richard_robust
No composite video on new B+?
Thu Sep 11, 2014 1:42 pm
What did they do ??? The program works , but now raspberry change the layout and the tulip connection so we dont have a analog connection any more : :shock: (WHAAAAAAA going nuts )
That is a real bummer , what do we do now ? ... I have to wait untill week 50 (element14) to get the old 512 mb back ... that is a ramp !!!
What do we got to do now ... this is realy a problem , we dont have a need of 4 usb's but we do have need of that analoge signal ...
Orderd 45 pieces all can go into the garbage now ... or is there a sollution ? without big extra stuff to change the rgb into 0100011100 ... :roll:
the story contiguous ..
BR
Richard
scotty101
Re: what is loose with that new Raspberry 512+
Thu Sep 11, 2014 1:50 pm
Next to no idea what you are talking about!!
What analog connection are you talking about?
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
RaTTuS
http://www.raspberrypi.org/forums/viewt ... 63&t=81736
please learn how to type when ranting - it makes it easier
need more CAPS ;)
Covfefe
redhawk
Thu Sep 11, 2014 1:53 pm
analoge signal
Are you referring to the Composite video port??The B+ has moved video signal to the headphone jack as part of the non-standardised 4 pole 3.5mm thingy.
If you have an Apple compatible 3.5mm video cable then extracting the video shouldn't be a problem else you could always hax0r the circuit board to fit a RCA connector.
Richard S.
Thu Sep 11, 2014 2:37 pm
richard_robust wrote:so we dont have a analog connection any more
:roll: :roll: http://www.raspberrypi-spy.co.uk/2014/0 ... video-jack
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
richard_robust
Thu Sep 11, 2014 2:59 pm
Thx mate , I know I 'm a bit lazzy at the moment , it is like the whole world collapse in 1 second when opening the box ..
Yes Redhawk , that is the one , but it is still there I just found out thanks of you guys.
Just have to find the right cables , or focus on the HDMI cable and buy a TFTscreen with HDMI connection. That will work.
Just have experience an other problem regarding SD card I try to install our image on the new mini SDcard but it says "the SD card is not Big enough ? :o
How is that possible a cloned image from a SD card (8GIG) Doesnt fit on a miniSD card (8GIG) ... Maybe time for a vacation now ...
:roll:
BMS Doug
Thu Sep 11, 2014 3:02 pm
richard_robust wrote:What did they do ??? The program works , but now raspberry change the layout and the tulip connection so we dont have a analog connection any more : :shock: (WHAAAAAAA going nuts )
Orderd 45 pieces all can go into the garbage now ... damn or is there a sollution ? without big extra stuff to change the rgb into 0100011100 ... :roll:
BR
Richard
Hi Richard,
as others have hinted the B+ does have a composite video output, it is included in the 3.5mm Jack connection. This is still compatible with the monitors you mentioned using previously.
Doug.
Building Management Systems Engineer.
Philip42
STOP RANTING AT THE WRONG PERSON !
Thu Sep 11, 2014 3:17 pm
Why are you not ranting at whoever placed the order AND ORDERED THE WRONG PART !!!
The B+ does not REPLACE the B, which is still available !
As has been said, the B+ has not 'lost' any audio or video connectors - they're just presented differently; and it's all fully documented - if you bother to look !
I'm now awaiting your next post, when you complain that the existing image files for various OS releases no longer work !
In anticipation of this, I suggest you READ THE FAQs about the B+ CAREFULLY, BEFORE POSTING !!!
RaTTuS
Thu Sep 11, 2014 3:22 pm
richard_robust wrote:...
:roll:
not all sd cards are the same [in fact it's likely that any 2 are not the same size]
if you have not used the entire space you may be OK with a quick e2fsck
personally
I'll build a fresh image from raspbian and add the things you need
or backup via rsync [my personal favourite]
Covfefe
abishur
Re: No composite video on new B+?
Thu Sep 11, 2014 3:39 pm
Mod edit: Changed thread title to accurate description of the problem
On the SD card issue, like RaTTus said, no two cards are made alike, but a common problem is some manufactures define a Gig in base 10 or base 2, that is, is a gigabyte 1000*(10^3) bites, for base 10, or is it 1024*(10^3) bites, for base 2. Many (most?) use the base 10 because then they can claim a larger capacity for less space, some choose to be honest and use base 2.
Regardless, starting with a fresh image might be in your best interest no matter what. The B+ requires updated boot files that the new images contain. You can update the boot files with an rpi-update, or doing a distro update (sudo apt-get upgrade for raspbian I believe)
Dear forum: Play nice ;-)
W. H. Heydt
Thu Sep 11, 2014 4:21 pm
abishur wrote:Mod edit: Changed thread title to accurate description of the problem
Or, of course, if you stick to one manufacturer, you'll probably see some consistency.
plugwash
Thu Sep 11, 2014 4:57 pm
richard_robust wrote: Just have experience an other problem regarding SD card I try to install our image on the new mini SDcard but it says "the SD card is not Big enough ? :o
Because unfortunately not all "8GB" cards are exactly the same size.
Theres a few ways arround this but i'm not aware of any that are easy enough to reccomend to a novice.
Jessie
Thu Sep 11, 2014 5:44 pm
http://softwarebakery.com/shrinking-images-on-linux
Edit: Also camcorder cables are often cheaper than ipod cables and all you need to do is swap the red and yellow connectors at the TV. The ground is in the proper location.
richard_robust
Fri Sep 12, 2014 7:24 am
Thank you abishur for this very useful info , didn't knew that. I will figure it out, and maybe just start a new image clean one and put everything manualy like you sugested.
I will search and find now , you guys are right , had to read the Faq first but whooowie I didn't expected those changes (I'm still a believer in this nice piece of fine technology)
Also good to see that the "old ones " are still around on this forum 'HI DOUGH' :) you guys helped me a lot a few month's ago A VERY VERY BIG THANKS to you all !! nowww must find the dude that made TFT with Touchscreens here somewhere on the forum 8-) .
Fri Sep 12, 2014 7:29 am
Also good to see that the "old ones " are still around on this forum 'HI DOUGH' [SIC] :) you guys helped me a lot a few month's ago A VERY VERY BIG THANKS to you all !! nowww must find the dude that made TFT with Touchscreens here somewhere on the forum 8-) .
Everyone of us called "Doug" (or variants of that name) loves the way speeling chuckers on phones rename us to "Dough".
Texy's the man with the TFT screens
http://www.raspberrypi.org/forums/viewt ... 93&t=65566
Notro is the man with the fbtft code for driving all sorts of TFT screens.
https://github.com/notro/fbtft
This is a doctor free zone.
BMS Doug
Fri Sep 12, 2014 7:45 am
So very true Dougie, so very true.
Of course as a result I have truly grown to enjoy sharing Doughnuts around the office....
Doug.
BMS Doug
Fri Sep 12, 2014 8:07 am
richard_robust wrote: nowww must find the dude that made TFT with Touchscreens here somewhere on the forum 8-) .
You know that you can still connect the B+ to your monitors?
It still has the composite output, it's just that it has been included into the 3.5mm socket, see abishur's comprehensive description from the Pictorial buying guide
mahjongg wrote: If you have a model B+ and want to use the composite Video (A/V) for composite video and analog sound, you need an A/V cable, like this one:
But note that there are many cables that look exactly like this one but do NOT work! That is because the wiring within them must be correct!
This is a picture listing the most common A/V cables, and their wiring:
The Raspberry PI can use cables designed for the Ipod, or for the Microsoft Zune, but can also work with some "camcorder cables" (but see below)
The PI does not work with the "hodgepodge" of systems that have pin 1 as GND.
As in the picture above, the tables below count, from sleeve (1) to tip (4) of the four pole 3.5mm jack plug.
A real "Raspberry PI model B+" 4-pole 3.5mm A/V output jack cable uses:
B+ wired cable
1 Video out
2 GND
3 Right audio
4 Left audio
Only Zune Cables are exactly right, because the PI want to keep left and right audio in the right place, and for some obscure reason iPod cables have those swapped.
The most common, and reasonably compatible, cable that is on the market now, uses the iPod wiring:
Ipod wired cable
1 Video out
2 GND
3 Left audio
4 Right audio
Note that you can make this cable 100% compatible by switching the two audio channels, that is the white and red RCA plugs. Its possible that in future software releases, when the system detects you are using a B+ with composite video, the software will swap the audio channels automatically.
A common cable that is also on the market now and often very cheap, is normally called a "camcorder cable"
Camcorder cable
1 Right audio
2 GND
3 Video out
4 Left audio
Note that you can use this cable by switching the video and right channels, that is the yellow and red RCA plugs.
When using a "camcorder" cable, try plugging in the red RCA plug of the cable into the yellow RCA receptacle of your TV and see if you get a picture, if so you can put the yellow plug in the red receptacle, and the white plug into the white receptacle.
Note that no cable you try to use should be able to damage your PI, so you can safely just try.
The cheap ($1.99) cable below is a camcorder cable, and has been tested and is reported to work (with the "camcorder RCA swap").
http://www.amazon.com/Fosmon-Technology ... B00HND2FW8
The iPod compatible cable below has also been confirmed to work, is more expensive but does not require the camcorder swap.
http://www.amazon.com/gp/product/B004UCU72U/
Note that instead of such an A/V cable, you could also use an adapter like this. Note that the same reservations as for the cables apply, it might not work, or the signals come out of the wrong plugs. Also, normally its more of a hassle to use and more expensive, but you might have one lying around you can try:
Doug.
jojopi
Sat Sep 13, 2014 2:38 am
abishur wrote:On the SD card issue, like RaTTus said, no two cards are made alike, but a common problem is some manufactures define a Gig in base 10 or base 2, that is, is a gigabyte 1000*(10^3) bites, for base 10, or is it 1024*(10^3) bites, for base 2. Many (most?) use the base 10 because then they can claim a larger capacity for less space, some choose to be honest and use base 2.
They all use decimal prefixes. Nobody ever markets an 8GB card as "7.4GiB".
The card controller needs to reserve a significant chunk of the actual flash storage for translation layer, wear levelling, bad block reallocation, and error correction.
richard_robust
Sun Sep 14, 2014 1:14 pm
abishur wrote: If you have a model B+ and want to use the composite Video (A/V) for composite video and analog sound, you need an A/V cable, like this one:
B+ wired cable
1 Video out
2 GND
3 Right audio
4 Left audio
Ipod wired cable
1 Video out
2 GND
3 Left audio
4 Right audio
Camcorder cable
1 Right audio
2 GND
3 Video out
4 Left audio
Thank you bmsdough for this fine information , with this we can figuring it out!
Br
Richard
richard_robust
Sun Sep 14, 2014 1:26 pm
[quote="jojopi"][quote="abishur"]On the SD card issue, like RaTTus said, no two cards are made alike, but a common problem is some manufactures define a Gig in base 10 or base 2, that is, is a gigabyte 1000*(10^3) bites, for base 10, or is it 1024*(10^3) bites, for base 2. Many (most?) use the base 10 because then they can claim a larger capacity for less space, some choose to be honest and use base 2.[/quote]They all use decimal prefixes. Nobody ever markets an 8GB card as "7.4GiB".
The card controller needs to reserve a significant chunk of the actual flash storage for translation layer, wear levelling, bad block reallocation, and error correction.[/quote]
That I totaly understand.. But if you look at the sd image, there is only 2.5 gig all the rest is unalocated space so as i understand it is just empty space, right . So isn't possible to get rit of the ghost space so i can get my freaking image back on a sd? I tried win32 thingy doesn't work. Try a script on this forum to schrink it. Doesnt work. I workt on the image a long time now it is finished and ready to stress test the wole thing changed. But that is not the real problem. It is the SD card size what is freaking me off. Also tried gparted can see it but unable to schrink it, anybody got a sollution for this one? :(
BR
Gino
plugwash
Sun Sep 14, 2014 1:31 pm
If you are sure there are no partitions beyond the end of the new card then you can write the image with dd (it will complain when it reaches the end of the card but it will have written everything before the card end successully).
klricks
Sun Sep 14, 2014 1:38 pm
BR
Gino
Your current question has drifted far away from the original topic. You might want to Google this forum and read the many threads already covering shrinking SD images, then if you still problems make a new thread.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
richard_robust
Tue Sep 16, 2014 12:30 pm
B+ wired cable
1 Video out
2 GND
3 Right audio
4 Left audio
Ipod wired cable
1 Video out
2 GND
3 Left audio
4 Right audio
Camcorder cable
1 Right audio
2 GND
3 Video out
4 Left audio
Br
Richard
This one comes in very handy now , when experiencing the HDMI and new jack problem
10x
BR
Richard
BMS Doug
Tue Sep 16, 2014 3:36 pm
richard_robust wrote: This one comes in very handy now , when experiencing the HDMI and new jack problem
10x
BR
Richard
Glad to have been of assistance but all the hard work was done by abishur mahjongg.
Doug.
mahjongg
Tue Sep 16, 2014 3:47 pm
10x
BR
Richard
Glad to have been of assistance but all the hard work was done by abishur.
Actually he only did a small starter, I expanded and updated it since then, for example, anything about the B+ I did.
