eysi
What usb hub would I need?
Tue Oct 07, 2014 4:20 am
Hi guys! I am confused if I would need a powered usb hub or not because currently I have a Raspberry Pi Model B,I am planning to connect a canon printer, an Edimax EW-7811U,keyboard,mouse?
Thanks!!
elatllat
Re: What usb hub would I need?
Tue Oct 07, 2014 5:48 am
Get a powered usb hub and isolate it so you can plug in anything without worrying about it.
If you want to avoid a powered hub look up how much wattage your devices pull... or you know just try it.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
eysi
Wed Oct 08, 2014 4:32 pm
I bought a powered hub but when I plugged it into the RPI it booted without the power supply but its full of error :'( so what I did is that I plugged the Micro usb and the hub, would it backfeed?
pluggy
Wed Oct 08, 2014 4:46 pm
Cheap hubs will back feed power with a Pi B, yes. You can stop it it doing this several ways, or you can live with it, its not usually a problem in my experience.
