jtb
copy32to8Gb
Mon May 06, 2013 12:31 pm
Hi
I want to make a system-disc on a USB-stick and just boot up from a smaller size SD-card
and been searching for a way to copy a 32Gb SD to a 8Gb SD but cant find anything here or when googling.
It will be a waist to use a 32Gb for just booting up and i got a samsung 8Gb,to big again but fast and reliable.
Jan
Just throw me out if I get obscene but that's the way that I've
always been
I think I know for certain
Joe Schmoe
Re: copy32to8Gb
Mon May 06, 2013 12:53 pm
The easiest thing to do is just to copy the files.
Get both devices (the SD card and the flash drive) mounted, then use "cp -a" to copy from one to the other.
jtb
Re: copy32to8Gb
Mon May 06, 2013 5:24 pm
Hi
I want to copy a 32Gb SD-card to a 8Gb SD-card first,then make a systemdisc on a usb-stick.
booting up from the SD and let the usb-stick take over.
Theres only about 5Mb of data on the 32Gb SD-card but rasperian had taken all 32GB.
Can I change the partitions,making it possible to copy to a smaller size SD-card?
Or do I have to download+install everything again?
Jan
2
always been
Joe Schmoe
Re: copy32to8Gb
Mon May 06, 2013 6:42 pm
Yes, it should "just work".
Note that on the Pi, there's really no such thing as a "system disk" (as there is on x86, running DOS, Windows, Linux, whatever). There's just files.
tedhale
Re: copy32to8Gb
Mon May 06, 2013 7:31 pm
jtb wrote:Hi
I use Mini-Tool Partition Wizard to do it under windows.
http://www.partitionwizard.com/free-par ... nager.html
- Ted B. Hale
http://raspberrypihobbyist.blogspot.com
