rasplumino
Re: Kodi 15 Packages for Raspbian Wheezy & Jessie for RPi2
Sat Nov 07, 2015 5:47 pm
I´ve installed Kodi 14.1 via archive.mene.za.net Repo.
How can I update to your 15.2 Version for Jessie?
I have a Raspberry Model B.
gkreidl
Sat Nov 07, 2015 6:36 pm
You cannot, RPI2 only,
But 15.1 is in the Foundation respository.
Minimal Kiosk Browser (kweb)
rasplumino
Sat Nov 07, 2015 7:01 pm
ok - you wrote:
It is not optimized for RPi2 and will work with any RPi model.
So i thought it works on RPi B too.
I can update to 15.1 if I add "http://archive.raspberrypi.org/debian jessie main" to sources.list?
Chateaudur
Sat Nov 07, 2015 7:24 pm
Hi everyone,
Just installed Jessie from scratch and installed Kodi 15.1 from the repo (apt-get install kodi).
I have the black screen problem when I quit. The Amber skin also does not load properly, I dont have the skin under the buttons and I found it slower than OP's version on Wheezy.
Does anyone think this version is still not ready to be used on top of Raspbian?
Any recommendations?
I'm not sure how to uninstall it either, should i just delete the Kodi folder, is that enough? Maybe I should try OP's version instead which worked great on my former Wheezy install.
Edit: I've uninstalled it using the apt remove cmd, but it seems my setting and skins are still installed and OP's version finds them. How can I start from scratch again?
Thanks for the help!! :)
davboc
Sat Nov 07, 2015 9:13 pm
I have jessie version of raspbian, I can update kodi to the latest version following the firs post instructions and without lose settings and addon that now I have installed in the kodi 14?
Thanks mate
gkreidl
Sun Nov 08, 2015 5:31 am
davboc wrote:I have jessie version of raspbian, I can update kodi to the latest version following the firs post instructions and without lose settings and addon that now I have installed in the kodi 14?
Thanks mate
Yes.
davboc
Sun Nov 08, 2015 1:53 pm
Thanks mate
Yes.
I really appreciate your help mate, updated kodi all works well, except for no-audio at the start, but I've solved removing guisettings.xml and restore all the settings. Now also youtube plugin back to works. Thanks again!
pattaboy
Tue Nov 10, 2015 4:48 pm
I wanted to install from a clean jessie install but it fails right after I try to install kodi 15.2 RC3...
can someone help me?
also I cannot install libcec3.. because the package is not found in the repository.
This is what I see:
  • pi@retropie ~ $ wget http://steinerdatenbank.de/software/kod ... sie.tar.gz
    --2015-11-10 16:39:24-- http://steinerdatenbank.de/software/kod ... sie.tar.gz
    Resolving steinerdatenbank.de (steinerdatenbank.de)... 85.25.144.201
    Connecting to steinerdatenbank.de (steinerdatenbank.de)|85.25.144.201|:80... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 21180127 (20M) [application/octet-stream]
    Saving to: `kodi-15-jessie.tar.gz'
    100%[======================================>] 21,180,127 1.80M/s in 11s
    2015-11-10 16:39:36 (1.77 MB/s) - `kodi-15-jessie.tar.gz' saved [21180127/21180127]
    pi@retropie ~ $ tar -xzf kodi-15-jessie.tar.gz
    pi@retropie ~ $ cd kodi-15-jessie
    pi@retropie ~/kodi-15-jessie $ sudo ./install
    Reading package lists... Done
    Building dependency tree
    The following packages were automatically installed and are no longer required:
    libcap-ng0 libdbus-glib-1-2 python-dbus python-dbus-dev
    Use 'apt-get autoremove' to remove them.
    The following extra packages will be installed:
    iso-codes lsb-release python-apt python-apt-common python-chardet
    python-debian
    Suggested packages:
    isoquery lsb python-apt-dbg python-gtk2 python-vte python-apt-doc
    The following NEW packages will be installed:
    gdebi-core iso-codes lsb-release python-apt python-apt-common python-chardet
    python-debian
    0 upgraded, 7 newly installed, 0 to remove and 15 not upgraded.
    Need to get 2,914 kB of archives.
    After this operation, 19.3 MB of additional disk space will be used.
    Get:1 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python-apt-common all 0.8.8.2 [115 kB]
    Get:2 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python-apt armhf 0.8.8.2 [289 kB]
    Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python-chardet all 2.0.1-2 [177 kB]
    Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main python-debian all 0.1.21 [61.3 kB]
    Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main gdebi-core all 0.8.7 [177 kB]
    Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main iso-codes all 3.41-1 [2,068 kB]
    Get:7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main lsb-release all 4.1+Debian8+rpi1+deb7u1 [26.8 kB]
    Fetched 2,914 kB in 1s (1,478 kB/s)
    Selecting previously unselected package python-apt-common.
    (Reading database ... 54597 files and directories currently installed.)
    Unpacking python-apt-common (from .../python-apt-common_0.8.8.2_all.deb) ...
    Selecting previously unselected package python-apt.
    Unpacking python-apt (from .../python-apt_0.8.8.2_armhf.deb) ...
    Selecting previously unselected package python-chardet.
    Unpacking python-chardet (from .../python-chardet_2.0.1-2_all.deb) ...
    Selecting previously unselected package python-debian.
    Unpacking python-debian (from .../python-debian_0.1.21_all.deb) ...
    Selecting previously unselected package gdebi-core.
    Unpacking gdebi-core (from .../gdebi-core_0.8.7_all.deb) ...
    Selecting previously unselected package iso-codes.
    Unpacking iso-codes (from .../iso-codes_3.41-1_all.deb) ...
    Selecting previously unselected package lsb-release.
    Unpacking lsb-release (from .../lsb-release_4.1+Debian8+rpi1+deb7u1_all.deb) ...
    Processing triggers for man-db ...
    Setting up python-apt-common (0.8.8.2) ...
    Setting up python-apt (0.8.8.2) ...
    Setting up python-chardet (2.0.1-2) ...
    Setting up python-debian (0.1.21) ...
    Setting up gdebi-core (0.8.7) ...
    Setting up iso-codes (3.41-1) ...
    Setting up lsb-release (4.1+Debian8+rpi1+deb7u1) ...
    Building data structures... Done
    This package is uninstallable
    Dependency is not satisfiable: libgcrypt20
    Selecting previously unselected package libplatform1.
    (Reading database ... 55484 files and directories currently installed.)
    Unpacking libplatform1 (from libplatform1_1.0.9-1_armhf.deb) ...
    Setting up libplatform1 (1.0.9-1) ...
Tue Nov 10, 2015 5:18 pm
pattaboy wrote:I wanted to install from a clean jessie install but it fails right after I try to install kodi 15.2 RC3...
At present 15.1 is now available from the Jessie apt-get repository ;)
Retired disgracefully.....
gkreidl
Tue Nov 10, 2015 5:44 pm
This looks like Wheezy, not Jessie (from the messages).
franz159
Thu Nov 12, 2015 2:01 am
I tried the installation described above but it failed with this error:
root@jessie-rpi:/kodi-15-jessie# ./install
Dependency is not satisfiable: libudev0
Any idea?
I'm completely new to kodi install, so forgive me please!
gkreidl
Thu Nov 12, 2015 12:57 pm
Run
sudo apt-get update
and try again.
libudev0 is definitely in the repository, but the version may have changed.
Micha1982
Fri Nov 13, 2015 5:45 am
Is it possible, that the repos-version has the exit-bug (blackscreen) again?
However, actually I managed to get gkreidl's version running again (after I found out that the gui-tool to change the gpu-mem did not change the ram, caused by 2(/4) entries (?!) in the configfile ...) - but I got a question: If I do apt-get dist-upgrade, it shows me some Kodi-files....can I install them (gkreidl's version!!) - or will it cause problems?
Alles, was schiefgehen kann, wird auch schiefgehen.
gkreidl
Fri Nov 13, 2015 6:54 am
Micha1982 wrote:Is it possible, that the repos-version has the exit-bug (blackscreen) again?
My version has problems with dist-upgrade. For some reason that I do not understand, the repository version takes precedence, although my version is newer. this does only happen with kodi (I have a few more of newer packages on my system)
Fortunately dist-upgrade is not required normally. If it is really needed, uninstall my version first and install it again afterwards.
Micha1982
Fri Nov 13, 2015 7:37 am
Ok. Hopefully there will be a good/working and actual repos-version soon......
torbenp
Sat Nov 14, 2015 8:15 pm
Trying to show DVD menus over SAMBA either using ISO or from extracted folder doesn't work for me. Here's the log:
13:27:28 T:1792046112 NOTICE: Thread BackgroundLoader start, auto delete: false
13:27:42 T:1950167824 NOTICE: Previous line repeats 2 times.
13:27:42 T:1950167824 NOTICE: DVDPlayer: Opening: smb://<...>/mydvd/VIDEO_TS/VIDEO_TS.IFO
13:27:42 T:1950167824 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:27:42 T:1792046112 NOTICE: Thread DVDPlayer start, auto delete: false
13:27:42 T:1792046112 NOTICE: Creating InputStream
However, if I select directly a VTS file it will play without problems.
dick.heijkoop
Sat Nov 21, 2015 3:19 pm
Hello Mr. Kreidl,
Wunderbar, vielen, vielen dank!! for this tutorial.
I gave it a second try on Jessy this morning (after trying it a few weeks ago for the first time) based on your new available download and instructions for Jessy. Followed it step by step, now it works fine, except for an issue or two. Much appreciated!
I have an issue though with airplay (freezing Kodi), but that's not important and - more important - I cannot play DVD movies (with VIDEO_TS and AUDIO_TS folder structure), while mkv and mp4 are doing fine. Looks like an issue in Kodi; anyone any idea how this can be solved? Thanks!
Kind regards,
Dick
gkreidl
Sun Nov 22, 2015 6:20 am
DVDs need libdvdcss which is missing in Raspbian (for legal reasons, I suppose). You have to compile it from source.
dick.heijkoop
Mon Nov 23, 2015 12:16 pm
OK Thanks. I am afraid that compiling whatever is a bit away of my competence.. Any instructions what to do exactly somewhere available? thx. Dick
gkreidl
Mon Nov 23, 2015 1:40 pm
dick.heijkoop wrote:OK Thanks. I am afraid that compiling whatever is a bit away of my competence.. Any instructions what to do exactly somewhere available? thx. Dick
Here it is
dick.heijkoop
Tue Nov 24, 2015 3:50 pm
Thanks!. Downloaded it and installed it with dpkg. What should I do next? Thanks. Dick
gkreidl
Tue Nov 24, 2015 4:29 pm
dick.heijkoop wrote:Thanks!. Downloaded it and installed it with dpkg. What should I do next? Thanks. Dick
Test if DVDs are working now.
lotte67890
Wed Nov 25, 2015 10:23 pm
For all of you having the problem that after installing Kodi your screen only shows black, http://elinux.org/RPi_Resize_Flash_Part ... spberry_Pi did the trick for me. Simply my root filesystem was full (fresh install 2015-11-21-raspbian-jessie). I could log into the pi immediately after booting (do not wait to long) followed the instruction and all went fine. Hint: There seems to be no swap partition (partition 3) as described in the article in the new(er) releases of Raspbian, so no need to delete it and be aware that the start of the new partition matches exactly the start of the old partition!
Regards
L
yussuf.islam
Tue Dec 01, 2015 6:39 pm
Hi everyone.
Is anyone having problems finding libcec3 in the repositories? When I use apt-get it says it was unable to locate the package.
I'm on raspbian 8, up to date, with original repos in sources.list.
Thanks.
Return to “Raspbian”
