ukanonymous
Argh!
Tue Jul 02, 2013 8:27 pm
How do I fix this please? I reloaded the SD card with weezy and then tried to SSH and got this
pc5:~ raspberrypi$ ssh pi@192.168.1.17
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the RSA key sent by the remote host is
51:78:12:a7:cc:79:11:52:c3:e2:f8:18:da:42:72:b2.
Please contact your system administrator.
Add correct host key in /Users/raspberrypi/.ssh/known_hosts to get rid of this message.
Offending RSA key in /Users/raspberrypi/.ssh/known_hosts:2
RSA host key for 192.168.1.17 has changed and you have requested strict checking.
Host key verification failed.
pc5:~ raspberrypi$
Re: Argh!
Tue Jul 02, 2013 8:38 pm
You need to delete the old entry from the .ssh/known_hosts file.
"Offending RSA key in /Users/raspberrypi/.ssh/known_hosts:2"
This is telling you that the old key is on line 2 of the file.
There are many ways to do that, but a quick one is with
sed -i "2d" /Users/raspberrypi/.ssh/known_hosts
(-i is "edit file and save contents back to same file". "2d" means "line 2, delete")
Then try the ssh again. You will probably get a warning at first, but it should still work.
ukanonymous
Re: Argh!
Tue Jul 02, 2013 8:39 pm
How do I do this though? I only have my laptop to work with :(
ukanonymous
Re: Argh!
Tue Jul 02, 2013 8:40 pm
I got this
pc5:~ raspberrypi$ sed -i "2d" /Users/raspberrypi/.ssh/known_hosts
sed: -i may not be used with stdin
pc5:~ raspberrypi$
surfatwork
Re: Argh!
Tue Jul 02, 2013 9:08 pm
Use any text editor of choice (vi, nano, gedit, notepad) on your laptop, open /Users/raspberrypi/.ssh/known_hosts, delete line 2, save it and then try the ssh again. You will get a warning, but it will work.
Re: Argh!
Wed Jul 03, 2013 5:56 am
ukanonymous wrote:I got this
pc5:~ raspberrypi$
Are you using a Mac? It seems the -i option isn't as flexible under OSX. It won't work if the filename doesn't have a ".something" extension on the end.
As surfatwork said, you can also use any text editor to delete that line.
ukanonymous
Re: Argh!
Wed Jul 03, 2013 6:40 am
thank you I did it wohoo and now virtually connected. This is awesome
