Dear community
my first post after weeks of anonymous browsing, great forum, great people and the Pi
I gave up and now I'm looking for your support. Any idea and assistance is very much appreciated.
tl;dr version:
arecord does not record any sound from easycap (stk1160) on RPI 2.0 with kernel 3.12
None of these works for me:
#arecord -D plughw:1,0 -f S16_LE -r 48000 | aplay -D plughw:0,0 -f S16_LE -r 48000
Result: no sound on headphone
#arecord -D plughw:1,0 -d 10 -f dat -r 48000 test.wav
Result: empty 44 bytes wav file with error message arecord: pcm_read:1801: read error: Input/output error:
Result: infinite loop and empty file:
Has anyone recorded a sound sample from the easycap video grabber? If yes how?
Pls. share with me any hint - thank you!
Details:
RPI 2.0 + easycap on Linux raspberrypi 3.12.22+ #691
root@raspberrypi:~# arecord -Ll
null
Discard all samples (playback) or generate zero samples (capture)
default:CARD=Controlle
USB 2.0 Video Capture Controlle, USB Audio
Default Audio Device
sysdefault:CARD=Controlle
front:CARD=Controlle,DEV=0
Front speakers
surround40:CARD=Controlle,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Controlle,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Controlle,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Controlle,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Controlle,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Controlle,DEV=0
IEC958 (S/PDIF) Digital Audio Output
**** List of CAPTURE Hardware Devices ****
card 1: Controlle [USB 2.0 Video Capture Controlle], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
root@raspberrypi:~# dmesg
[ 4711.599487] usb 1-1.3: USB disconnect, device number 6
[ 4711.599732] stk1160: freeing 0 urb buffers...
[ 4711.599747] stk1160: all urb buffers freed
[ 4711.600067] stk1160: releasing all resources
[ 4717.719360] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
[ 4717.820392] usb 1-1.3: New USB device found, idVendor=05e1, idProduct=0408
[ 4717.820427] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4717.820445] usb 1-1.3: Product: USB 2.0 Video Capture Controller
[ 4717.820462] usb 1-1.3: Manufacturer: Syntek Semiconductor
[ 4717.824527] usb 1-1.3: New device Syntek Semiconductor USB 2.0 Video Capture Controller @ 480 Mbps (05e1:0408, interface 0, class 0)
[ 4717.824559] usb 1-1.3: video interface 0 found
[ 4718.521942] saa7115 2-0025: saa7113 found @ 0x4a (stk1160)
[ 4719.830179] stk1160: driver ver 0.9.5 successfully loaded
[ 4719.929182] stk1160: registers to NTSC like standard
[ 4720.090380] stk1160 1-1.3:1.0: V4L2 device registered as video0
root@raspberrypi:~# cat /proc/asound/cards
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
1 [Controlle ]: USB-Audio - USB 2.0 Video Capture Controlle
Syntek Semiconductor USB 2.0 Video Capture Controlle at usb-bcm2708_usb-1.3, hi
root@raspberrypi:~# amixer -c 1 contents
numid=1,iface=MIXER,name='Digital In Capture Switch'
; type=BOOLEAN,access=rw------,values=1
: values=on
Simple mixer control 'Digital In',0
Capabilities: cswitch cswitch-joined penum
Capture channels: Mono
Mono: Capture [on]
Audio jack works, tested with speaker-test -D plughw:0,0
I try to record some sound with following commands:
# First try:
root@raspberrypi:~# arecord -D plughw:1,0 -f S16_LE -r 48000 | aplay -D plughw:0,0 -f S16_LE -r 48000
Recording WAVE 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
Playing WAVE 'stdin' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
#Results: no sound in headphone !!!
#Second:
root@raspberrypi:~# arecord -d 5 -D plughw:1,0 -f S16_LE -r 48000 test.s16
Recording WAVE 'test.s16' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
# although I use -d 5 it does not stop after 5 seconds ???? What does it mean
# after ctrl-c the test.s16 file is empty (only 44 bytes):
-rw-r--r-- 1 root root 44 Jul 10 20:49 test.s16
#Third try:
Recording WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Stereo
#another "funny" thing:
root@raspberrypi:~# arecord -D plughw:1,0 -d 10 -f S16_LE -r 48000 test.wav
# runs in a infinity loop and has to be stoped with ctrl-c
many regards
Peter
