Nikki81
how to stop usb hub powering the pi
Tue Jun 25, 2013 10:57 am
Ive just got a new usb hub for my pi and it is back powering it is there a simple way for me to stop it happening ?
pluggy
Re: how to stop usb hub powering the pi
Tue Jun 25, 2013 11:04 am
Easiest way is don't bother about it.
That should get the puritans going....
You could do open heart surgery on the hub or butcher a USB cable if it worries you.
Nikki81
Tue Jun 25, 2013 11:31 am
Thanks ill just take the power pin off the USB in socket looking at the links above then ill be able to use any pi to hub cable.
mrpi64
Tue Jun 25, 2013 12:38 pm
Cest impossible. no way to do it, I'm afraid.
Mod edit: Wrong, sorry. See links above.
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
pluggy
Tue Jun 25, 2013 12:43 pm
mrpi64 wrote:Cest impossible. no way to do it, I'm afraid.
Defeatist.....
redhawk
Tue Jun 25, 2013 1:13 pm
Cut the red wire :)
Richard S.
Davespice
Contact: Twitter
Tue Jun 25, 2013 1:15 pm
Nikki81 wrote:Thanks ill just take the power pin off the USB in socket looking at the links above then ill be able to use any pi to hub cable.
Yep, that will also do it. Just make sure you remove the right pin!
Joe Schmoe
Tue Jun 25, 2013 1:25 pm
Why does this matter? I didn't see any text in the OP describing why he thinks there's any reason to worry about this.
Like so many other things, cutting the wire seems like a solution in search of a problem...
Davespice
Contact: Twitter
Tue Jun 25, 2013 1:29 pm
Joe Schmoe wrote:Like so many other things, cutting the wire seems like a solution in search of a problem...
I think it puts stress on the polyfuse or something, I think we might need Gert or Dom to comment on this officially though.
The OP was asking how to stop the behaviour, from the title of the post, so we were just giving the answer.
pluggy
Tue Jun 25, 2013 1:32 pm
hippy
Tue Jun 25, 2013 3:52 pm
Poundland in the UK sell a small Signalex USB adapter for charging iPhone. That's basically a USB A male to USB A female on a PCB with a flying lead off to the charger connector, all wrapped in a plastic case. You can probably find similar products elsewhere.
Very easy to modify so it's a through connector without Vusb connected, or for injecting external power as a back-feed through the USB ports.
http://i.ebayimg.com/t/Signalex-USB-iph ... ~60_35.JPG
ChromeBlue
Wed Jun 26, 2013 5:01 pm
Best idea yet - IF you'll never connect any USB device direct to Pi.
Frito: Yah I know this place pretty good, I went to law school here.
Pvt. Joe Bowers: In Costco?
From Idiocracy - funniest/scariest move ever.
Lob0426
Thu Jun 27, 2013 3:43 am
Just run it back-powered. I have been for almost a year now.
Cut the red or the blue? The ever confusing movie question. Of course there are no blue wires in a USB cable!
http://www.raspberrypi.org/phpBB3/viewt ... 41&t=16473
Letting it back-power gives me 5 USB ports. 1 RasPi port, 4 USB hub ports so 5 ports in all. I have two RasPi working this way. A modified ver. 1 256MB and a unmodified ver. 2 512MB. Both have a 2 amp PSU and have been completely reliable!
But since you asked, cut the red wire in the cable from the RasPi USB to the uplink port in your hub. Or open the hub and cut the pin from the board to the connector. Either will work. I have tried stripping the contact out of the connector, it would not peel off. I also covered the pin with some thin tape, that did work.
Good Luck either way you try!
Motorola Lapdock with Pi2B
http://rich1.dyndns.tv/
SirLagz
Thu Jun 27, 2013 7:43 am
Unless he's doing it to the socket on the hub...
