ofe
board with male-male pins
Tue Oct 15, 2013 5:07 am
hi, Im developing my drone and I need to connect rpi with motors and sensors. So I need a ribbon cable from rpi gpio.
than i need to rearrenge some pin order to fullfill the sensor connector(for example the i2c sensor has got the 2 channels inverted respet the pi)
So im thinking to have a board with male connector for the rpi conn and another male for the devices conn.finally I ll solder the necessary jumper.Is there this type of board?
if there is better solution let me know.
Note: Breadbord is too big and heavy for my project.
tnk
Oscar
Visit my quadcopter blog
http://solenerotech1.wordpress.com
itsmedoofer
Re: board with male-male pins
Tue Oct 15, 2013 8:04 am
Is this something like you were thinking of ?
https://www.modmypi.com/raspberry-pi-ex ... kout-board
Martin.
ofe
Wed Oct 16, 2013 5:10 am
well, something similar, but I need to invert some pins so the board should be without any circuit on it.
Oscar
ame
Wed Oct 16, 2013 6:19 am
That board has no circuit on it. It's just an easy way to use a ribbon cable and either plug into a breadboard, or just have easy access to the pins.
It's very similar to this:
http://eleparts.co.kr/EPX8JRHF
and this:
http://eleparts.co.kr/EPX8JRHG
and this (which also duplicates the UART pins):
If you can't find what you want, can you make a small sketch and post it here? Maybe someone will have seen something similar.
Another option is to use pluggable wires, like this:
F-M https://www.sparkfun.com/products/9385
F-F https://www.sparkfun.com/products/9389
fdufnews
Wed Oct 16, 2013 1:34 pm
Why not using a piece of perfboard with male connectors and wiring only the signal you need?
