robonerd137
Simple question about resistors
Tue Jul 02, 2013 5:57 pm
Hi...
i am trying to understand basic electronics so i don't need to only copy projects i see on the internet, but also be able to create my own.
So, my problem is that i am trying to figure out how to find the right Resistor to use with LEDs.
I know about the Ohm's Law: V=IR and i though i should be able to use it to find the R value.
But my problem is that i have the LEDs for reaaaaaaally long time and i have no idea about any of it's values.
I have read often that a average LED takes about 20mA current.
So it would make something like:
V = I R
R = V / I
R = 5 / 0.020
R = 250 Ohm
right?
But what if i don't know the I from the LED, how can i find that out?
Also, i read about this formula for calculating the Resistor for a LED:
R = (Es - Eled) / Iled
Es - source voltage (V)
Eled - voltage drop across the LED (V),
Iled - current through the LED (A)
Would it be better to use this formula?
Thanks...
Re: Simple question about resistors
Tue Jul 02, 2013 6:33 pm
The second formula is correct. The voltage across the resistor is the supply voltage minus the voltage across the LED. So V in your V = IR should be (Vsupply - Vled).
Using a 5V supply (do remember that the Pi uses 3.3V for the GPIOs, not 5V!) and a 20mA 2V red LED as an example.
Vsupply = 5
Vled = 2
I = 0.02 (20 mA)
V = IR or V/I =R
(5 - 2) / 0.02 = R
3 / 0.02 = R
150 = R
For 3.3V it would be (3.3 - 2)/0.02 or 65 ohms, but you don't want to be taking that much current from a gpio. Most LEDs will work down to around 5mA (especially the low current ones), so 150 ohms would give about 8.7mA on a 3.3V supply.
