gyeben
Missing free space
Wed Aug 21, 2013 2:11 pm
I am a quite new Linux user and stumbled upon something that I don't understand. I just bought a new 16GB card, installed Raspbian onto it, and expanded the filesystem. According to the output of df -BM, the root filesystem's size is 14895M, of which 1509M is used and 12763M is available.
I understand that 16 GB = 14,83 GiB, but still, 12763M + 1509M = 14272M, so 623M is missing. What happened with that "missing" space?
RaTTuS
Re: Missing free space
Wed Aug 21, 2013 2:13 pm
df -h
you have 2 partitions
1 for the fat32 boot image
and the rest for the rootfs etc.
Covfefe
gyeben
Wed Aug 21, 2013 4:06 pm
Well, I have already quoted the output of dh.
My problem is that if I sum the amount of used space and the amount of available/free space, it doesn't match the total size.
RaTTuS
Wed Aug 21, 2013 4:12 pm
you have 2 partitions on that card
a fat32 one to hold the boot info and the rest
so it comes closer
look at the output of
df -h
and sudo fdisk -l
Covfefe
itimpi
Wed Aug 21, 2013 5:03 pm
gyeben wrote:Well, I have already quoted the output of dh.
You also have to make an allowance for the space that is used to manage the space within each partition. This is not available for storing data.
OtherCrashOverride
Wed Aug 21, 2013 5:18 pm
Its probably due to "root reserved space" on the filesystem.
http://boncey.org/2006_11_18_reclaiming_ext3_disk_space
When an ext2/3 filesystem is formated by default 5% is reserved for root.
Joe Schmoe
Wed Aug 21, 2013 5:55 pm
The "take away" from this thread (and the many others similar, past, present and future) is that:
1) The standard explanations - Windows only sees 59M, there's extra partitions, Windows can't accesss those partitions, there's gaps between the partitions, NOOBS uses a totally new and different partitioning scheme, etc, etc.
2) It's never going to add up to the penny. BTDT
gyeben
Mon Aug 26, 2013 9:02 pm
OtherCrashOverride wrote:Its probably due to "root reserved space" on the filesystem.
Most of the "missing" space was reserved for root indeed. Thanks for the link!
