JxPond
Waking up Pi
Sun Jun 02, 2013 1:05 am
Given the power requirements, I assume a lot of people just keep their pis running. However does the pi actually ever shutdown? It seems to s3 on shutdown. Is there a polling event that will wake it?
Re: Waking up Pi
Sun Jun 02, 2013 5:42 am
You can wake your Pi by briefly connecting pins 5 and 6 on P1. This is handled by the firmware. It will cause the kernel to be reloaded from scratch though, so is pretty much the same as a cold start.
You can also connect the two pins of (the not fitted by default) P6, which is (I believe) a hardware reset.
I'm not aware of any other way to wake a Pi from that state, other than killing the power.
