tarmdjur
5GHz wifi without hub
Fri Mar 21, 2014 7:47 pm
Are there any 802.11n 5Ghz 300Mbit/s usb dongles that work without a hub? I've searched, googled and tried two different models with no luck.
redhawk
Re: 5GHz wifi without hub
Fri Mar 21, 2014 8:46 pm
If your Pi is a rev2 board (with the 2 massive holes) then it should be able to manage a Wifi dongle without a powered hub providing you have suitable power supply.
The early Pi rev1 boards had polyfuse protection per USB port which meant only low powered devices like flash drives or keyboards worked but not Wifi dongles.
When buying a Wifi dongle always check the chipset for compatibility, most should be okay on the Pi but some may not have firmware support for the 5GHz band yet even in hardware it does.
Richard S.
tarmdjur
Sat Mar 22, 2014 1:03 am
Thank you for your answer.
I do have the rev2 board, powered by an original Samsung Galaxy S4 power adapter (2A).
The D-Link DWA-160 (A2, AR9170) does start but stutters and hangs the Pi quickly when loaded.
CC&C WL-6210-V3 (RTL8192DU) doesn't even have support in OpenELEC...
TP-Link TL-WN821N (V3, AR7010) works but 2,4GHz wifi is quite unpleasant in crowded areas.
samidalati
Tue May 20, 2014 7:20 pm
Hi, i m trying to find a 5GHz wifi dongle that works with the Pi. i m wondering if you have found one that works?
semtex
Tue May 27, 2014 5:21 am
I assume you've already looked at http://elinux.org/RPi_USB_Wi-Fi_Adapters... but just in case.
xbmcnut
Fri Sep 05, 2014 9:10 am
@samidalati
I've tested the Tenda W522U with OpenELEC and the 5Ghz works. With the ability on the B+ to push 1200mA from the USB ports, should run without a hub if you use a 2A P/S?
http://www.tenda.cn/tendacn/Product/sho ... ductid=384
xbmcnut
Fri Sep 05, 2014 9:12 am
I've also tried the Cisco WUSB600N (V1.0) but the 5Ghz does not work with OpenELEC 4.0.7. Streams very nicely though on 2.4Ghz via a Cisco EA6500.
http://support.linksys.com/en-apac/supp ... s/WUSB600N
WeirdG
Tue Oct 28, 2014 4:53 am
@xbmcnut
I bought the Tenda W522U based on your post and several others. I understand the B+ has a USB current limiter. Did you have to make any changes to get around this?
I'm planning to run the current version of OpenELEC on my B+, along with a Tenda W522U USB wifi adapter. Please let me know, if you see this post.
Thanks.
Siamak
Mon Jan 12, 2015 12:11 pm
Hi Every body,
I am using Raspbmc with a TV guide and I needed to configure EDIMAX WiFi Dongle, it would not work at all until the day I found out that I have to install few things, i.e the following:
sudo apt-get install rfkill zd1211-firmware hostapd hostap-utils iw dnsmasq bridge-utils
Now it works like magic.
Ceers
Siamak
