tawalker
Doom/Doom II/Quake (accelerated)
Mon May 21, 2012 3:25 pm
I know Pi-folk have been playing Quake III recently, but is it possible to play Doom, Doom II or the original Quake in GPU-accelerated form on the Pi?
I ask mainly because I have the legitimate level (WAD) files from buying the games many moons ago, and wouldn't mind having something on the Pi that I can actually run and play... :)
Raspberry Pi Model 3B+ (2019) ("ayeka") - CentOS
Raspberry Pi Zero W (2018) ("mass") - Raspbian
Raspberry Pi Model B (1st-gen - 2012) ("ryo-ohki") - Arch Linux ARM
Nr90
Re: Doom/Doom II/Quake (accelerated)
Mon May 21, 2012 3:51 pm
Maybe http://www.dengine.net/linux would be an option. It uses OpenGL.
Don't know anything about making it work on ARM though ;)
tawalker
Mon May 21, 2012 10:01 pm
When I got home, I queried the pacman database:
pacman -Ss doom
This revealed that "prboom" is in the "community" repository for Arch/ARM - I'd imagine it's an X program and not accelerated, though I suppose there'd be no harm in trying it...
toxibunny
Mon May 21, 2012 11:19 pm
doom doesn't even need acceleration - unless you're planning to run it at 1080p, I suppose...
note: I may or may not know what I'm talking about...
Narishma
Tue May 22, 2012 9:19 am
Nr90 wrote:Maybe http://www.dengine.net/linux would be an option. It uses OpenGL.
It needs to use OpenGL ES, not OpenGL, to work on the Pi.
grumpyoldgit
Tue May 22, 2012 9:22 am
Is there an idiot's guide to setting Doom up on the Pi?
Ed Raket
Tue May 22, 2012 9:42 am
Or... can anyone post an image file :D
Doom meets Pi.... Epic!
tawalker
Tue May 22, 2012 12:47 pm
toxibunny wrote:doom doesn't even need acceleration - unless you're planning to run it at 1080p, I suppose...
I suppose it depends if the program is X-based or not (haven't tried it)? If it is, my current X resolution is 1280x720 (720p HD) - if Prboom is running from the console (framebuffer?), I guess it might run a bit faster. Have to try it this week :)
Robert_M
Tue May 22, 2012 1:51 pm
grumpyoldgit wrote:Is there an idiot's guide to setting Doom up on the Pi?
Can I borrow it when you're done?
I sometimes ride my Pi to the Forum.
EdwinJ85
Wed May 23, 2012 3:21 pm
It should run, most of the original code was written in C which we can compile for ARM.
Most current generation Linux ports of the engine target x86, so we would need a port that had only C code and maybe some Arm Assembly bits here and there. We could then compile it for ARM and use the result. Power wise the Pi is more than capable of running the original doom, modern ports use higher resolutions though and may not work as well.
You also need more than just the engine to play Doom, you need a data file called a WAD that contains the levels, images and so on. Most of these are NOT free, only the original shareware version of Doom, Hexen, Heretic and a few third party modifications are. You can not play the original full Doom 1 or Doom 2 legally without buying them.
I go a bit more detail on my blog if you are interested. http://edwinjones.me.uk/rants/introducing-ezdoom.aspx
Hello!
Narishma
Wed May 23, 2012 4:15 pm
EdwinJ85 wrote:You also need more than just the engine to play Doom, you need a data file called a WAD that contains the levels, images and so on. Most of these are NOT free, only the original shareware version of Doom, Hexen, Heretic and a few third party modifications are. You can not play the original full Doom 1 or Doom 2 legally without buying them.
You can freely play the shareware version of Doom though, which consists of the first episode in it's entirety.
EdwinJ85
Thu May 24, 2012 8:10 am
I did mention that, but the shareware versions of Hexen and Heretic are also freeware. You can also use FreeDoom, there are quite a lot of levels in that mod and it's completely open source.
Hello!
gordon@drogon.net
Thu May 24, 2012 9:37 pm
sudo apt-get install prboom
cd ... to where the .wad is
prboom
and that's it. It will open a 640x480 window centred on the main screen and it runs Doom II OK. I tried it full-screen (1280x1024 for me) and it was too slow - absolutely no accelleration in the SDL libraries (yet?)
-Gordon
Gordons projects: https://projects.drogon.net/
EdwinJ85
Thu May 24, 2012 10:04 pm
Prboom builds on top of the original engine. As such it is more resource hungry. Chocolate doom would work much better I think, if anybody can get it working. It relies on sdl but everything else is plain old c from what I remember.
Hello!
Ed Raket
Thu May 24, 2012 10:34 pm
Look... i (for one) am holding my breath here, untill anyone tells me it runs ok on a Pi... (and i dont care for full HD)
So if anyone will save my life.... :)
gordon@drogon.net
Fri May 25, 2012 7:00 am
Ed Raket wrote:Look... i (for one) am holding my breath here, untill anyone tells me it runs ok on a Pi... (and i dont care for full HD)
Prboom runs OK on the Pi.
-Gordon
grumpyoldgit
Fri May 25, 2012 8:01 am
-Gordon
So ...... Can we have an idiot's guide please?
gordon@drogon.net
Fri May 25, 2012 8:11 am
-Gordon
Login, startx, open a terminal type this:
mkdir doom
cd doom
... Now copy the doom2.wad file from whereever you have it into this directory
prboom
and off you go. That is literally all I did to make it work.
Make it bigger with prboom -width 1024 -height 768 etc. however it will be slower.
Should the X server/framebuffer get 2D acelleration at some point then it might be faster, but until them prboom, and all applications using the SDL libraries (e.g. tuxpaint, pyGame) will be somewhat sub-optimal as the ARM is doing all the blitting, etc. (Assuming the GPU can blit faster than the ARM anyway)
-Gordon
riffraff
Sat May 26, 2012 2:30 am
I know there's an android version of DOOM, but I'm not sure if it's been ported to native ARM code or to Dalvik VM. DOOM doesn't require acceleration. Remember, this is a game that ran well on i386-SX.
gordon@drogon.net
Sat May 26, 2012 7:13 am
riffraff wrote:I know there's an android version of DOOM, but I'm not sure if it's been ported to native ARM code or to Dalvik VM. DOOM doesn't require acceleration. Remember, this is a game that ran well on i386-SX.
prboom runs fine - and you're right - the CPU is more than fast enough! The slowness right now in the ARM is doing olde-fashioned 2D type stuff with the frambuffer - which prboom is doing (with the SDL library) - that's somewhat sub-optimal and if/when the framebufer can be rewritten as an accellerated 2D framebuffer then things will get a whole load faster - with the GPU doing "BLIT" type operations for us - which I'm told will be much faster than the ARM!
-Gordon
gordon@drogon.net
Sat May 26, 2012 1:02 pm
Just another (final!) followup - bit of a quick "lash-up" on the floor, but:
Pi running DoomII via the prboom engine.
It's running under the standard Debian image, under X (launched prboom from an terminal), however as my screen is small there, I have to explicitly set the screen size.
And it's green, but monsters are green anyway... ;-)
And the sound works too (modprobe snd-bcm2835) - first time I've actually had sound out of a Pi!
-Gordon
Ed Raket
Sat May 26, 2012 3:48 pm
That is great Gordon! THX for showing :mrgreen:
tawalker
Sat May 26, 2012 4:04 pm
I'll have to dig out my old Doom/Doom II WADs now - thanks for the news!
(It confirms my belief that what the Pi really needs on the Linux front, is an accelerated X server. I so wish I could help make it happen, but the limit of my programming is occasional bash and PHP-scripting... :( )
tawalker
Tue May 29, 2012 9:06 am
I tried running prboom on my Pi yesterday evening...
Good news: it found the WAD files I'd installed, and there were no problems with sound (well, OK, the music wasn't playing, but the sound effects were).
Bad news: I couldn't see any visuals :( I tried specifying the "window" size to 640x480 (I was running prboom at the console, not under X), but it didn't have any effect.
Any ideas on how to get the game visible?
Many thanks :)
gordon@drogon.net
Tue May 29, 2012 9:22 am
tawalker wrote:I tried running prboom on my Pi yesterday evening...
Many thanks :)
Run it full-screen under X.
I've had lots of issues running SDL applications on the console - working my way through some of them (e.g. it's a 16bpp framebuffer by default not 32 which might confuse apps. exepecting 32bpp)
-Gordon
