surendar
Video Play in Vertical
Tue May 13, 2014 6:06 am
Hi!!!!!! Greetings to all.My screen resolution is 1366x768.I want to rotate screen by 90 degree.I done this using "display_rotate=1" in config file.If i rotate a display by 90 degree means How to play a video in full screen i.e it fits to display?
masterluke
Re: Video Play in Vertical
Tue May 13, 2014 7:15 am
If you want a video to fill the whole screen with video using a portrait oriented screen then its going to be horribly distorted. Your best bet is keeping the correct aspect ratio. This would limit your video to 768x432 maximum effective resolution, but it would have the correct ratio.
tvjon
Tue May 13, 2014 7:35 am
"How to play a video in full screen i.e it fits to display?"
$ omxplayer --orientation 90 your_video
surendar
Tue May 13, 2014 9:21 am
tvjon wrote:"How to play a video in full screen i.e it fits to display?"
It shows /usr/bin/omxplayer.bin: unrecognized option '--orientation'
RaTTuS
Contact: Twitter YouTube
Tue May 13, 2014 9:29 am
omxplayer -v
Covfefe
galsasson
Thu Oct 19, 2017 1:09 pm
It's an old thread, but I encountered the same problem and I'm just putting here the solution I found in case someone else gets here.
I have a 1080x1920 screen and I use 'display_rotate=1' in /boot/config.txt to put it in landscape mode. omxplayer doesn't like it and don't render the video on the entire screen.
Further, using --orientation=90 just makes it worse.
Use this:
--win="xstart ystart xend yend"
For example:
 --win="0 0 1920 1080" to render full-screen.
This will define the render window coordinates of omxplayer.
