macemoneta
Re: Downloadable SD Card Images
Thu Jan 26, 2012 9:42 pm
A smaller image will work on a larger card, but if you want to be able to use the additional space you'll either need to add a partition or use an installer (like the live USB creator) that expands the partition and underlying filesystem.
http://en.wikipedia.org/wiki/F.....SB_creator
RedDude
Fri Jan 27, 2012 12:39 am
The obvious solution to the whole ordeal would be to include a small EEPROM or flash chip on every board containing some minimal bootloader with a busybox recovery console capable of mounting a USB filesystem.
