Re: very cheap case
Posted: Mon Mar 19, 2012 5:09 pm
by pigsy
Here on ebay, £2.40 for 5  ,should be easy to cut holes with a craft knife or a dremel  http://www.ebay.co.uk/itm/BUSI.....500wt_1054
Re: very cheap case
Posted: Mon Mar 19, 2012 7:53 pm
by Shpaget
http://www.rapidsupplies.co.uk.....es-7-p.asp
It's cheaper.
Re: very cheap case
Posted: Mon Mar 19, 2012 8:27 pm
by SlobJunkie
I don't think it would be good idea using this type of case for our Raspberry PI's with the case being made of polypropylene
The problem is with the two parts of the case rubbing against each other when opened and closed the box will generate a lot of static, wouldn't want to subject my PI to static.  I think I would rather use a potting box instead which are cheap as chips
like this  http://goo.gl/99Ohx
Re: very cheap case
Posted: Mon Mar 19, 2012 10:14 pm
by pigsy
hmm hadnt thought of that
Re: very cheap case
Posted: Tue Mar 20, 2012 8:58 am
by RaTTuS
paper bag?
Re: very cheap case
Posted: Tue Mar 20, 2012 6:38 pm
by trikidiki
RaTTuS said:
paper bag?
Nasty paper cuts!
Re: very cheap case
Posted: Tue Mar 20, 2012 7:11 pm
by TheCrazyInventor
SlobJunkie said:
I don"t think it would be good idea using this type of case for our Raspberry PI"s with the case being made of polypropylene
The problem is with the two parts of the case rubbing against each other when opened and closed the box will generate a lot of static, wouldn"t want to subject my PI to static.  I think I would rather use a potting box instead which are cheap as chips
"Static"...?
Meh, don't worry too much about ESD. The Pi will be fine inside that box. And besides, other plastic surfaces also build up a substantial charge when two surfaces are separated from each other.
Re: very cheap case
Posted: Tue Mar 20, 2012 7:54 pm
by Stewrat
It's cheaper.
How is £4.35 for 1 including delivery cheaper than £2.40 for 5 inc delivery?
