mcc
TP-WN722N
Wed Jun 13, 2012 8:37 pm
After trying an old Philips dongle, which didn't work, I decided to do it properly and bought a TP-WN722N, it should work, it even has a how to. It doesn't and there is nothing wrong with the dongle, I'm using it with a PC to post this message. Are there any USB wifi devices that actually work?
bredman
Re: TP-WN722N
Thu Jun 14, 2012 8:34 am
Lots of WiFi devices work.
There should be no problem with a TP-WN722N, I assume you are using the instructions on http://elinux.org/RPi_Peripherals#Wirel ... ebian_6.29
How do you know that your device is not working fully? How far in the instructions did you get before you saw a problem?
Have you tried it in a network with security disabled? Most people have problems with network security.
Are you using a powered USB hub?
mcc
Re: TP-WN722N
Fri Jun 15, 2012 1:49 pm
Thanks for the reply, any help appreciated. I'm using a belkin powered hub, one from the verified list. That definitely is working. I don't think it is wireless security, debian loads the module, sees the usb device, but doesn't list any device under wlan0. To be honest I have had this problem with linux systems before, their native driver support is pretty bad. The cheat way around it on an X86 system is ndiswrapper.
Anyway I thought I would give ARCH ago, I had it working on an eeepc, the machine I'm using at the moment, which is now Lubuntu. Once I've figured out how to resize an ext4 partition. Oh well.
antiloquax
Re: TP-WN722N
Fri Jul 13, 2012 2:49 pm
I have the same TP-Link dongle. I couldn't get it to work with Arch either. It does work perfectly with the new Puppy Alpha 3 release.No idea why!
mark
xkxx
Re: TP-WN722N
Fri Jul 13, 2012 4:15 pm
According to linuxwireless TP-WN722N requires firmware[1]. Installing the nonfree wireless driver package should solve this problem. The puppy distro comes with firmware, maybe?
[1]http://linuxwireless.org/en/users/Drivers/ath9k_htc
