WizardZ0mbie
Re: Installing debian to a usb drive?
Fri Apr 13, 2012 7:52 pm
If I write an install image to a sd card, can I install Debian onto a usb memory stick and then let my pi boot from it after the install? Thanks
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Sat Apr 14, 2012 5:39 pm
You always have to boot from the SD card, but, you can copy/move everything except the /boot directory to the USB drive, then edit the /boot configuration files on the SD card to point to the USB drive. Once boot is complete, the /boot directory is no longer needed, and you can remove the SD card to allow insertion of another card. You can also spread the non-boot directories across multiple USB drives, editing the boot config files appropriately.
pvautrin
Thu Apr 26, 2012 1:38 am
How would one edit the config files?
In the debian6-19-04-2012.zip image, there is the cmdline.txt config file (absent from the firmware boot folder on git) which contains:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
If files are moved to first partition of USB drive (ext4), would it be as simple as replacing with root=/dev/sda1p1 ?
EDIT: Answering myself, it seems /dev/sda1 is correct
http://zenit.senecac.on.ca/wik.....or_Storage
anthonycroberts
Wed May 02, 2012 10:56 pm
I couldn't make this work with the Debian image.  It hangs waiting for the root device /dev/sda1.  It appears to be loading the USB drive, but it is not getting assigned a node (/dev/sda1).  Any thoughts on how to fix this?
dom
Wed May 02, 2012 11:17 pm
Latest kernel on GitHub enables some options needed for USB boot.
pvautrin
Thu May 03, 2012 1:08 am
Does this mean the SD card is no longer mandatory or just that the handover from SD to USB drive via root=.. was borked and is now fixed?
rmm200
Thu May 03, 2012 1:20 am
SDCard will always be necessary to boot from.
