Page 1 of 2
Dropbox
Posted: Sun Jun 03, 2012 4:21 pm
by sharix
Is there a way to have dropbox synchronization on the Pi (debian)? I'd like to have a selective folder synchronization option so the desktop client is probably a must.
Re: Dropbox
Posted: Mon Jun 04, 2012 12:49 am
by AndrewS
Never gonna work. Dropbox for Linux only runs on x86 :( so won't work on Raspi's ARM CPU.
Re: Dropbox
Posted: Mon Jun 04, 2012 1:16 am
by JeremyF
You could make a complex system in which you install Dropbox on a Windows machine, and mount the Dropbox folder as a Samba share so you can access the "remote-remote" folder on the Pi.
Re: Dropbox
Posted: Mon Jun 04, 2012 5:38 am
by felix123
dropdav
(It'll cost you though.)
Re: Dropbox
Posted: Mon Jun 04, 2012 6:12 am
by cheery
Might be too early for dropbox to set in.. but who knows ask them whether they can provide support now. :)
Re: Dropbox
Posted: Mon Jun 04, 2012 9:40 am
by AndrewS
cheery wrote:Might be too early for dropbox to set in.. but who knows ask them whether they can provide support now. :)
Nice idea, but people have been asking (and voting) for a Dropbox Linux ARM client for many many years, but all the requests fall on deaf ears :(
https://www.dropbox.com/votebox/358/linux-arm-support
Re: Dropbox
Posted: Mon Jun 04, 2012 4:28 pm
by sharix
But my armv6 android phone has dropbox.
Re: Dropbox
Posted: Mon Jun 04, 2012 5:16 pm
by AndrewS
sharix wrote:But my armv6 android phone has dropbox.
Yup https://www.dropbox.com/android
But the mobile Dropbox clients work very differently to the desktop Dropbox clients.
Re: Dropbox
Posted: Mon Jun 04, 2012 5:17 pm
by abishur
Yep, your android OS can do something that a bare Linux OS cannot do. I know at the end of the day, Android is just a fancy GUI and assorted ins and outs on top of linux, but it really does make a difference. Just because something runs on one doesn't mean instant compatibility for the other. ;-)
Re: Dropbox
Posted: Wed Jun 06, 2012 1:21 pm
by EdwinJ85
Would the web client not work? It wouldn't be perfect but you could get files from A to B with reasonable speed.
Re: Dropbox
Posted: Sun Jun 10, 2012 3:01 pm
by sharpapotheosis
http://www.raspberrypi.org/phpBB3/viewt ... =36&t=7536 suggests owncloud, which looks pretty good. I'm about to try it out now :)
Re: Dropbox
Posted: Mon Jun 11, 2012 9:41 am
by Crook
Look up lftp - I want this capability and have my own FTP space (as I suspect many here do as well). Don't know much about it yet but that seems to do what you want and sync locally with a remote.
Re: Dropbox
Posted: Mon Jun 11, 2012 10:04 am
by bredman
If you are looking for a file backup/restore service, Duplicity (http://duplicity.nongnu.org/) is available for the RPi by using the command
sudo apt-get duplicity
Duplicity is the built-in backup solution used by Ubuntu. It can backup over ssh/scp, samba, rsync, ftp, HSI, WebDAV, Tahoe-LAFS, and Amazon S3.
I have used it for years (under the name deja-dup) to backup daily to a Samba drive and it is rock-solid.
Re: Dropbox
Posted: Mon Jun 11, 2012 2:28 pm
by meltwater
I was just thinking about this, although the other services sound good, I think I could have a good simple solution (which will hopefully work for my situation where the RPi does not have internet access (due to company proxy) but does have network, so I can use through VNC).
1. Set up a SMB shared drive on rpi, so it can be viewed from windows PC.
2. Setup up file sync software (i.e. AllwaySync) to mirror these files to a sub-directory in windows which is within dropbox...
Bingo...end up with dropbox backup of files and easy way to drop files on the RPi. If I set up another SD-card with the same share, it'll keep both cards synced too.
Just need to work out how to share a directory on the RPi now...
As, bredman has pointed out before...
http://elinux.org/R-Pi_NAS
I feel may be my friend here.
Re: Dropbox
Posted: Sun Jun 17, 2012 10:25 am
by gkmanning
Not Dropbox but you can follow the instructions here to mount box.com as a network drive on your R-pi.
http://linuxfordummies.org/mount-your-b ... -in-linux/
Re: Dropbox
Posted: Mon Jun 18, 2012 4:40 pm
by AndrewS
gkmanning wrote:Not Dropbox but you can follow the instructions here to mount box.com as a network drive on your R-pi.
There's also a WebDAV addon available for Dropbox http://dropdav.com/ which I guess would work in the same way.
Re: Dropbox
Posted: Thu Jun 21, 2012 12:01 pm
by ferik
Easiest would be to use one of the ask or the raw REST API to Push,pull files from Dropbox. Use the python sdk for example: https://www.dropbox.com/developers/reference/sdk
Re: Dropbox
Posted: Thu Jun 21, 2012 12:48 pm
by AndrewS
Yup. But using the SDK effectively gives you a FTP-like interface, which isn't what people expect when they ask for a Dropbox client - they want the standard 2-way automatic file synchronization (with speedy delta-transfers) that Dropbox on the desktop (or headless x86 Linux) offers :geek:
Re: Dropbox
Posted: Thu Jun 21, 2012 1:11 pm
by tawalker
There is another possibility, if you want to access your Dropbox (and, indeed, other "cloud" storage) from your Pi without actually mirroring the files to your local storage: I just found out about a Web service called Otixo, which aims to provide a single "file manager" front-end for accessing your "cloud storage" (Dropbox, Google Drive, Skydrive, Box.net, etc.).
What particularly interests me with Otixo, is that it also provides access to your files on these services as a WebDAV share. I don't know about Debian, but in the Arch "extra" repository, there's a filesystem driver called davfs (named "davfs2" for installation), which allows you to mount a WebDAV share directly into the Pi's filesystem.
In other words: as long as you have an Otixo account (with your desired "cloud storage" services added) and a working Internet connection on the Pi, with one "mount" command you could have access to your Dropbox, etc. without needing the files mirrored locally.
I haven't had time to try it yet, but I think I have a blog post in the offing if it works :D
Re: Dropbox
Posted: Thu Jun 21, 2012 5:59 pm
by ferik
AndrewS wrote:Yup. But using the SDK effectively gives you a FTP-like interface, which isn't what people expect when they ask for a Dropbox client - they want the standard 2-way automatic file synchronization (with speedy delta-transfers) that Dropbox on the desktop (or headless x86 Linux) offers :geek:
Unless you use the sdk to build exactly that. Easy enough to do in Node.js
Re: Dropbox
Posted: Thu Jun 21, 2012 6:40 pm
by AndrewS
tawalker wrote:What particularly interests me with Otixo, is that it also provides access to your files on these services as a WebDAV share. I don't know about Debian, but in the Arch "extra" repository, there's a filesystem driver called davfs (named "davfs2" for installation), which allows you to mount a WebDAV share directly into the Pi's filesystem.
Which is exactly what the DropDAV I linked to earlier does. But Otixo looks cheaper than DropDAV :) - I wonder exactly how long Otixo will be able to stay "free" for?
Re: Dropbox
Posted: Thu Jun 21, 2012 6:44 pm
by AndrewS
The Dropbox SDK only uploads/downloads entire files, not file-deltas. And I'd love to hear how a server-side Node.js script is supposed to automatically spot when a file on your Raspi has changed?
Re: Dropbox
Posted: Thu Jun 21, 2012 7:15 pm
by ferik
Quite easily with any of the node wrappers around FAM or inotify. I am not sure if you're making a distinction between the pi and 'server-side' but the app would run on the rpi. It's very unlikely any of my rpi will be running anything but headless.
Also the Dropbox API does deltas: https://www.dropbox.com/developers/reference/api#delta
Re: Dropbox
Posted: Thu Jun 21, 2012 7:35 pm
by AndrewS
Ah, that's why I was getting confused. Never used Node.js myself so thought it could only run on webservers, didn't realise you could run it "locally" too :)
Yes, but that's change-deltas, not file-deltas. If you only change 1KB in a 50MB file, the traditional Dropbox desktop clients only need to transfer the small part of the file that actually changed, but using the Dropbox API you have to transfer the whole 50MB all over again.
Re: Dropbox
Posted: Thu Jun 21, 2012 8:10 pm
by ferik
Gotcha. Wouldn't really affect my use case, upload new sensor log payload to a specific directory on Dropbox then delete on the rpi but it would make for a slightly ineffective sync client. Could be fine for many use cases though.
It's important to note that Dropbox claims to create hashes on every 4MB of each file. Which means that if your file are on average less than 4MB, it wouldn't make a difference that you can't use change deltas.
