rpi_ayu
shell script throwing error on rpi but works fine on ubuntu
Mon Oct 07, 2013 12:49 pm
strange thing to say but same script which is working fine for ubuntu but throwing error on rpi the content of script is as given below. in this script just trying to find ip of working interface (interface which is up)
    #!/bin/bash
    wifiip=$(ip addr \
    | grep inet | grep wlan0 \
    | awk -F" " '{print $2}' \
    | sed -e 's/\/.*$//')
    checketh0=$(ip addr |grep eth0 |grep DOWN &> /dev/null ; echo $?)
    if [ "$checketh0" == "0" ] ; then
        eth0ip="not connected"
      else
        eth0ip=$(ip addr \
        | grep inet | grep eth0 \
        | sed -e 's/\/.*$//')
    fi
    checketh1=$(ip addr |grep eth1 |grep DOWN &> /dev/null ; echo $?)
    if [ "$checketh1" == "0" ] ; then
        eth1ip="not connected"
      else
        eth1ip=$(ip addr \
        | grep inet | grep eth1 \
        | sed -e 's/\/.*$//')
    fi
    # report findings, only returning devices with IPs
    echo "wlan0: $wifiip" | grep [0-9]$
    echo "eth0: $eth0ip" | grep [0-9]$
    echo "eth1: $eth1ip" | grep [0-9]$
works fine on ubuntu o/p shows itself
ayush@ayush-desktop:~$ sh ip.sh
wlan0: 192.168.1.82
but when same script is when i am running on rpi
pi@raspberrypi ~ $ sh ip.sh
ip.sh: 13: [: 0
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN qlen 1000: unexpected operator
ip.sh: 24: [: 0: unexpected operator
i know its silly question to ask but i really need it solution for this .........Thanks in advance..
DeeJay
Re: shell script throwing error on rpi but works fine on ubu
Mon Oct 07, 2013 1:05 pm
My suggestion for debugging would be to run the commands
and
on both the Ubuntu and RPi systems and look for differences in the output that is returned.
chilinski
Mon Oct 07, 2013 1:30 pm
The hostname command will also give you the ip addresses.
For example: hostname -I (that's a capital i). It won't tell you which ones are active and it won't give you the nic (e.g. eth0), but it works for basic stuff.
ripat
Mon Oct 07, 2013 6:18 pm
As your are using iproute, you can also simply use:
ip route | awk '/src/{print $3": "$9}'
Using Linux command line usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
BluDragon
Tue Oct 08, 2013 8:40 am
:idea:
instead of using
use spaces like;
checketh0=$(ip addr | grep eth0 | grep DOWN &> /dev/null ; echo $?)
"Whenever a separation is made between liberty and justice, neither, in my opinion, is safe." - Edmund Burke
"Men make counterfeit money; in many more cases, money makes counterfeit men." - Sydney J. Harris
jojopi
Tue Oct 08, 2013 9:19 am
rpi_ayu wrote:pi@raspberrypi ~ $ sh ip.sh
"&>" and "[ x == y ]" are bash extensions. You must run the script as "bash ip.sh", not "sh ip.sh".
Or, preferably, change all the "&> /dev/null" to ">/dev/null 2>&1", and all the "if [ x == y ]" to "if [ x = y ]", which are the standard ways to express these operations.
On Ubuntu, sh is probably the same as bash. But in Debian/Raspbian, sh is dash, which implements only standard POSIX behaviour.
BluDragon wrote::idea:
If you are going to guess what the problem might be, you could at least take the time to check whether your suggestion makes any difference at all. It does not.
BluDragon
Wed Oct 09, 2013 12:16 am
i don't have my raspberry pi setup right meow. it was just a suggestion anyway.
use this instead of using sh or bash,
chmod +x script
./script
if you still can't get it to work, try using each line in terminal. you will see the problem if you do this. sometimes compilers & command interpreters don't give you completely accurate errors.
