max1zzz
Re: Power via gpio
Sun May 06, 2012 10:11 pm
Am i right to assume if i hook up a 5v supply to the 5v pins on the gpio it'll power the RPi fine? it seems that the only micro usb cable i have is a cheap one which is way too thin
thanks
max1zzz
Gert van Loo
Re: Power via gpio
Sun May 06, 2012 10:23 pm
Yes, BUT! you bypass the fuse so it is more risky.
By the way: that has been extensively discussed.
max1zzz
Re: Power via gpio
Sun May 06, 2012 10:25 pm
ok thanks, and it seems my searching skills aren't too good (i did search bu didn't find it)
feel free to close this thread
jbeale
Re: Power via gpio
Mon May 07, 2012 2:15 am
somewhat relevant: is there a general-purpose FAQ on the wiki somewhere? This should be in it. I know of the "Troublshooting" page but it isn't as good a fit there I think.
AndrewS
Re: Power via gpio
Mon May 07, 2012 3:49 am
It is mentioned at http://www.elinux.org/RPi_Hardware#Power but that doesn't count as a FAQ page
ghans
Re: Power via gpio
Mon May 07, 2012 10:01 am
@jbeale
OH GOD. Yes ! There are two:
"Will it work ?" (for the impatient ones)
"End-User FAQ" (if you know what I mean)
ghans
