x755c602c in ioctl () at ../sysdeps/unix/syscall-template.S:81
#1  0x01719068 in CLinuxInputDevices::CheckDevice(char const*) ()
#2  0x01719bf8 in CLinuxInputDevices::InitAvailable() ()
#3  0x016c17ac in CWinEventsLinux::MessagePump() ()
#4  0x00a24c70 in CApplication::FrameMove(bool, bool) ()
#5  0x00000000 in ?? ()
Thread 36 (Thread 0x724ff3b0 (LWP 2164)):
#1  0x763c7fa8 in completion_thread () from /opt/vc/lib/libvchiq_arm.so
#2  0x763decc4 in vcos_thread_entry (arg=0x763db250 <vchiq_instance+16>) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
#3  0x76887e90 in start_thread (arg=0x724ff3b0, arg@entry=<error reading variable: Cannot access memory at address 0xc>) at pthread_create.c:311
#4  0x755cd698 in ?? () at ../ports/sysdeps/unix/sysv/linux/arm/nptl/../clone.S:92 from /lib/arm-linux-gnueabihf/libc.so.6
/build/gdb-nrlhe3/gdb-7.7.1+dfsg/gdb/frame.c:472: internal-error: get_frame_id: Assertion `fi->this_id.p' failed.
A problem internal to GDB has been detected,
further debugging may prove unreliable.
Quit this debugging session? (y or n) [answered Y; input not from terminal]
Create a core file of GDB? (y or n) [answered Y; input not from terminal]
############# END STACK TRACE ###############
################# LOG FILE ##################
19:04:13 T:1946210304  NOTICE: special://profile/ is mapped to: special://masterprofile/
19:04:13 T:1946210304  NOTICE: -----------------------------------------------------------------------
19:04:13 T:1946210304  NOTICE: Starting Kodi (15.2 Git:02e7013). Platform: Linux ARM 32-bit
19:04:13 T:1946210304  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
19:04:13 T:1946210304  NOTICE: Kodi compiled Dec 28 2015 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
19:04:13 T:1946210304  NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.1.18-v7+
19:04:13 T:1946210304  NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
19:04:13 T:1946210304  NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
19:04:13 T:1946210304  NOTICE: ARM Features: Neon disabled
19:04:13 T:1946210304  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
19:04:13 T:1946210304  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
19:04:13 T:1946210304  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
19:04:13 T:1946210304  NOTICE: special://home/ is mapped to: /home/pi/.kodi
19:04:13 T:1946210304  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
19:04:13 T:1946210304  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
19:04:13 T:1946210304  NOTICE: Local hostname: raspberrypi
19:04:13 T:1946210304  NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
19:04:13 T:1946210304   ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanSuspend
19:04:13 T:1946210304   ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanHibernate
19:04:13 T:1946210304  NOTICE: load settings...
19:04:13 T:1946203056  NOTICE: Thread FDEventMonitor start, auto delete: false
19:04:13 T:1946210304  NOTICE: Found 2 Lists of Devices
19:04:13 T:1946210304  NOTICE: Enumerated PI devices:
19:04:13 T:1946210304  NOTICE:     Device 1
19:04:13 T:1946210304  NOTICE:         m_deviceName      : HDMI
19:04:13 T:1946210304  NOTICE:         m_displayName     : HDMI
19:04:13 T:1946210304  NOTICE:         m_displayNameExtra:
19:04:13 T:1946210304  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
19:04:13 T:1946210304  NOTICE:         m_channels        : FL,FR
19:04:13 T:1946210304  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
19:04:13 T:1946210304  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
19:04:13 T:1946210304  NOTICE:     Device 2
19:04:13 T:1946210304  NOTICE:         m_deviceName      : Analogue
19:04:13 T:1946210304  NOTICE:         m_displayName     : Analogue
19:04:13 T:1946210304  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
19:04:13 T:1946210304  NOTICE:         m_sampleRates     : 48000
19:04:13 T:1946210304  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
19:04:13 T:1946210304  NOTICE:     Device 3
19:04:13 T:1946210304  NOTICE:         m_deviceName      : Both
19:04:13 T:1946210304  NOTICE:         m_displayName     : HDMI and Analogue
19:04:13 T:1946210304  NOTICE: Enumerated ALSA devices:
19:04:13 T:1946210304  NOTICE:         m_deviceName      : @
19:04:13 T:1946210304  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
19:04:13 T:1946210304  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000
19:04:13 T:1946210304  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
19:04:13 T:1946210304  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
19:04:13 T:1946210304  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="UTF-8" ?>
                                            <advancedsettings>
                                              <video>
                                                <defaultplayer>dvdplayer</defaultplayer>
                                                <defaultdvdplayer>dvdplayer</defaultdvdplayer>
                                              </video>
                                              <gui>
                                                <algorithmdirtyregions>3</algorithmdirtyregions>
                                                <nofliptimeout>0</nofliptimeout>
                                              </gui>
                                              <splash>false</splash>
                                              <lookandfeel>
                                                <enablerssfeeds>false</enablerssfeeds>
                                              </lookandfeel>
                                              <cputempcommand>sed -e &apos;s/\([0-9]*\)[0-9]\{3\}.*/\1 C/&apos; /sys/class/thermal/thermal_zone0/temp</cputempcommand>
                                              <gputempcommand>/opt/vc/bin/vcgencmd measure_temp | sed "s,temp=\([0-9]*\)\.[0-9]&apos;C,\1 C,"</gputempcommand>
                                            </advancedsettings>
19:04:13 T:1946210304  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:04:13 T:1946210304  NOTICE: Default DVD Player: dvdplayer
19:04:13 T:1946210304  NOTICE: Default Video Player: dvdplayer
19:04:13 T:1946210304  NOTICE: Default Audio Player: paplayer
19:04:13 T:1946210304  NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:04:13 T:1946210304  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:04:13 T:1946210304  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:04:13 T:1946210304  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:04:13 T:1946210304  NOTICE: Loaded playercorefactory configuration
19:04:13 T:1946210304  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:04:13 T:1946210304  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:04:13 T:1936716720  NOTICE: Thread ActiveAE start, auto delete: false
19:04:13 T:1926230960  NOTICE: Thread AESink start, auto delete: false
19:04:13 T:1865413552  NOTICE: Thread CRBPWorker start, auto delete: false
19:04:13 T:1946210304  NOTICE: Running database version Addons19
19:04:13 T:1946210304  NOTICE: ADDONS: Using repository repository.xbmc.org
19:04:13 T:1853879216  NOTICE: Thread RemoteControl start, auto delete: false
19:04:14 T:1946210304  NOTICE: Raspberry PI firmware version: Feb 25 2016 14:25:47
19:04:14 T:1946210304  NOTICE: ARM mem: 880MB GPU mem: 128MB MPG2:0 WVC1:0
19:04:14 T:1946210304  NOTICE: Config:
                                            arm_freq=1000
                                            audio_pwm_mode=1
                                            audio_sdm_mod_order=2
                                            config_hdmi_boost=5
                                            core_freq=500
                                            disable_commandline_tags=2
                                            disable_l2cache=1
                                            disable_splash=1
                                            emmc_pll_core=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_ignore_alpha=1
                                            framebuffer_swap=1
                                            hdmi_channel_map=8
                                            hdmi_force_cec_address=65535
                                            hdmi_force_hotplug=1
                                            init_uart_clock=0x2dc6c0
                                            lcd_framerate=60
                                            over_voltage=2
                                            over_voltage_avs=0x1b774
                                            over_voltage_sdram_p=2
Posted: Sat Mar 05, 2016 8:54 pm
by gkreidl
Which version are you running? From the OP or the repository?
How large is your GPU memory?
Posted: Sun Mar 06, 2016 1:27 pm
by typxxi
#1 it starts with the blue bubble background screen but no menus.
#2 After a few seconds the screen is black, access only by ssh or remote desktop.
#3 I have noops (Dec 2015) and installed raspbian, later booted OpenElec a few times, but my problems mentioned above occured under raspbian and the OP Installation,
but I had started with the files from Michael (http://michael.gorven.za.net) before I switched in January to the OP Version.
#4 I did all the update and upgrade stuff, use Realtek WiFi, samba, proftp, ...
gkreidl wrote:Which version are you running?
As mentioned your OP Version (Jessie)
gkreidl wrote:From the OP or the repository?
OP "Steinerdatenbank"
gkreidl wrote:How large is your GPU memory?
160MB as recommended
Posted: Sun Mar 06, 2016 1:55 pm
by gkreidl
Try removing it and reinstalling.
Posted: Sun Mar 06, 2016 8:59 pm
by stickperson
I still can't seem to get kodi to autostart on boot. I'm running Raspbian Jessie and followed the instructions in the OP. I didn't have an /etc/default/kodi file, so I created it and added ENABLED=1 to it. This didn't do anything, though, probably because I don't have an /etc/init.d/kodi file. I also tried the steps here: http://kodi.wiki/view/HOW-TO:Autostart_ ... nit_script making sure all the paths were correct, but that didn't work either.
Any ideas?
Posted: Mon Mar 07, 2016 6:22 am
by gkreidl
stickperson wrote:I still can't seem to get kodi to autostart on boot. I'm running Raspbian Jessie and followed the instructions in the OP. I didn't have an /etc/default/kodi file, so I created it and added ENABLED=1 to it. This didn't do anything, though, probably because I don't have an /etc/init.d/kodi file. I also tried the steps here: http://kodi.wiki/view/HOW-TO:Autostart_ ... nit_script making sure all the paths were correct, but that didn't work either.
Any ideas?
No I never tried it and I really don't understand why anyone wants to do that. For me a kodi installation on Raspbian only makes sense, if I can use it as a program like any other one.
I would use OpenElec for a system that boots directly into kodi.
Posted: Mon Mar 07, 2016 9:11 am
by futant
@stickperson
If you install the stock Raspbian Kodi or Pipplware 16 Kodi you can get the autostart working without any additional hassle (all the required scripts & user account creation are in the debian packages). Just edit /etc/default/kodi and set your system to boot into console with raspi-config. That's how I have my system set up.
Any ideas?
Posted: Mon Mar 07, 2016 5:29 pm
by typxxi
gkreidl wrote:Try removing it and reinstalling.
Yes, I will do this and try to create a documentation and Backup after each - major - step.
One question regarding the OP and these 15.2 Jessie configuration:
CFLAGS="-I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -mfloat-abi=hard -mcpu=cortex-a7 -mfpu=neon-vfpv4" CXXFLAGS="-I/opt/vc/include/ -I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux -mfloat-abi=hard -mcpu=cortex-a7 -mfpu=neon-vfpv4" LDFLAGS="-L/opt/vc/lib" FFMPEG_OPTS="--cpu=cortex-a7" ./configure --prefix=/usr --disable-debug --enable-optimizations --with-platform=raspberry-pi --enable-player=omxplayer --disable-x11 --disable-sdl --disable-vaapi --disable-vdpau --disable-xrandr --disable-joystick --enable-airplay --enable-mid --enable-rsxs --enable-afpclient --disable-external-ffmpeg --enable-non-free --enable-dvdcss --enable-ccache --enable-alsa --enable-libusb --enable-libbluray --enable-libcec --disable-projectm --disable-pulse
What do I have to do with these lines?
Thanks a lot.
Posted: Mon Mar 07, 2016 6:43 pm
by gkreidl
typxxi wrote: One question regarding the OP and these 15.2 Jessie configuration:
Thanks a lot.
Nothing. Those were the compiler and configuration options used for building the package.
Posted: Mon Mar 07, 2016 7:38 pm
by typxxi
gkreidl wrote: Nothing. Those were the compiler and configuration options used for building the package.
GOTT sei Dank - new installation is still running and updating from the scratch (NOOB 1.8).
Posted: Tue Mar 08, 2016 12:02 pm
by Jsnow0187
Seems to work well apart from a few bugs. I am usingthe pipplware repo, and o get a black screen when i tey to change the resolution from desktop. Also exit does not work. I tried the scripts but was unabe to it working.
Anyone have fixes for these bugs?
