windows PI emulator
Posted: Mon Jun 25, 2012 4:47 pm
by secretreeve
anyone got a emulator for the PI that works on windows?
i'd like to test my SD card setup prior to putting it in my Pi when it arrives and have a play around with whats in the debian build
Re: windows PI emulator
Posted: Mon Jun 25, 2012 5:01 pm
by DuncanKennedy
QEMU is your best choice - there are a number of threads on the topic which will walk you through the install and configuration process. When set up properly, QEMU will boot directly from an .img file on disk (the ones from the download page work fine), but will not boot from a USB directly (although there is nothing to keep you from using your .img file after you get everything set the way you want to create a bootable SD card for when your Pi arrives)
Posted: Mon Jun 25, 2012 8:14 pm
by secretreeve
can someone please explain in simple terms how to get qemu to boot the debian img i have please?
fyi qemu.exe is coming back as not a command (within qemu)
and if i right click the debian image and select qemu.exe it just halts on "booting from hdd"
oh and (3rd edit lol) this is on windows 7 HP
Posted: Mon Jun 25, 2012 8:21 pm
by DuncanKennedy
Rather than rehash this, I'd suggest you search for the topic 'Emulating Raspberry Pi in Windows the easy way' This includes downloads, instructions and comments and questions from users at a variety of levels. Following the info there you shouldn't have any trouble getting it to work.
Posted: Mon Jun 25, 2012 8:22 pm
by secretreeve
DuncanKennedy wrote:Rather than rehash this, I'd suggest you search for the topic 'Emulating Raspberry Pi in Windows the easy way' This includes downloads, instructions and comments and questions from users at a variety of levels. Following the info there you shouldn't have any trouble getting it to work.
tried that but didnt really understand/manage to follow it because of being unsure of the debian img.
i'll try it again anyways
Posted: Tue Jun 26, 2012 2:00 pm
by DuncanKennedy
The Debian image is the one available from the RPi Foundations download page - you can also use the Arch image available there as well. Download it to your windows system (I.e. to a file Debian.img) then make sure that when you have everything else set up the way the instructions tell you to, that you Qemu command line references the file you downloaded (again, for example Debian.img).
Good luck!
