jell0zz
Re: Securing your RasPi and external HDD's/USB drives.
Thu May 03, 2012 7:44 pm
Hey guys,
I was looking into the option to lock an external HDD or USB drive with just a simple password. Similar to how you use a password to log in to your user.
However, there seems to be no real solution. Almost every solution i have encountered needs a computer side client to unlock the client on the drive.
What I would love is a way to just plug in the drive, let the window pop up which tells you it is locked and it needs a password. Put it in, and the window gets unlocked.
Now, my question is, is there anything like that out there?
Locking your devices is something I believe is quite important as you wouldn't leave your house unlocked why would you leave your external hdd with personal finance information etc unlocked.
Cheers, Jelle
Thu May 03, 2012 8:05 pm
For decent disk security you would really need whole disk encryption. Not sure what's available on Linux although PGP do something on Windows.
Forgot to add, if you only have a few files you want securing rather than the whole disk, try Truecrypt.
jell0zz
Thu May 03, 2012 8:24 pm
No, its really all about securing the entire drive.
Otherwise you would have to encrypt every single new file manually.
Where as if the drive is 'locked' its more like a cupboard with a lock on it, you can put anything in it and you just lock it so nobody can touch it without the key or password.
rmm200
Thu May 03, 2012 8:27 pm
Best to make sure, if the drive is locked, every byte written is encrypted. Otherwise easy enough to stick a new controller board on the drive and have access to everything.
jell0zz
Thu May 03, 2012 9:32 pm
haha, i just want my relatives to keep their hands of it.
and none of them will go that far
Thu May 03, 2012 9:48 pm
You could just have one big truecrypt volume on the drive and put everything in that.
jell0zz
Thu May 03, 2012 10:07 pm
yea but that way truecrypt needs to be on all pc's right? and it deletes everything currently on the hdd right?
dukla2000
Thu May 03, 2012 10:15 pm
Lots of Linux options. I haven't tried any of them but, for example, Ext4 has an option in the format to encrypt the partition.
Daily driver: Pi3B, 64GB Samsung Evo+ @100MHz, DVB-T, onboard WiFi for internet, BT/USB dongle for KB/mouse, 250GB HDD via USB for media, Raspbian Jessie Lite with Openbox desktop.
Museum: Pi B
AndrewS
Thu May 03, 2012 11:46 pm
If you have no computer-side client installed, then what exactly do you expect this "pop-up window" to be displayed by??
Basically there's no such thing as a "simple lock" - you need to have everything on the drive encrypted, either with a "container" like TrueCrypt (or similar), or a "filesystem" like eCrpytfs (or similar).
I believe you can get external USB HDs where the encryption is all done by the drive-controller itself, in which case you wouldn't need client software, but these are usually very expensive.
After some googling I found http://blogs.computerworld.com.....ard_drives
