system-info - my RaspberryPi system summary script
Posted: Sun Sep 29, 2013 8:29 pm
by kraptv
Hi gang.
I was a little annoyed that there didn't seem to be an "all in one info" script that would provide info about my RaspberryPi. In this void, I found other scripts doing some of what I was looking for, but not all. Utilities existed for the x86 platform like dmidecode for dmi information (serials, mainboard info, component info), lmsensors or ipmitool for IPMI info (temperatures, voltages), and others.
Hopefully those used to that functionality (or are searching the forums for equivalents) can find use in my script.
Features include:
  • Model A/B detection
    RAM summary detailing how much is split between system and GPU
    System Overvoltage Detection (acts better for hexadecimal hardware revisions now)
    Raw SD Card capacity (fixed for 4GB and 8GB cards showing up as thousands of megabytes)
    Current Temperature in Fahrenheit and Celsius
    CPU core speeds/voltage
    Extra codecs licensed for for GPU offload.
Needs to be run as root and requires bc to be installed (apt-get install bc if you're running Debian or derivates).
Current version is being served out by my RaspberryPi here:
http://skylab.org/~ryan/system-info/
Code (version current as of this post) is as follows:
#!/bin/bash
VERSION="0.5.6"
# raspberry-pi system information script
# One script that can tell you the RAM config, serial number, SD card size,
# temperature, and codec entitlements. Work-in-progress!
# Requires bc to for quick calculation. (apt-get install bc on debian)
# questions and comments to kraptv@sdf.org (or post to the rpi web forum!)
# ***** This has only been tested on Raspbian wheezy
# check if run as a normal user - if so, exit.
if [[ $(/usr/bin/id -u) -ne 0 ]]; then
    echo "$0 not running as root!"
    exit
fi
# Annoyingly, users ignore the bc requirement. This should set them straight!
if [ ! -f /usr/bin/bc ]; then
    echo -e "ERROR: bc binary is not installed.\nTry running 'apt-get install bc' on most popular RaspberryPi Linux distributions."
    exit
fi
# calculate the memory allocated based upon the GPU / system split read from
# /boot/config.txt (gpu_mem=64) - use vcgencmd because text file contents may be
# different than actual boot-time memory split allocation!
sysmem=`/opt/vc/bin/vcgencmd get_mem arm  | sed 's/[A-Za-z]*//g' | cut -c 2-`
gpumem=`/opt/vc/bin/vcgencmd get_mem gpu  | sed 's/[A-Za-z]*//g' | cut -c 2-`
totalmem=`expr $sysmem + $gpumem`
# Model A shouldn't have the smsc95xx installed! Return 1 if it's a modelB
modelB=`lsusb -t | grep -c smsc95xx`
rpiSerialNum=`grep Serial /proc/cpuinfo | cut -d " " -f 2`
# Reference: http://elinux.org/RPi_HardwareHistory#Board_Revision_History
# We have alphanumeric CPU revisions. Need to change the greater than logic.
rpiOverVolt=`grep Revision /proc/cpuinfo | cut -d " " -f 2 | tr -d [A-Z][a-z]`
# Start outputting content with script version
echo "*** system-info for raspberry-pi $VERSION ***************************************"
if [ "$modelB" = "1" ]
then
  echo "Model B serial $rpiSerialNum detected with $totalmem MB ($sysmem Sys/$gpumem GPU)"
else
  echo "Model A serial $rpiSerialNum detected with $totalmem MB installed ($sysmem sys / $gpumem gpu split)"
fi
# Raw SD card capacity does not translate to usable space! May need resizing!
# Changed as many users have 4GB and 8GB SD cards and fdisk shows in KBytes
fdiskOutput=`fdisk -l /dev/mmcblk0 | head -n 2 | tail -n 1 | cut -d \  -f 3,4`
echo "SD card raw capacity: ${fdiskOutput:0:-1}"
# Check if overvolted and display warning.
if [ "$rpiOverVolt" -gt "1000" ]
then
  echo "WARNING: Overvoltage has been applied to this system at least once!"
else
  echo " "
fi
echo -n "Firmware version: "
/opt/vc/bin/vcgencmd version | grep -v Broadcom
echo " "
tm=`/opt/vc/bin/vcgencmd measure_temp`
tc=`echo $tm| cut -d '=' -f2 | sed 's/..$//'`
tf=$(echo "scale=1; (1.8*$tc)+32" | bc)
echo -e "temp:\t $tf'F ($tc'C)"
echo " "
#echo -e "temp:\t $(/opt/vc/bin/vcgencmd measure_temp)" ;
for src in arm core v3d uart emmc pixel hdmi ; do echo -e "$src:\t $(/opt/vc/bin/vcgencmd measure_clock $src)" ; done
echo " "
for id in core sdram_c sdram_p ; do echo -e "$id: $(/opt/vc/bin/vcgencmd measure_volts $id)" ; done
echo " "
for codec in MPG2 WVC1 ; do echo -e "$codec:\t $(/opt/vc/bin/vcgencmd codec_enabled $codec)" ; done
this will output something like this on a Model B with a 64GB SD Card (RPi has not had overvoltage applied ):
*** system-info for raspberry-pi 0.5.6 ***************************************
Model B serial 00000000d2e1bc26 detected with 512 MB (448 Sys/64 GPU)
SD card raw capacity: 63.9 GB
Firmware version: Nov 15 2013 14:17:01
version 162026b1448f491e97e3b3b57cdca29be6a1d61a (tainted) (release)
temp:	 116.7'F (47.1'C)
arm:	 frequency(45)=900000000
core:	 frequency(1)=250000000
v3d:	 frequency(43)=250000000
uart:	 frequency(22)=3000000
emmc:	 frequency(47)=249999000
pixel:	 frequency(29)=148500000
hdmi:	 frequency(9)=163683000
core: volt=1.25V
sdram_c: volt=1.20V
sdram_p: volt=1.23V
MPG2:	 MPG2=disabled
WVC1:	 WVC1=disabled
And a Model B with 256GB of RAM, 8GB SD Card, and had overvoltaged applied:
Model B serial 0000000047a27b1d detected with 256 MB (192 Sys/64 GPU)
SD card raw capacity: 7861 MB
temp:	 104.1'F (40.1'C)
emmc:	 frequency(47)=250000000
pixel:	 frequency(29)=0
hdmi:	 frequency(9)=0
core: volt=1.25V
sdram_c: volt=1.20V
sdram_p: volt=1.23V
MPG2:	 MPG2=disabled
WVC1:	 WVC1=disabled
Your feedback is welcome! I would appreciate it if someone with a Model A could tell me that it has reliably detected their system as a Model A, as I am guessing a little bit on the auto-detection part.
Re: system-info - my RaspberryPi system summary script
Posted: Thu Nov 14, 2013 1:44 am
by chrissv
Hi there,
I was looking for an e-mail address to reply to you (in the script, on this page, or on your website) but didn't find any. So I am posting my comment here.
I tried your version 0.5.5 of the script and got the following results:
*** system-info for raspberry-pi 0.5.5 ***************************************
Model B serial 000000005953cfe9 detected with 512 MB (448 Sys/64 GPU)
./system-info.sh: line 47: -1: substring expression < 0
./system-info.sh: line 50: [: 000e: integer expression expected
Firmware version: Nov 12 2013 23:43:03
version 4aee5454c7955e7bc0bbb152ca4c0e26e75376e1 (clean) (release)
temp:    107.9'F (42.2'C)
arm:     frequency(45)=699998000
pixel:   frequency(29)=108000000
hdmi:    frequency(9)=163682000
core: volt=1.20V
sdram_c: volt=1.20V
sdram_p: volt=1.23V
MPG2:    MPG2=disabled
WVC1:    WVC1=disabled
Apparently your script is expecting the fdisk -l output to contain a "GB" and mine doesn't:
# fdisk -l /dev/mmcblk0
Disk /dev/mmcblk0: 7948 MB, 7948206080 bytes
4 heads, 16 sectors/track, 242560 cylinders, total 15523840 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0002c262
        Device Boot      Start         End      Blocks   Id  System
/dev/mmcblk0p1            8192      122879       57344    c  W95 FAT32 (LBA)
/dev/mmcblk0p2          122880    15523839     7700480   83  Linux
I don't know about the second error.
My "uname -a" results in:
Linux rpi 3.10.18+ #594 PREEMPT Wed Nov 13 17:59:34 GMT 2013 armv6l GNU/Linux
Regards - Steven
Posted: Mon Nov 25, 2013 11:02 am
by Honsolgen
[wrong thread --sorry]
Posted: Mon Nov 25, 2013 3:15 pm
by tvjon
kraptv wrote:....
Thanks, looks useful.
Model A:
Model A serial 0000000076ed0a03 detected with 256 MB installed (128 sys / 128 gpu split)
SD card raw capacity: 31.9 GB
Firmware version: Oct 18 2013 16:04:29
version dbda126981820ea5681263042435388dddf65131 (tainted) (release)
temp: 86.7'F (30.4'C)
arm: frequency(45)=700000000
emmc: frequency(47)=100000000
core: volt=1.20V
sdram_c: volt=1.20V
sdram_p: volt=1.23V
MPG2: MPG2=disabled
WVC1: WVC1=disabled
pi@raspberrypi ~ $
Like other posters though, script errors are reported:
cut: the delimiter must be a single character
Try `cut --help' for more information.
./rpii.sh: line 47: -1: substring expression < 0
./rpii.sh: line 50: [: 100000e: integer expression expected
Posted: Mon Nov 25, 2013 11:31 pm
by kraptv
Thanks for the bug reports (and tests on a Model A), everyone, I have since killed those issues.
Try the latest version!
Posted: Mon Nov 25, 2013 11:41 pm
by DougieLawson
In this (http://www.raspberrypi.org/phpBB3/viewtopic.php?t=58632) Android project we collected the following data items:
hostname -f
cat /etc/*-release | grep PRETTY_NAME=
uname -mrs
uname -v
cat /sys/class/thermal/thermal_zone0/temp
cat /proc/uptime
cat /proc/meminfo
cat /proc/loadavg
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
df -T | grep -vE \"tmpfs|rootfs|Filesystem|File system\"
You may want to consider adding some of those (that are missing) to your project.
Posted: Mon Nov 25, 2013 11:44 pm
by DougieLawson
This project http://linuxcounter.net/main.html has been running for many years (and my linux machines have been logging on there). You may want to pull a copy of their code and steal some of their ideas. http://linuxcounter.net/script/lico-update.sh
We can then feed that completed work back to the Linux Counter so they can have a Raspberry Pi version.
Posted: Tue Nov 26, 2013 12:01 am
by kraptv
To be honest, I've actually cut out a lot of the stuff with the idea that I'd be able to display it all within a 80x24 terminal window.
I wanted it to be a bit unique to the hardware circumstances rather than simply replace the system utilities like top and uptime.
I suppose I should work on a "verbose" mode for system-info.sh that will give the mother-lode of information as you suggested - might be good for people wanting "system information super-dumps" in case they need to send back some info to someone else, save for posterity, etc!
Thanks for the suggestions.
Posted: Tue Nov 26, 2013 9:59 am
by micksulley
Very useful, thank you. :D
I was looking for a way to monitor the voltage to my Pi as I have experienced several crashes, but from what I have found it is not possible. Would monitoring the core: volt, sdram_c and sdram_p achieve a similar thing? Should I see these dip if there is a power problem?
Mick
Posted: Tue Nov 26, 2013 10:06 am
by kraptv
Hi Mick!
There could be a lot of factors that are feeding into your system's peculiar behaviour. It might be best to start interacting with the vgencmd commands invoked periodically to see if there are major differences.
http://elinux.org/RPI_vcgencmd_usage will show you the various options you can invoke and get information from.
I know I had some instability when I applied CPU overvoltage and was too zealous with my over clock settings, but when I did a more modest overclock, things were much better.
Also - I happened to experience better stability after I upgraded the firmware and kernel configuration. Have you run the rpi-update command on the system lately?
Posted: Wed Jan 01, 2014 7:13 pm
by jrwagz
Hi @kraptv, great script!
I ran it on my Pi running the SiriProxy image from SourceForge (http://sourceforge.net/projects/siriproxyrpi/) which is based on Raspbian Wheezy, and got a slight error that I was able to easily fix and thought you might want to incorporate:
Here was the original output when running version 0.5.6 of your script:
root@raspberrypi:/bin# ./system_info
tr: extra operand `dd'
Try `tr --help' for more information.
Model B serial 00000000431b1cb9 detected with 256 MB (240 Sys/16 GPU)
SD card raw capacity: 16.1 GB
./system_info: line 53: [: : integer expression expected
Firmware version: Oct 18 2013 16:02:09
version dbda126981820ea5681263042435388dddf65131 (clean) (release)
temp:    115.7'F (46.5'C)
arm:     frequency(45)=700074000
core: volt=1.20V
sdram_c: volt=1.20V
sdram_p: volt=1.23V
MPG2:    MPG2=disabled
WVC1:    WVC1=disabled
I then modified the line where you calculate "rpiOverVolt" to break the "tr" command into two separate commands like so:
rpiOverVolt=`grep Revision /proc/cpuinfo | cut -d " " -f 2 | tr -d [A-Z] | tr -d [a-z]`
It now works without errors:
root@raspberrypi:~# system_info
temp:    111.9'F (44.4'C)
core: volt=1.20V
sdram_c: volt=1.20V
sdram_p: volt=1.23V
MPG2:    MPG2=disabled
WVC1:    WVC1=disabled
Thanks for the handy script!
Posted: Fri Nov 09, 2018 2:05 am
by chrissv
Does anyone maintain this script?
I think it needs to be updated for the Pi 3.
The website referenced in the first posting in this thread doesn't work.
Posted: Fri Nov 09, 2018 9:38 am
by B.Goode
The original author, @kraptv has not logged into these forums since 2016 - it is unlikely, though not impossible, that they will see it and reply.
The original version of the script was published in the initial post in this thread. It is therefore possible for you to update it for your own needs, and maybe republish it somewhere like GitHub for the future benefit of other users.
Posted: Fri Nov 09, 2018 9:40 am
by jamesh
Try this one instead.
https://github.com/raspberrypi/utils/tr ... r/raspinfo
This will be installed as standard on Raspbian at some point, to help with diagnostics.
