dboira
raspberry pi on/off
Thu Dec 19, 2013 9:22 am
when I do a shutdown (sudo shutdown -h), my raspberry reboots. I can't turn off my raspberry pi.
Any help?
thanks in advance.
Re: raspberry pi on/off
Thu Dec 19, 2013 10:31 am
Odd, I thought shutdown worked fine on mine. Have you tried halt?
dboira
Thu Dec 19, 2013 10:56 am
Yes, very odd. I've tried also with halt and poweroff.
That worked fine before I made changes for configure a 7'' touchscreen on my Pi. What do you think?
RaTTuS
Thu Dec 19, 2013 10:58 am
what gpio things have you got plugged in
Covfefe
shuckle
Thu Dec 19, 2013 11:08 am
I had this also recently.
After I did
sudo apt-get update
sudo apt-get upgrade
It now works.
dboira
Thu Dec 19, 2013 11:22 am
I need to check that information because I haven't the Pi now with me.
I plugged in the pins to communicate with a thermal printer as I've read (I think are pins #6 and #8 I'm not sure now). But I'm sure: when I was the printer working fine, I could shutdown the Pi; the problem came later.
dboira
Thu Dec 19, 2013 11:25 am
I'll try shuckle suggestion
dboira
Thu Dec 19, 2013 11:28 am
shuckle, do you know which was the cause of the problem?
shuckle
Thu Dec 19, 2013 12:17 pm
no, I have no idea about the reason.
I was very surprised to experience it as I have done several installations and only saw it with the new raspberry I bought last week.
I did not pay that much attention since it was cured by the upgrade. (I also did rpi-update, but I don't think it is needed.)
I guess it is some kind of mismatch between kernel and firmware. My versions now are:
Linux raspberry2 3.10.24+ #610 PREEMPT Thu Dec 12 13:12:09 GMT 2013 armv6l GNU/Linux
Dec 9 2013 21:24:40
Copyright (c) 2012 Broadcom
version c7215df85576f3e72f9c390db9bc2da642453b10 (clean) (release)
dboira
Thu Dec 19, 2013 1:17 pm
so, I do an update and upgrade today.
I hope that fix my problem, I'll post here.
mrpi64
Fri Dec 20, 2013 8:34 am
Changing your settings using 'sudo raspi-config --> Advanced options --> Boot to desktop', and select boot straight to desktop. Now, when you go 'Start --> Logout', it should give you the option to shutdown. It should now shutdown more successfully.
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
Redrobes
Sat Dec 21, 2013 12:15 pm
I'll just chip in and say when I built myself a new kernel and installed it, it has since rebooted after shutdown in a similar manner to that posted by OP. I have not tried to fix it and still don't know why its doing it either.
I use "sudo shutdown -h now". It runs through the power down scripts and then blacks out the monitor. Then about 1 sec later it powers up the monitor and begins the boot sequence again. I have been pulling the power cord in the blacked out period.
