gjs
Re: Mono Working on Raspberry Pi?
Thu Apr 19, 2012 4:25 pm
Can anyone that has a board confirm if Mono runs on the Raspberry Pi?
Thanks.
Joe Schmoe
Thu Apr 19, 2012 6:42 pm
I think if you run the stereo audio output and the cut one of the wires (say, the right channel), then you'll get mono.
Not sure why you'd want to do this, though.
fodi
Thu Apr 19, 2012 7:17 pm
i think he wants some information about this mono: mono framework
gjs
Thu Apr 19, 2012 7:31 pm
Correct.  Sorry, should have been more explicit.
pepedog
Thu Apr 19, 2012 8:07 pm
Yes, it works, at least in arch
Harrkev
Thu Apr 19, 2012 9:19 pm
Thanks.
If you are referring to Mononucleosis, the infectious "kissing disease," then I strongly suspect that your Pi won't get it, no matter how much you kiss it.  If you are still worried, then try installing an anti-virus program.
emg
Thu Apr 19, 2012 10:56 pm
I too would be interested in details if anyone with a board has Mono under Debian running. Also Iron Python as well. I've got a few C# apps I'd like to try running on the Rpi...
gjs
Fri Apr 20, 2012 10:08 am
Thank you.  That give me more confidence.  I would still like to hear of it working on Debian Squeeze, though, if anyone can oblige.
romland
Fri Apr 20, 2012 1:58 pm
Then you'll be happy to know that everything works just hunky dory. I grabbed the default Debian image from the Foundation and installed Mono and compiled a small test (look up local system ip information ) and executed it without any issues.
Cheers,
Joakim
gjs
Fri Apr 20, 2012 2:10 pm
Excellent news.  Thank you very much.
GvdB
Thu Apr 26, 2012 6:46 pm
Yep, I ran ' apt-get install mono-complete' takes 42MB to download, 125MB to install, download time was 1.5 min. installing took 15 min or more. But then it worked.
GvdB
emg
Thu Apr 26, 2012 7:42 pm
romland,
Excellent. Thanks for testing this. +1 internets for you!
Yannikator
Fri Jan 18, 2013 8:45 am
I'm trying on RaspBian Wheezy... And I find troubles that we can see on stack trace bellow :
grep: /etc/gre.d/*.conf: No such file or directory
generating monodoc search index... (this can take a while)
Problem: O:Mono.Math.BigInteger.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector2d.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector2l.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector2ul.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector4f.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector4i.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector4ui.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector8s.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector8us.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector16b.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
Problem: O:Mono.Simd.Vector16sb.Conversion, with xpath: /Type/Members/Member[@MemberName='op_Conversion']/Docs
It appears that the install can't find framework documentation ?? :?:
And there a long list... That take a long time... I'm drinking my second coffee... ^^
Just finish my coffee and install also! Fine! we are synchronised.
I wrote a small script like this :
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace testMono
    class Program
        static void Main(string[] args)
            System.Console.WriteLine("Test Mono");
            String input = System.Console.ReadLine();
            System.Console.WriteLine("it work fine! [" + input + "]");
            return;
I try compile this one :
mcs test.cs
No problem... I find a test.exe in my directory.
So, I try to launch my test.exe! It's not so easy... -_-
But it work!
I was helped by the instructions on the site bellow:
http://www.mono-project.com/Running_you ... pplication
But instead of the instruction, I wrote a script test with this command :
 /usr/bin/mono ./test.exe
After, I run the script with command :
 sh test
Result :
pi@raspberrypi ~/Mono/test $ sh test
Test Mono
GOGO
it work fine! [GOGO]
SO , it work! ^^
Jardar
Mon Mar 18, 2013 2:59 pm
With Arch, I used this command in order to install mono, .Net framework and dependencies:
pacman nginx mono fcgi xsb
Works fine, I'm happy to say :-)
ajithrit
Wed Jun 05, 2013 10:08 am
I would like to use a C# Windows Form developed on a Linux machine using mono develop as start up screen in raspberry pi. I mean I will use Matchbox or some other window manager and then launch my C# exe from Rc.local. I have two doubts
1. If I install Mono run time in RPI will it be possible to run the same executable I created in the linux PC to work on RPi as well?( I suppose the .Net should be platform independant)
2. Will the above mentioned way of having a different "HMI" other than LXDE for my system using matchbox window manager is possible(for example I put a loop in the rc.local to launch the Form continuously)
