deonwessels
raspbian to replace openelec
Wed Oct 08, 2014 11:52 pm
I am still a total noob with raspberry pi's. I want to replace openelec with raspian - I have downloaded noobs and saved onto the sd card. The Pi does not connect to the screen when I power up with the sd card in place..Any suggestions would be appreciated, thank you.
elatllat
Re: raspbian to replace openelec
Thu Oct 09, 2014 4:15 am
what are your lights doing?
http://elinux.org/R-Pi_Troubleshooting
If you just want raspbian there is no need for noobs
how did you put the img on the card?
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
deonwessels
Thu Oct 09, 2014 4:52 am
I initially installed openelec, which worked ok. I then copied and pasted raspian onto the sd card.( used the noobs download for that.) any suggestion where I should get Raspian from?
The red and green lights turn on but my display doesn't.
Many thanks.
Thu Oct 09, 2014 5:31 am
deonwessels wrote:I initially installed openelec, which worked ok. I then copied and pasted raspian onto the sd card.( used the noobs download for that.) any suggestion where I should get Raspian from?
Many thanks.
Read the sticky: http://www.raspberrypi.org/forums/viewt ... 28&t=58151
Though it is likely you have not created the SD Card correctly: http://www.raspberrypi.org/help/noobs-setup
Retired disgracefully.....
deonwessels
Thu Oct 09, 2014 7:41 am
Thanks very much for the suggestions - I tried reformatting the the sd card with FULL OVERWRITE and it is all systems go . :-)
