Page 1 of 2
Re: We've just released the schematics!
Posted: Thu Apr 19, 2012 10:36 pm
by liz
See this post from Eben on the main page. I know a lot of you though I was talking out of my backside when I told you we'd be doing this - please submit your humble pi(e) below!
Posted: Thu Apr 19, 2012 10:53 pm
by ukscone
a la mode?
Posted: Thu Apr 19, 2012 10:54 pm
by liz
Right at the moment, it is best if the ice cream is coffee-flavoured.
Posted: Thu Apr 19, 2012 11:02 pm
by ukscone
It's not ice cream but i just chucked a couple of coffee ice cubes in my glass of chocolate milk
Posted: Thu Apr 19, 2012 11:06 pm
by john_wage
Good stuff.
Posted: Thu Apr 19, 2012 11:11 pm
by jbeale
I somehow had the impression that the +5V rail did not go directly to the main SoC, but I see it does connect at five points; A13,A14,A15,B13,B14.  The schematic grouping and pin names imply it is used by the internal switcher to generate VDD_CORE.  Good to know.
Posted: Thu Apr 19, 2012 11:36 pm
by scep
They said it couldn't be done, but using the schematics I have made my own RasPi. Fools!
Posted: Thu Apr 19, 2012 11:44 pm
by ukscone
is that a class10 sd card?
Posted: Fri Apr 20, 2012 12:28 am
by hippy
Excellent news and thanks.
Only one thing jumped out at me; if GPIO47 can be set output high, it's a short via the SD Card Detect to 0V. Not sure if it's possible to set it that way by accident or what damage it would do if one did.
Having 5V-0V-TXD-RXD on the GPIO as a consecutive block of four is a nice and useful surprise.
Posted: Fri Apr 20, 2012 12:36 am
by johnbeetem
Yes, that is very interesting... excellent observation.  I guess 10 uF C17 (probably multi-layer ceramic) provides the bulk +5V bypass when electrolytic cap C6 breaks off   Very nice that VDD_CORE is generated from +5V to reduce the load on +3.3V regulator RG2.
Posted: Fri Apr 20, 2012 3:10 am
by rurwin
Thanks loads for this.
I'll pass thanks. Ice-cream yes, coffee maybe, but coffee ice-cream is an abomination.
Posted: Fri Apr 20, 2012 3:13 am
by Golem
1+0+0= 100
Posted: Fri Apr 20, 2012 3:49 am
by Golem
No, no… I’ve made a mistake --- let me recalculate this!
Posted: Fri Apr 20, 2012 8:17 am
by Michael
I've created an errata wiki page at http://elinux.org/RPi_schematic_errata to track any typos, etc the community might spot.
Posted: Fri Apr 20, 2012 9:35 am
by bredman
When are you shipping? Do you accept PayPal?
Posted: Fri Apr 20, 2012 9:50 am
by jamesh
You'll have to get to the back of the queue, so far there have been, let me see...100k, 200k, 350K.....1 order. By sceps Mum.
Posted: Fri Apr 20, 2012 11:20 am
by selsinork
I demand that you put all the connectors on the same side...
and that you add another gig of ram
and where's the VGA connector
and wouldn't an extra Gbit network be useful ?
and you forgot the SATA interface, and the PCIe 2.0 x16 slot
actually, just add a SODIMM slot while you're at it
Then make sure the price is $5 delivered to my door anywhere in the world, that I don't have to pay anything for delivery and that my Govt won't charge any import duty, tax or anything else...
Oh, and can you have 1 million shipped by Monday ??
P.S. does it run Windows ?
Posted: Sat Apr 21, 2012 12:56 am
by mjtessmer
Would it be possible to release a pinout and block diagram of the
BCM2835 SOC?
Posted: Sat Apr 21, 2012 9:07 am
by Michael
BCM2835 SOC?
The pinout is given in the schematic: http://www.raspberrypi.org/wp-.....s-R1.0.pdf
The datasheet (http://www.raspberrypi.org/wp-.....herals.pdf) provides further detail on the GPIO pins.
A very basic board-level block diagram by Paul Beech:
http://elinux.org/images/thumb.....9x1024.png
There are a number of block diagrams in the datasheet, including 6-1 GPIO pins, 8-2 PCM audio interface, 10-6 serial interface
Posted: Sat Apr 21, 2012 10:51 am
by Robert_M
Where did you hide the Heisenberg Compensator?
Posted: Sat Apr 21, 2012 11:17 am
by M0TGW
It's behind the flux capacitor
Posted: Mon Apr 23, 2012 2:12 pm
by AndrewS
Posted: Tue Apr 24, 2012 3:58 am
by jbeale
Great job on that netlist, Andrew!  I don't know how you found the patience to generate that!
Posted: Tue Apr 24, 2012 4:15 am
by mjtessmer
Thanks! Andrew
Gert:  Can you tell us which pins the I2S signals are on?
Posted: Tue Apr 24, 2012 6:09 am
by rew
The GPIO pinout that was published mentions one of them as DNC. This means that a future run of RPIs might have a GPIO pin there.
Also note that you should not directly drive 5V onto the RXD line. If you do, you'll "shorten the lifetime of the SOC" as Liz always says.
Check out http://www.bitwizard.nl/catalo.....ucts_id=69 for the breakout to that ground-rxd-txd-5V pinout that you wanted. And it has a protection circuit that keeps your RPI in one piece if you drive it at 5V levels.
