kelvinmead
Re: Mjpg-Streamer
Fri Feb 15, 2013 1:57 am
In the lxterminal
And that sounds like the stupidly simple idea, but most obvious idea ever.
Ill try that!
kelvinmead
Re: Mjpg-Streamer
Fri Feb 15, 2013 11:34 am
thanks, that worked.
SirLagz
Re: Mjpg-Streamer
Sat Feb 16, 2013 7:37 am
You're Welcome :)
raspBarryPi
Re: Mjpg-Streamer
Sun Feb 17, 2013 6:59 pm
followed this tutorial http://sirlagz.net/2012/08/04/how-to-st ... pberry-pi/ and it works fine! :D
For those struggling with viewing the stream:
You can't open http://10.0.0.10/webcam.mjpeg directly (at least i can't)
Had to install a webserver and embed the stream like this:
<object id="MediaPlayer">
<param name="FileName" value="MyStream.mjpg">
<param name="AutoStart" value="True">
<param name="ShowControls" value="True">
<embed src="http://10.0.0.10/webcam.mjpeg" type="video/mpeg" debug="true">
</embed>
</object>
Works on Firefox, Chrome, Sarafi, Opera. But not on IE (because IE does not support mjpeg)
When you get "bind(port 80): Address already in use" run this:
pkill -e ffserver
It kills the running ffserver process, so you can safely start it again!
I have just one problem.
How can i make webcam.sh run at system boot?
I would like the webcam to start streaming automatically, right after Raspberry is connected to the power supply.
Tried messing with symlinks in /etc/init.d and crontab, but it didn't work.
Ideas anyone?
SirLagz
Re: Mjpg-Streamer
Mon Feb 18, 2013 12:10 am
Glad the tutorial helped :)
In Rasbpian -
If you want webcam.sh to start automatically, copy one of the existing /etc/init.d/ scripts to /etc/init.d/webcam.sh, modify the internals to what you need it to do, and then run
update-rc.d webcam start defaults
<-- I think that's the command.
That will update the things needed.
danjperron
Re: Mjpg-Streamer
Mon Feb 18, 2013 2:08 am
Since I complete my system to control the heat of my pond and it has a web cam using mjpg_streamer.
I decide to capture one image every minute and create a small video.
I use wget application to stream one image and transfer it to a tmpfs folder. I don't like to write to the sdcard too often. Then I transfer the capture image via FTP to an external location (My cloud WD disk).
So this is my original streamer script. It is call at startup in /etc/rc.local .
script streamer1080p.sh
killall mjpg_streamer
/usr/local/bin/mjpg_streamer -i "/usr/local/lib/input_uvc.so -n -f 10 -r 1920x1080" -o "/usr/local/lib/output_http.so -p 10088 -w /usr/local/www" &
This is the python script to capture one image and transfer it via FTP
#!/usr/bin/python
import time
import os
import sys
import re
import subprocess
import datetime
now = datetime.datetime.now()
# capture image
SnapImage = "/var/www/chart/data/image.jpg"
subprocess.call(["/usr/bin/wget","-O",SnapImage,"http://127.0.0.1:10088/?action=snapshot"])
# create a stamp image file
StampImage = "PondImg_" + now.strftime("%Y_%m_%d_%H_%M_%S") + (".jpg")
# transfer image to mycloud WD disk
subprocess.call(["/usr/local/bin/FtpImage.sh",SnapImage,StampImage,"RPi","My8assword"])
This is the bash script to transfer via FTP
#!/bin/bash
IN_LOCAL=$1
OUT_REMOTE=$2
USER=$3
PASSWD=$4
sleep 5
ftp -v -n 10.11.12.4 <<END_OF_SESSION
user $USER $PASSWD
cd /Daniel/PiData/Images
prompt off
binary
put $IN_LOCAL $OUT_REMOTE
bye
END_OF_SESSION
Also if your webcam has auto focus, mine does (logitech C-920), you will need to disable it.
use uvcdyctrl.
uvcdynctrl -c will show you a list of all parameters. Check for Focus or something similar.
uvcdynctrl -s "Focus, Auto" 0
At the last thing is to combine all the images and create this video
http://dl.dropbox.com/u/48891705/TheSunFalling.mp4
be aware it is 1080P. (save the file and play it).
Daniel
danjperron
Re: Mjpg-Streamer
Thu Feb 21, 2013 5:46 pm
From all the images collected from the Snapshot.py script I decide that it could be nice to create a daily movie of it.
First I fix the code of the previous script. (replace subprocess.popen with the call function). I want the wait until the image is captured before sending it to the ftp server.
#!/usr/bin/python
import time
import os
import sys
import re
import subprocess
import datetime
# capture image
subprocess.call(["/usr/local/bin/FtpImage.sh",SnapImage,StampImage,"RPi1","pass8ord"])
And now the script to convert captures images on every minutes from mjpeg_streamer to a mp4 video.
1 - mount images resource. For me is a remote network drive but it could be a USB stick.
2 - create software link with each image sorted in times and with filename using a number scheme.
3 - use avconv converter to create the mp4 video.
4 - Delete the link files.
5 - Delete the jpg files.
6 - Unmount images resource. (if your usb stick is always attach don't do it).
#!/usr/bin/python
import datetime
import os
import sys
import subprocess
import glob
# this routine will create a daily movie
# from the collected jpg images of the previous day
# first it will create link using number order filename
# and then it will use ffmpeg to create a mp4 movie
# some define function
def mkdirp(directory):
    if not os.path.isdir(directory):
        os.makedirs(directory)
# Ok get the date of yesterday
yesterday = datetime.datetime.now() - datetime.timedelta(1)
# since I transfer the jpg to an other computer/or drive
# let's mount the device if it is not mounted
# I'm using a cloud WD network drive  so we will mount it
subprocess.call(["/bin/mount","-t","cifs","-o","user=RPi1,pass=pass8word","//10.11.12.4/Daniel/PiData","/mnt/wd"])
# now let's erase all link from my tmpfs folder
#first create the folder if it is not there
movieLink= "/var/www/chart/data/MovieLink"
mkdirp(movieLink)
#delete all link inside the folder if any
files = glob.glob(movieLink + "/*")
for f in files:
    os.remove(f)
#ok now set  the filename mask
mask= "/mnt/wd/Images/PondImg_"+ yesterday.strftime("%Y_%m_%d_") + "*.jpg"
#ok now creation of the link
counter=1
# python link doesn't work! crossdevice not permitted
# we will use  /bin/ln -s
files = sorted(glob.glob(mask))
for file in files:
   destlink = movieLink + ("/img%04d.jpg" % (counter))
   print "try to link: " + file + "with " + destlink
   subprocess.call(["/bin/ln","-s",file,destlink])
   counter += 1
#and now the main thing
mkdirp("/mnt/wd/DailyMovie")
MovieFile = "/mnt/wd/DailyMovie/Pond_" + yesterday.strftime("%Y_%m_%d") + ".mp4"
subprocess.call(["/usr/bin/avconv","-f","image2","-r","10","-i","/var/www/chart/data/MovieLink/img%04d.jpg","-b","4000k","-r","10","-c:v","mpeg4","-s","1024x576",MovieFile])
#ok done now let's remove the link
filelink = glob.glob(movieLink + "/*")
for f in filelink:
    os.remove(f)
# remove all the jpeg file
for file in files:
    os.remove(file);
#and now let's remove the mount
subprocess.call(["/bin/umount","/mnt/wd"])
Maybe it is a good idea to disable the images files removal until you know that everything is working
And the last thing to do will be to start the script every day using crontab -e . Add the following lines into it
 */1 * *   *   *     /usr/local/bin/Snapshot.py
 0   0 *   *   *     /usr/bin/python /usr/local/bin/DailyMovie.py
This will capture an Image every minute and at midnight every day it will convert all the captured images into a mp4 video. (You could replace the */1 by *. It is just easier to read).
P.S. I changed the resolution of the image capture. I really don't need to be full 1080P.
Daniel
lauraspberryPI
Re: Mjpg-Streamer
Wed Mar 13, 2013 6:09 pm
¿alguien tiene el pluging de rtp o udp para hacer streaming con mjpg-streamer?
skidoobond
Re: Mjpg-Streamer
Thu Mar 28, 2013 7:36 pm
I have also tried these instructions and the various command line changes. I didn't get any make errors or any indication that something is wrong. When I point my pc browser to the pi, firefox says it is unable to connect. I can start and stop motion and the camera's led responds accordingly. It doesn't appear that the mjpg-streamer is doing anything.
cgenco
Re: Mjpg-Streamer
Wed Apr 10, 2013 6:16 am
The problem raised in one of the first posts when installing MJPG-streamer of:
linux/videodev.h: No such file or directory
Is fixed by symlinking it as described in http://stackoverflow.com/questions/5842 ... untu-11-04:
sudo apt-get install libv4l-dev
cd /usr/include/linux
sudo ln -s ../libv4l1-videodev.h videodev.h
leprasmurf
Re: Mjpg-Streamer
Wed Aug 07, 2013 2:08 am
Here's an init script that's working for me. I copied parts of it from the nginx init script.
#!/bin/bash
### BEGIN INIT INFO
# Provides:          mjpg_streamer
# Required-Start:    $network
# Required-Stop:     $network
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description: mjpg_streamer for webcam
# Description:       Stream a video device over http.  http://<ip>:<port>/?action=stream
### END INIT INFO
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin";
DAEMON="/usr/bin/mjpg_streamer";
NAME="mjpg_streamer";
DESC="MJPEG Streamer";
VIDEO_DEV="/dev/video0";
RESOLUTION="640x480";
FRAME_RATE="20";
JPEG_QUALITY="75";
PORT="8080";
WEB_DIR="/var/www/mjpg_streamer";
PID_FILE="/var/run/${NAME}.pid";
TXT_RESET=$(tput sgr0);
TXT_RED=$(tput setaf 1);
TXT_GREEN=$(tput setaf 2);
TXT_YELLOW=$(tput setaf 3);
TXT_BLUE=$(tput setaf 4);
TXT_PURPLE=$(tput setaf 5);
TXT_CYAN=$(tput setaf 6);
TXT_WHITE=$(tput setaf 7);
TXT_BOLD=$(tput bold);
# Include defaults if available
if [ -f /etc/default/mjpg_streamer ];
then
        . /etc/default/mjpg_streamer;
fi
test -x ${DAEMON} || exit 0;
. /lib/lsb/init-functions;
function check_process {
        if [ -f /var/run/mjpg_streamer.pid ];
        then
                PID=`cat ${PID_FILE}`;
        else
                echo -n "${PID_FILE} does not exist";
        fi
        if [ "$( ps -p ${PID} -o comm= )" == "mjpg_streamer" ];
        then
                return 0;
        else
                return 1;
        fi
function start_mjpeg_daemon {
        echo -n "Starting ${DESC}";
        start-stop-daemon --quiet --background --pidfile ${PID_FILE} --make-pidfile --exec ${DAEMON} --start -- -i "/usr/lib/input_uvc.so -d ${VIDEO_DEV} -n -r ${RESOLUTION} -f ${FRAME_RATE} -q ${JPEG_QUALITY}" -o "/usr/lib/output_http.so -p ${PORT} -w ${WEB_DIR}" || true;
        sleep 1;
        # If check_process returns 0, process started successfully
        if check_process;
        then
                echo -e "\t\t[${TXT_GREEN}Done${TXT_RESET}]";
        else
                echo -e "\t\t[${TXT_RED}Failed${TXT_RESET}]";
        fi
function stop_mjpeg_daemon {
        echo -n "Stopping ${DESC}";
        start-stop-daemon --stop --quiet --pidfile ${PID_FILE} || true;
        sleep 1;
        # If check_process returns 1, process stopped successfully
        if check_process;
        then
                exit 1;
        else
        fi
case "${1}" in
        start)
                start_mjpeg_daemon;
        stop)
                stop_mjpeg_daemon;
        restart)
                echo "Restarting ${DESC}: ";
                stop_mjpeg_daemon;
                sleep 1;
                start_mjpeg_daemon;
        status)
                status_of_proc -p ${PID_FILE} "${DAEMON}" mjpg_streamer && exit 0 || exit $?;
                echo "Usage: ${NAME} {start|stop|restart|status}" >&2;
                exit 1;
esac;
exit 0;
masterpete
Re: Mjpg-Streamer
Thu Jan 16, 2014 6:32 am
i ve read the thread and you use uvcdyctrl
How to get this?
Can i disable the LED o my logitech cams?
leopard891
Re: Mjpg-Streamer
Mon Mar 24, 2014 3:41 pm
Can someone makes github repository for capturing video with python? I think it would be worthfull to anyone. or can some one explain step by step how to run code above?
hussain
Mjpg-Streamer
Sat Apr 12, 2014 7:21 am
i am streaming video using MJPG-STREAMER on my pi
and is working very fine
my problem is i want to store streamed video on my pi
sadiqodho
Re: Mjpg-Streamer
Sat Jul 26, 2014 6:11 am
I have installed successfully but there is an error when i try
mjpg_streamer -i "/usr/local/lib/input_uvc.so" -o "/usr/local/lib/output_http.so -w /usr/local/www"
Error:
MJPG Streamer Version: svn rev: 3:172 i: Using V4L2 device.: /dev/video0 i: Desired Resolution: 640 x 480 i: Frames Per Second.: 5 i: Format............: MJPEG Unable to set format: 1196444237 res: 640x480 Init v4L2 failed !! exit fatal i: init_VideoIn failed
any suggestion
danjperron
Re: Mjpg-Streamer
Sat Jul 26, 2014 12:03 pm
What kind of webcam are you using?
Did you check if your webcam is mjpeg compatible?
uvcdynctrl -f
There is another post about mjpeg-streamer http://www.raspberrypi.org/forums/viewt ... 68#p471868
Daniel
sadiqodho
Re: Mjpg-Streamer
Sun Jul 27, 2014 4:44 am
I am using this device
Bus 001 Device 006: ID 041e:4034 Creative Technology, Ltd Webcam Instant
Kindly tell me step by step i am new on linux.
danjperron
Re: Mjpg-Streamer
Mon Jul 28, 2014 12:41 am
The first thing to test is the mjpeg compatibility
First install uvcdynctrl
sudo apt-get install uvcdynctrl
and run it
sudo uvcdynctrl -f
and check if you have MJPG format . If you don't have "MJPG" , it won't work.
pi@raspberrypiRobot:~# sudo uvcdynctrl -f
Listing available frame formats for device video0:
Pixel format: YUYV (YUV 4:2:2 (YUYV); MIME type: video/x-raw-yuv)
  Frame size: 640x480
    Frame rates: 30, 25, 20, 15, 10, 5
Pixel format: MJPG (MJPEG; MIME type: image/jpeg)
  Frame size: 640x480
  Frame size: 1024x576
  Frame size: 1280x960
This will list all the available format with the resolution and frame rate.
Daniel
ranma1988
Re: Mjpg-Streamer
Mon Jul 28, 2014 7:04 am
masterpete wrote: How to get this?
keep it simple: use electrical tape to disable led;)
TheQWERTYCoder
Re: Mjpg-Streamer
Wed Sep 04, 2019 8:00 pm
Just clone the newest version of mjpg-streamer from github (use the one with added raspberry pi support), open the "mjpg-streamer-experimental" folder and run
make -B -i | make install -B -i
, then you can run mjpg-streamer with the command
mjpg_streamer
TheQWERTYCoder
Re: Mjpg-Streamer
Wed Sep 04, 2019 8:05 pm
and run it
sudo uvcdynctrl -f
  Frame size: 640x480
  Frame size: 640x480
Daniel
The Raspberry Pi Camera has built-in hardware support for JPEG, H.264, and MJPEG. You do realize that if OP was going to try MJPEG streaming, they would get a camera with support for MJPEG, right?
danjperron
Re: Mjpg-Streamer
Wed Sep 04, 2019 9:57 pm
@TheQWERTYCoder
You do realize that you comment something I wrote in 2014!
And yes at that time it was for an USB camera. The application mjpegstreamer is for mjpeg usb cam anyway. Why I will use that application with a none mjpeg camera.
B.T.W. Is still the best web cam application for video streaming since the cpu usage is minimal.
