hub
Auto Shutdown
Mon Sep 30, 2013 2:04 am
Does anyone know of a way to have the pi shut itself off completely? I can handle to auto boot, I jus need it to shut down (without pulling the plug)
elatllat
Re: Auto Shutdown
Mon Sep 30, 2013 3:18 am
you could have a script monitor a button on the gpio, but I just pull the plug.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
klricks
Re: Auto Shutdown
Mon Sep 30, 2013 3:32 am
hub wrote:Does anyone know of a way to have the pi shut itself off completely? I can handle to auto boot, I jus need it to shut down (without pulling the plug)
Not without adding external circuitry such as a relay.
The RPi is much like any modern PC..... the 5V standby circuits in the power supply and motherboard remain powered even when the computer is shutdown.
ramstrong
Re: Auto Shutdown
Mon Sep 30, 2013 3:51 am
I connected mine to powered USB hub. By switching off the hub, I shut off the Pi. After I did a "sudo halt", of course.
Raspberry Pi Journal: http://simpletongeek.blogspot.com/p/raspberry-pi-journal-directory_4.html
confuseling
Re: Auto Shutdown
Mon Sep 30, 2013 8:40 am
Kind of depends what you mean. You can schedule tasks (such as a shutdown) with cron or at.
But it'll still be powered.
http://debian-handbook.info/browse/stab ... n-atd.html
http://forums.debian.net
