daemonsh
Command line start script
Thu Oct 09, 2014 10:54 pm
Hello, I need some help about Console boot.
I want to run my python script "start.py" at boot on foreground. but I didnt make it. how can I run this script at boot (but it must be run on foreground, not background)
elatllat
Re: Command line start script
Fri Oct 10, 2014 12:02 am
You can run something in the foreground on login by adding it to .bashrc or the like.
If you really want it prelogin you need to manually attach to the display.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
