Page 1 of 2
Difference between Pi 1 & Pi 2
Posted: Mon May 14, 2012 9:25 pm
by Tass
So I received my 2nd Pi today (don't worry - going to good home) - and I noticed a few differences.
Pi 1 has an RJ45 connector made by Bothhand (LB)
Pi 2 has an RJ45 connector made by HanRun
Both seem to hace magnetics :)
Pi 1 has no CE sticker
Pi 2 has a CE sticker
Just above the SD card:
Pi 1 has 1208 printed
Pi 2 has 1213 printed
Pi 1 SoC has engraved text on top
Pi 2 Soc has flat white text on top
Overall, I'd say the components on Pi 2 are all a little straighter than Pi 1.
Most importantly.... they both boot up!!! :-)
P.S. Pi 2 really is going to a good home!!
Re: Difference between Pi 1 & Pi 2
Posted: Mon May 14, 2012 10:16 pm
by teh_orph
Did you get them from different companies?
Posted: Mon May 14, 2012 10:19 pm
by Tass
Yes, 1 from Farnell, 1 from RS.
Posted: Mon May 14, 2012 10:34 pm
by abishur
The fact that one has the CE stamp and one does not would lead me to believe that one came from the initial 10K batch the RPF had made and the other came from the serial production of one of the two distributors
Posted: Mon May 14, 2012 10:38 pm
by max1zzz
abishur wrote:The fact that one has the CE stamp and one does not would lead me to believe that one came from the initial 10K batch the RPF had made and the other came from the serial production of one of the two distributors
i believe the one with no CE mark must be from the first 2K, since as far as i know my Pi is from the first 10K (but not the first 2K) and it has the CE marking
Posted: Mon May 14, 2012 10:45 pm
by Tass
Yes, that's what I've figured. Pi 1 (without the CE sticker) arrived about 4 weeks ago.
Posted: Mon May 14, 2012 10:49 pm
by abishur
Are you talking about a CE mark as in part of the silkscreen? Or are you just talking about a CE sticker?
Posted: Mon May 14, 2012 10:56 pm
by max1zzz
Just a sticker
Posted: Tue May 15, 2012 12:43 am
by AndrewS
Interesting, thanks for that :)
Your description of "Pi 1" matches the pictures here: http://www.frambozenbier.org/index.php/ ... -his-raspi
I think these are probably manufacturing year and week number, i.e. 2012 week 8 and 2012 week 13.
http://www.epochconverter.com/date-and- ... ?year=2012
Just to be pedantic ;) the marking is actually on the RAM (stacked on top of the SoC), not the SoC itself.
Posted: Sat May 19, 2012 10:40 pm
by stevepdp
Forgive me if this sounds a little silly...
Since hearing about the Pi about a year ago, I've always thought it would be fun to document the Raspberry Pi's changes in development, board revisions and such.
We see this kind of documented history with devices like the BBC Micro, Speccy and all, so why not do it for the Pi too? Perhaps at the wiki?
Thanks for pointing out the differences, I too noticed changes in components and such when comparing my board to a couple of friends' boards last Thursday.
Posted: Thu May 24, 2012 9:42 am
by SN
Mine that arrived today has 1215 stamped on it
Posted: Thu May 24, 2012 12:31 pm
by TonyD
1215 looks to be a date stamp put onto the silkscreen by the PCB manufacturer. It's means the PCB was made in the 15th week of 2012
Posted: Thu May 24, 2012 7:37 pm
by AndrewS
stevepdp wrote:Since hearing about the Pi about a year ago, I've always thought it would be fun to document the Raspberry Pi's changes in development, board revisions and such.
I guess someone needs to take the time to update http://elinux.org/RPi_HardwareHistory ;)
SN wrote:Mine that arrived today has 1215 stamped on it
Oooh, interesting. So that's 3 batches of production PCBs so far :) I'm assuming that each successive batch is going to be bigger than the last one?
Posted: Fri May 25, 2012 5:37 pm
by AndrewS
And now a "fourth batch" PCB, stamped 1218 :)
http://www.raspberrypi.org/phpBB3/viewt ... 894#p83894
Posted: Thu Jun 07, 2012 7:50 pm
by SN
In the words of Monty Python ... "and now for something completely different"
Todays delivery from RS brought this...
Image Image
No build date at all on the front of the board -- But the RS label on the back 'might' contain a Build Week - Week 21 in this case
Image Image
Posted: Thu Jun 07, 2012 8:11 pm
by jojopi
SN wrote:No build date at all on the front of the board
The seven-segment "1218" has moved to the bottom, in the vicinity of the magjack, along with the "SL" and "94V-0" marks. I wonder what that ugly roman "CE" is for, and why it is now so important...
Posted: Thu Jun 07, 2012 8:19 pm
by SN
So it is.... so this one is Build Week 12 18
Posted: Thu Jun 07, 2012 11:38 pm
by bonelifer
jojopi wrote:
SN wrote:... I wonder what that ugly roman "CE" is for, and why it is now so important...
CE mark -->> http://en.wikipedia.org/wiki/CE_mark
Posted: Fri Jun 08, 2012 12:18 am
by bonelifer
And the reason it's so important is that the distributors refused to sell it without it getting that certification:
http://www.geek.com/articles/chips/dist ... -20120329/
Posted: Fri Jun 08, 2012 5:08 am
by itimpi
There were two CE type marks on the photos. The stylistic one is the CE logo and relates to the certification process - no idea what the other one in roman letters stands for.
Posted: Sat Jun 09, 2012 2:49 pm
by AndrewS
SN wrote:So it is.... so this one is Build Week 12 18
Right... so we can no longer uniquely identify board revisions by build-week-number, as we now have two boards with "1218" build week numbers (week 18 of 2012), but different silkscreens:
Good to see that production is obviously continuing to churn away... :D
Posted: Sat Jun 09, 2012 2:56 pm
by SN
Andrew, is yours a Farnell or RS pi - mine is an RS pi
Posted: Sat Jun 09, 2012 3:00 pm
by AndrewS
SN wrote:Andrew, is yours a Farnell or RS pi - mine is an RS pi
That's not my Pi, it's the one from http://www.raspberrypi.org/phpBB3/viewt ... 894#p83894 which says it's from Farnell. (mine is also from Farnell, but marked 1215)
Posted: Sat Jun 09, 2012 3:20 pm
by SN
Hmmm... so we can't make any assertions that differing distributor requirements are driving the differences then. Can anyone (from RPF) comment on how many factories are building them and for who?
Posted: Sat Jun 09, 2012 8:18 pm
by Michael
Both manufacturers switched from batch to serial production some time ago. They are probably receiving deliveries once or twice a week.
Michael
