Tue Aug 07, 2012 10:38 pm
So, i was just bored, and thought of getting some measurements, do what you want with them, and say if you want some more or some other.
I used a power supply with USB interface and logging software.
Following setup.
Fresh Debian Wheezy Image, with all updates installed before logging.
HDMI monitor Connected.
LAN Connected.
Logitech Wireless Keyboard and mouse Dongle on USB-0. (MK250)
Power supplied via GPIO pins, bypassing the fuse.
Current limited to 1000mA.
Time span, 13min 00sec
Logging interval: 2000ms (2sec)
Values measured.
Supply voltage: 4,900 (V)
Maximum value: 4,907
Minimum value: 4,894
Range: 0,013
Average: 4,897
Current (A):
Maximum value: 0,51
Minimum value: 0,05
Range: 0,46
Average: 0,403
Power (W):
Maximum value: 2,497
Minimum value: 0,245
Range: 2,253
Average: 1,976
During boot, the power usage was between 1,92W and 2,30W (Spike 2,49W)
Idle terminal (eg. before starting X), between 1,92W and 1,96W
Starting X and idle X, 1,96W to 2,02W
Starting Task manager and a Pygame (Squirrel eats squirrel, 100% CPU load, GPU load unknown), 1,98W to 2,16W (Spike 2,49W)
Running a Pygame, 2,12W to 2,16W.
Shutting down, 2,12W to 2,40W
Halt, 0,47W
