JohanSA
just stopped working
Sun Jun 23, 2013 6:33 am
Hello
I use the pi to play music from a playlist. It was working fine for 2 days and then it just stopped (i had it working 24x7). The SD is corrupt. This is strange because nobody touched the pi. This has happened 3 times with 3 different pis and 3 different SD cards. Could it be the software on the SD card?
Btw all the lights are on and when i tried to connect it to a hdmi screen it is blank.
malakai
Re: just stopped working
Sun Jun 23, 2013 7:13 am
Are you booting with the HDMI connected if not it will not display through HDMI.
Is power dropping out? Wireless connection or wired? Need a bit more info on setup. Can you ssh into the Pi when it is non responsive. When rebooted what error are you seeing.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
JohanSA
Sun Jun 23, 2013 7:19 am
Ok you have resolved my hdmi issue.
The power is fine. I have another pi running the same software in the same location.
I cannot ssh to it when it is in this states. I have not rebooted because i am trying to find a way to see the current state....which does not seem possible.
The other 2 that had this problem gave me an error message 'unable to mount root...'
JohanSA
Sun Jun 23, 2013 8:07 am
Sorry i forgot to mention it is wired
JohanSA
Sun Jun 23, 2013 12:37 pm
Any ideas as to why this would happen?
pluggy
Sun Jun 23, 2013 3:42 pm
Top two reasons for SD card corruption :
Power supply.
Overclocking.
JohanSA
Sun Jun 23, 2013 4:08 pm
Thank you. I doubt it is a power supply issue. I am using Samsung charger. In a stable environment so there is no surcharge or power failure.
I am a little new to this. How can i identify if overclocking is the problem
mc349
Mon Jun 24, 2013 7:32 am
JohanSA wrote: I am a little new to this. How can i identify if overclocking is the problem
Have you enabled overclocking? I doubt you'd need it for playing MP3s. If you have re-edit your config to turn it off again and retest.
If that doesn't fix it then do another test with a different power source (just to rule that out too). You could also try a different brand of SD Card to eliminate that possiblity.
JohanSA
Mon Jun 24, 2013 7:38 am
Thank you for your replies. It seems as though the corrupt SD cards is common. I found this thread:
http://www.raspberrypi.org/phpBB3/viewt ... 3&start=25
liz
Mon Jun 24, 2013 11:43 am
Have you shut it down (sudo halt) before unplugging the power supply? Not doing so is a quick route to a toasted SD card.
JohanSA
Mon Jun 24, 2013 11:51 am
It was playing music when it just stopped working. I cannot connect to it in any way.
liz
Mon Jun 24, 2013 12:05 pm
Are you overclocking?
JohanSA
Thu Jul 18, 2013 1:58 pm
no i am not overclocking.
Are there any default logs that would assist in trying to debug the problem?
