sim_tcr
changes on /etc/resolve.conf not getting saved upon reboot
Sat Oct 05, 2013 8:21 am
I am running 2013-09-25-wheezy-raspbian image on 4GB SD Card. I tried making changes to /etc/resolv.conf (adding two name servers).
Upon reboot those values are gone.
Any idea?
Thanks,
Simon Mandy
http://raspisimon.no-ip.org
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
Re: changes on /etc/resolve.conf not getting saved upon rebo
Sat Oct 05, 2013 8:59 am
You can't just use nano (or vi) on /etc/resolv.conf. That will be overwritten every time you disconnect, reconnect, shutdown or reboot. Resolv.conf is updated by the ifup/ifdown process based on what's in your /etc/network/interfaces definitions.
Edit /etc/network/interfaces and add your preferred nameserver (my examples use Google's public servers)
iface eth0 inet dhcp
  dns-nameservers 8.8.8.8 8.8.4.4
and the same for WLAN0
iface wlan0 inet dhcp
This is a doctor free zone.
jojopi
Sat Oct 05, 2013 9:28 am
Also, if you are using DHCP, it would be better to configure your DHCP server/router to give out the resolvers you want to use, instead of individually configuring your clients to substitute their own.
sim_tcr
Sat Oct 05, 2013 11:37 am
DougieLawson wrote:You can't just use nano (or vi) on /etc/resolv.conf. That will be overwritten every time you disconnect, reconnect, shutdown or reboot. Resolv.conf is updated by the ifup/ifdown process based on what's in your /etc/network/interfaces definitions.
auto lo
iface lo inet loopback
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
#iface default inet dhcp
auto wlan0
iface wlan0 inet static
address 192.168.1.XXX
gateway 192.168.1.1
netmask 255.255.255.0
network 192.168.1.0
broadcast 192.168.1.255
auto eth0
iface eth0 inet static
gateway 192.168.1.1
network 192.168.1.0
Is this correct?
Tue Oct 08, 2013 7:45 am
That should work.
The dns-nameservers statement relates to the iface stanza that comes before it. That means you can have different specifications depending on which interface is connected.
sim_tcr
Tue Oct 08, 2013 7:51 am
DougieLawson wrote:That should work.
After making those changes, if i look in /etc/resolve.conf will it be there?
pippopippo
Fri Apr 08, 2016 1:09 pm
this is my network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
auto eth0
address 192.168.1.113
gateway 192.168.1.1
network 192.168.1.0
dns-nameservers 8.8.8.8 4.4.4.4
auto wlan0
allow-hotplug wlan0
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
metric 1
allow-hotplug eth1
iface eth1 inet dhcp
metric 2
but dns is not ok:
nslookup google.com
;; Got recursion not available from 192.168.8.1, trying next server
Server: 8.8.8.8
Address: 8.8.8.8#53
and:
wget google.com
--2016-04-08 03:10:51-- http://google.com/
Resolving google.com (google.com)... 192.168.8.1
Connecting to google.com (google.com)|192.168.8.1|:80... connected.
HTTP request sent, awaiting response... 307 Temporary Redirect
Location: http://192.168.8.1/html/index.html?url=google.com [following]
--2016-04-08 03:11:06-- http://192.168.8.1/html/index.html?url=google.com
my /etc/resolv.conf is this:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 192.168.8.1
nameserver 8.8.8.8
nameserver 4.4.4.4
search hi.link
and it is not correct...nameserver 192.168.8.1 is not correct...it cames from eth1 interfaces that is a 3G dongle connected but non working now....it should be:
nameserver 8.8.8.8
nameserver 4.4.4.4
---if I change by hand /etc/resolv.conf everything works fine but at the next restart it came back (wrong).
How can I change /etc/resolv.conf forever?
tks,
Pippo
Sat Apr 09, 2016 1:13 pm
You need to remove the raspberrypi-net-mods and resolvconf packages if they're installed. The network-manager stuff should then work more normally and your changes to the /etc/network/interfaces file will be effective.
Your alternative option is to embrace the changes from those two packages and remove the stuff you've added in /etc/network/interfaces and add stuff in /etc/dhcpcd.conf to define your static IP and the resolver you want to use.
I've added a couple of lines to define "domain" and "search" in my /etc/resolv.conf so this is my interfaces file
auto lo
iface eth0 inet manual
        dns-search example.co.uk
        dns-domain example.co.uk
allow-hotplug wlan0
#allow-hotplug wlan1
#iface wlan1 inet manual
#    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
and add this stuff at the bottom of /etc/dhcpcd.cond
interface eth0
static ip_address=192.168.1.99/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1 8.8.8.8
interface wlan0
static ip_address=192.168.1.29/24
cotuitKayaker
Re: changes on /etc/resolve.conf not getting saved upon reboot
Tue Jan 30, 2018 10:51 am
I wanted to add this for people who are using RaspberryPi with Firebase to access data. I wrote my python test code on win10 using the firebase_admin library. Everything worked fine. However when I moved my python code over to the RaspberryPi Zero W (RaspianOS), and attempted a get() from the cloud based data, I got the following errors:
google.auth.exceptions.TransportError: HTTPSConnectionPool(host='accounts.google.com', port=443): Max retries exceeded with url: /o/oauth2/token (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0xb5d4ee50>: Failed to establish a new connection: [Errno 111] Connection refused',))
To resolve this, in /etc/resolve.conf, you must change:
# Generated by resolvconf
nameserver 127.0.0.1
to:
nameserver 8.8.8.8
Also, make the changes listed in the forum posts above to ensure that your conf file does not get automatically overwritten.
teknopaul
Sun Nov 18, 2018 6:37 pm
Testing this on Raspbian/stretch to take back control of resolv.conf and local DNS lookups with a static networking config.
- disable dhcpcd which fiddles with resolv.conf
- tell NetworkManager not to
- configure network without dhcpcd
- configure resolv.conf manually
- remove systemd-resolved
- remove root access to resolv.conf
Manual network config
**/etc/network/interfaces**
    iface enxb8123442be inet static
        address 192.168.1.99
        gateway 192.168.1.1
        dns-nameservers 208.67.222.222
        dns-search example.org
The above config will generate resolv.conf, potentially as you needed it.
**resolv.conf**
	nameserver 208.67.222.222
	search example.org
In my case it still gets the dns servers wrong 127.0.0.1, resolvconf is presuming systemd's local cache is running. I run dnsmasq on this server as a local cache for the network. This is apparently a "bug" that just happens to make systemd-resolved necessary.
The following should tell network manager not to fiddle with resolv.conf, but in raspbian did not, YMMV.
**/etc/NetworkManager/NetworkManager.conf**
	[main]
	dns=none
I've seen it as follows, but this did not work in raspbian either
dns=default
So now prevent even root access to resolv.conf
    chattr +i /etc/resolv.conf
If you script your own /etc/resolv.conf add to the script
    chattr -i /etc/resolv.conf
To start network on boot the simplest way is to add to
**/etc/rc.local**
    ifup enxb8123442be
n.b. you may need to make /etc/rc.local executable
Tell systemd not to run dhcpcd (we have a static config), and disable systemd's DNS meddling.
    sudo systemctl disable dhcpcd
    sudo systemctl disable --now systemd-resolved.service
reboot or restart networking
    sudo systemctl enable networking
Roken
Sun Nov 18, 2018 8:31 pm
Easy answer. Setup /etc/resolv.conf how you want it.
Run
sudo chattr +i /etc/resolv.conf
Then it will never be changed. If you need to edit it, change +i to -i
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
