projectgregory
Re: I have built my own Raspberry PI
Sat Apr 21, 2012 12:27 pm
I have built my own Raspberry PI but for some reason it does not work.
liz
Sat Apr 21, 2012 12:33 pm
That is *super* cute.
yell
Sat Apr 21, 2012 12:38 pm
you need to plugin the power cord..
edit: the sdcard must be under the PCB.
nickw
Sat Apr 21, 2012 12:43 pm
Unfortunately I think you may have bricked it
ukscone
Sat Apr 21, 2012 12:44 pm
did you try turning it off and turning it on again? If that doesn't work try hitting it
SteGriff
Sat Apr 21, 2012 12:47 pm
I don't know... if he would just change the SD card, it should just click -- figuratively speaking of course.
ukscone
aarrgghhh ok i nominate nickw as the next human sacrifice for that comment.  it's much too early especially pre-coffee
gushie
Sat Apr 21, 2012 12:48 pm
I think you're missing a magnet on the RJ45 port…
MarcoA
Sat Apr 21, 2012 12:54 pm
It's CE compliant for sure!!!
Golem
Sat Apr 21, 2012 1:30 pm
That’s the cat’s toy!14
“Simplicity is the ultimate sophistication”
- LDV
boley
Sat Apr 21, 2012 1:42 pm
Didn't you read the FAQ?  Class 10 SD cards are flakey.  Could I get you to redesign it for me with mounting holes in each corner?
sallocca
You need to submit this to Lego at this web site
http://lego.cuusoo.com/
If it gets 10,000 votes then Lego will look into building it.
I think we could get 10k fans out there to vote and it would be a great way to promote the whole Raspberry Pi project
nickw
Sat Apr 21, 2012 1:58 pm
aarrgghhh ok i nominate nickw as the next human sacrifice for that comment.  it"s much too early especially pre-coffee
Crikey – you should add that you use that sanction to the before you post 101 topic!
Mugwump199
Sat Apr 21, 2012 2:04 pm
As a long time Lego fan, I would definitely like to see it submitted, and would encourage all I know to vote for it. Go for it!
ukscone
Sat Apr 21, 2012 2:07 pm
i thought everyone knew that liz just bought a new cookbook called 'to serve man"
projectgregory
Sat Apr 21, 2012 2:08 pm
Well this as only a 10 min build and uses an illegal connection that the Lego company would not use. So unless I do a redesign its not likely to happen.
zoltan
Sat Apr 21, 2012 2:56 pm
Obviously you did some strange partitioning voodoo on your sd card. Three primary and one extended partion that contains two logical volumes??!
Repartition and you will be playing Minecraft in just no time!
TechColab
Sat Apr 21, 2012 10:49 pm
I bet it still works better than Windows 8.
AllyR
Sun Apr 22, 2012 12:52 pm
So, Liz is starting up a rival project marketing the ManPi?
IT_Sean
Tue Apr 24, 2012 11:00 am
Seriousily, try turning it off and back on again.
Unofficial Raspberry Pi IRC channel: #raspberrypi on irc.freenode.net
Come join us for a chat!
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Tue Apr 24, 2012 4:20 pm
+1,000,000
I would check to see that all of the blocks have been verified, as bad blocks can result in all sorts of nefarious problems.  Choosing the correct block size will also help.  If you choose blocks that are too small, you will be slowed down trying to fit everything optimally.  If you choose blocks that are too big, you will waste space, most notably when you try to fit the Pi into a pocket or even a large-size Altoids tin.
At least you had the good sense to not try building it with Duplo blocks!  :D
Lob0426
Tue Apr 24, 2012 4:32 pm
Fixing it should be snap!
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
